Hello guys hopefully somebody can help me here. I recently got a R2 and a MT7615 card for Wifi, my image is a self-build Alpine 3.13.3 and it works great.
Now after I got the internal wifi working and now wanted to add a better card I aquired the MT7615 card, but ever 5GHz channel has the “no IR” flag which means no channel is usable. Hence hostapd will not select a channel.
I use @frank-w kernel 5.10 and have also tried 5.4 both have the same issue. I have the “wireless-regdb” package installed the kernel still erros with “platform regulatory.0: Direct firmware load for regulatory.db failed with error -2” “cfg80211: failed to load regulatory.db” I also tried to compile the kernels with cfg80211 as a module which fails. Lots of “undefined reference” errors. Hence I cannot pass any argument to cfg80211 like described in multiple wikis.
“iw reg set US” or any other (DE,GB,JP) doesn’t work. I need help it seems I cannot do anything.
