Maybe change this:
https://elixir.bootlin.com/linux/latest/source/net/wireless/reg.c#L270
Oh that I also changed as I thought it may be relevant , no dice.
Then i guess you need entry-point of module where the params are parsed to get function which sets the countrycode and copy this with fixed country to non-module startcode
That sounds like a really complicated matter, nothing I would be able to do . Thank you for all the help .
come a bit further to build cfg80211 as module and supporting r2 internal wifi:
diff --git a/drivers/misc/mediatek/connectivity/Kconfig b/drivers/misc/mediatek/connectivity/Kconfig
index cf31d30c763a..ad1a3e051ea1 100644
--- a/drivers/misc/mediatek/connectivity/Kconfig
+++ b/drivers/misc/mediatek/connectivity/Kconfig
@@ -216,7 +216,7 @@ config MTK_COMBO_BT_HCI
config MTK_COMBO_WIFI
tristate "MediaTek combo chip Wi-Fi support"
- depends on MTK_COMBO
+ depends on MTK_COMBO && CFG80211
select MTK_BTIF
select WIRELESS_EXT
select WEXT_PRIV
if now cfg80211 is module, MTK_COMBO_WIFI be built as moduleâŚnot yet completely because of
drivers/misc/mediatek/connectivity/common/common_detect/drv_init/wlan_drv_init.c:34: undefined reference to `mtk_wcn_wmt_wifi_init'
so i built wlan_drv_init as module too
diff --git a/drivers/misc/mediatek/connectivity/common/common_detect/drv_init/Makefile b/drivers/misc/mediatek/connectivity/common/common_detect/drv_init/Makefile
index fda8ba149107..e7d13fefcf91 100644
--- a/drivers/misc/mediatek/connectivity/common/common_detect/drv_init/Makefile
+++ b/drivers/misc/mediatek/connectivity/common/common_detect/drv_init/Makefile
@@ -16,7 +16,7 @@ endif
obj-y += bluetooth_drv_init.o
obj-y += gps_drv_init.o
obj-y += fm_drv_init.o
- obj-y += wlan_drv_init.o
+ obj-$(CONFIG_MTK_COMBO_WIFI) += wlan_drv_init.o
obj-($(CONFIG_MTK_COMBO_ANT)) += ant_drv_init.o
endif
now i hang here:
ERROR: modpost: missing MODULE_LICENSE() in drivers/misc/mediatek/connectivity/common/common_detect/drv_init/wlan_drv_init.o
ERROR: modpost: "sched_setscheduler" [drivers/misc/mediatek/connectivity/wlan/gen2/wlan_gen2.ko] undefined!
ERROR: modpost: "gWmtDetectDbgLvl" [drivers/misc/mediatek/connectivity/common/common_detect/drv_init/wlan_drv_init.ko] undefined!
cause gWmtDetectDbgLvl is declared as external in drivers/misc/mediatek/connectivity/common/common_detect/wmt_detect.h and defined in wmt_detect.c
for sched_setscheduler this seems to be defined in ./kernel/sched/core.c, here just a export is missing (which was removed in 2020)
diff --git a/kernel/sched/core.c b/kernel/sched/core.c
index 98191218d891..b7858e39c118 100644
--- a/kernel/sched/core.c
+++ b/kernel/sched/core.c
@@ -6374,6 +6374,7 @@ int sched_setscheduler(struct task_struct *p, int policy,
return _sched_setscheduler(p, policy, param, true);
+EXPORT_SYMBOL_GPL(sched_setscheduler);
for the gWmtDetectDbgLvl (external) and LICENSE:
diff --git a/drivers/misc/mediatek/connectivity/common/common_detect/drv_init/wlan_drv_init.c b/drivers/misc/mediatek/connectivity/common/common_detect/drv_init/wlan_drv_init.c
index 6d7c5751cade..2bc7315ebfb4 100644
--- a/drivers/misc/mediatek/connectivity/common/common_detect/drv_init/wlan_drv_init.c
+++ b/drivers/misc/mediatek/connectivity/common/common_detect/drv_init/wlan_drv_init.c
@@ -20,6 +20,7 @@
#include "wmt_detect.h"
#include "wlan_drv_init.h"
+unsigned int gWmtDetectDbgLvl = WMT_DETECT_LOG_INFO;
int do_wlan_drv_init(int chip_id)
@@ -73,3 +74,5 @@ int do_wlan_drv_init(int chip_id)
return i_ret;
+MODULE_LICENSE("GPL");
r2wifi-mod.patch (2,1 KB)
you can try this patch (created on 5.12), i can compile, but have not tested its functionalityâŚ
patch -p1 < path/to/patch
in kernel source root
before running wmt commands on r2 make sure all modules have been loaded
net/wireless/cfg80211.ko
net/mac80211/mac80211.ko
drivers/misc/mediatek/connectivity/common/conn_soc/linux/pub/stp_chrdev_bt.ko
drivers/misc/mediatek/connectivity/common/conn_soc/linux/pub/wmt_chrdev_wifi.ko
mhm, as i thought, change for gWmtDetectDbgLvl breaks builtin-compilationâŚso i guarded the new definition depended on module-compilation
index 2bc7315ebfb4..86f0cffc841c 100644
@@ -20,7 +20,9 @@
+#if defined(CONFIG_MTK_COMBO_WIFI_MODULE)
+#endif
Maybe anybody have an idea how to build 1 module for wifi instead of 4âŚmaybe we can work here with exports too. I guess this is wrong here:
maybe use defined(CONFIG_MTK_COMBO_WIFI_MODULE) here too as it is done for function call
Have not found where MTK_WCN_REMOVE_KERNEL_MODULE is defined,but for BT this is dropped (bt working only as module). CONFIG_MTK_COMBO_WIFI_MODULE not defined anywhere tooâŚso always false
seems like i need to link connectivity/common/conn_soc/linux/pub/wmt_chrdev_wifi.c to connectivity/common/common_detect/drv_init/wlan_drv_init.c to get this working. as the first should be the module and the second is the âcoreâ, this cannot work this wayâŚso we need another way to reduce module-count
in bluetooth-âcoreâ this call is simply disabled but this depends driver is always built as module (because it is initialized on module load)
added commits to 5.12-hnat treeâŚbut not yet tested
Ok applied the patch (to branch 5.10-main) and everything compiles fine, with âiw reg getâ I get my desired output.
Now for the rest: I modprobed the modules you mentioned, modules load but there is output in dmesg.
When loading stp_chrdev_bt:
Apr 5 17:41:27 kernel: [ 109.363955] [MTK-BT] BT_init: mtk_stp_BT_chrdev driver(major 192) installed
Apr 5 17:41:27 kernel: [ 109.363986] [WMT-STP-EXP][E]mtk_wcn_stp_register_if_rx(223):ERROR! mtk_wcn_stp_if_rx_f cb is null
Apr 5 17:41:27 kernel: [ 109.364600] [WMT-STP-EXP][E]mtk_wcn_wmt_func_on(332):ERROR! mtk_wcn_wmt_func_on_f cb is null
Apr 5 17:41:27 kernel: [ 109.364613] mtk_bt_hci_open func on failed with 0
Apr 5 17:42:08 kernel: [ 149.972826] [WMT-STP-EXP][E]mtk_wcn_wmt_msgcb_reg(384):ERROR! mtk_wcn_wmt_msgcb_reg_f cb is null
Now starting wmt_loader gives the following
Apr 5 17:43:31 kernel: [ 232.718444] [WMT-DETECT][I]wmt_detect_open:open major 154 minor 0 (pid 1451)
Apr 5 17:43:31 kernel: [ 232.718498] [WMT-DETECT][I]wmt_detect_unlocked_ioctl:cmd (-2147191037),arg(0)
Apr 5 17:43:31 kernel: [ 232.718536] [WMT-DETECT][I]wmt_detect_unlocked_ioctl:cmd (1074034433),arg(30243)
Apr 5 17:43:31 kernel: [ 232.718544] set current consys chipid (0x7623)
Apr 5 17:43:31 kernel: [ 232.718571] [WMT-DETECT][I]wmt_detect_unlocked_ioctl:cmd (-2147191036),arg(30243)
Apr 5 17:43:31 kernel: [ 232.718580] [WMT-MOD-INIT][I]do_common_drv_init:start to do common driver init, chipid:0x00007623
Apr 5 17:43:31 kernel: [ 232.722019] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6620.defAnt'.
Apr 5 17:43:31 kernel: [ 232.722037] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6628.defAnt'.
Apr 5 17:43:31 kernel: [ 232.722047] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6630.defAnt'.
Apr 5 17:43:31 kernel: [ 232.724606] [WMT-MOD-INIT][I]do_common_drv_init:finish common driver init
Apr 5 17:43:31 kernel: [ 232.724623] [WCN-MOD-INIT][E]do_connectivity_driver_init(58):do common driver init failed, ret:-1
Apr 5 17:43:31 kernel: [ 232.724631] [WCN-MOD-INIT][E]do_wlan_drv_init(31):Can not find wlan module for chip: 30243 !
Apr 5 17:43:31 kernel: [ 232.725058] [WMT-DETECT][I]wmt_detect_close:close major 154 minor 0 (pid 1451)
Going on with âstp_uart_launcher -p /etc/firmware &â
Apr 5 17:44:33 kernel: [ 294.468188] [WMT-CORE][E]opfunc_hif_conf(874):WMT-CORE: WMT HIF info added
Apr 5 17:44:33 kernel: [ 294.468649] vcn18: mode operation not allowed
Apr 5 17:44:33 kernel: [ 294.470513] [WMT-CONSYS-HW][E]mtk_wcn_consys_hw_reg_ctrl(290):Read CONSYS chipId(0xfffff093)
Apr 5 17:44:33 kernel: [ 294.570340] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6620.defAnt'.
Apr 5 17:44:33 kernel: [ 294.570358] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6628.defAnt'.
Apr 5 17:44:33 kernel: [ 294.570367] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6630.defAnt'.
Apr 5 17:44:33 kernel: [ 295.149989] [STP] mtk_wcn_stp_psm_enable:[W] STP Not Ready, Dont do Sleep/Wakeup
After all this the device â/dev/wmtWifiâ is never created so I canât do ,obvioulsy, âecho A >/dev/wmtWifiâ
lsmod:
wlan_gen2 1548288 0 stp_chrdev_bt 24576 0 wlan_drv_init 16384 0 wmt_chrdev_wifi 20480 2 wlan_gen2,wlan_drv_init mac80211 749568 0 cfg80211 774144 2 wlan_gen2,mac80211 libarc4 16384 1 mac80211
Iâd say this is a good start?
Afair bluetooth needs to be loaded after running stp_uart_launcher and wmtloader
Could you try also last patch from 5.12-hnat as it includes wlan_drv_init
back to builtin?
Then try running wmt loader and stp_uart_launcher first then load modules
I downloaded the branch â5.12-hnatâ but I canât do â./build.sh importconfigâ as it gives me an error âplease install gcc-aarch64-linux-gnuâ.
Trying to manually edit the files in â5.10-mainâ branch results in:
drivers/misc/mediatek/connectivity/common/common_detect/drv_init/wlan_drv_init.o: In function `.LANCHOR0':
wlan_drv_init.c:(.data+0x0): multiple definition of `gWmtDetectDbgLvl'
drivers/misc/mediatek/connectivity/common/common_detect/wmt_detect.o:wmt_detect.c:(.data+0x4): first defined here
Makefile:1166: recipe for target 'vmlinux' failed
make: *** [vmlinux] Error 1
5.12-hnat is changed to bpi-r64 in build.conf,just comment out the line by adding a # at beginning
board=bpi-r64
Got it compiled and have it now on the Pi.
Here are the outputs as I do them:
modprobe mac80211 modprobe cfg80211
âiw reg getâ has the desired output!
wmt_loader:
Apr 5 21:40:00 kernel: [ 120.199400] [WMT-DETECT][I]wmt_detect_open:open major 154 minor 0 (pid 1448)
Apr 5 21:40:00 kernel: [ 120.199472] [WMT-DETECT][I]wmt_detect_unlocked_ioctl:cmd (-2147191037),arg(0)
Apr 5 21:40:00 kernel: [ 120.199513] [WMT-DETECT][I]wmt_detect_unlocked_ioctl:cmd (1074034433),arg(30243)
Apr 5 21:40:00 kernel: [ 120.199525] set current consys chipid (0x7623)
Apr 5 21:40:00 kernel: [ 120.199551] [WMT-DETECT][I]wmt_detect_unlocked_ioctl:cmd (-2147191036),arg(30243)
Apr 5 21:40:00 kernel: [ 120.199563] [WMT-MOD-INIT][I]do_common_drv_init:start to do common driver init, chipid:0x00007623
Apr 5 21:40:00 kernel: [ 120.203188] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6620.defAnt'.
Apr 5 21:40:00 kernel: [ 120.203217] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6628.defAnt'.
Apr 5 21:40:00 kernel: [ 120.203228] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6630.defAnt'.
Apr 5 21:40:00 kernel: [ 120.205824] [WMT-MOD-INIT][I]do_common_drv_init:finish common driver init
Apr 5 21:40:00 kernel: [ 120.205847] [WCN-MOD-INIT][E]do_connectivity_driver_init(58):do common driver init failed, ret:-1
Apr 5 21:40:00 kernel: [ 120.205860] [WLAN-MOD-INIT][I]do_wlan_drv_init:CONFIG_MTK_COMBO_WIFI is not defined
Apr 5 21:40:00 kernel: [ 120.206235] [WMT-DETECT][I]wmt_detect_close:close major 154 minor 0 (pid 1448)
stp_uart_launcher -p /etc/firmware &:
Apr 5 21:42:12 kernel: [ 251.817813] [WMT-CORE][E]opfunc_hif_conf(874):WMT-CORE: WMT HIF info added
Apr 5 21:42:12 kernel: [ 251.818194] vcn18: mode operation not allowed
Apr 5 21:42:12 kernel: [ 251.819983] [WMT-CONSYS-HW][E]mtk_wcn_consys_hw_reg_ctrl(290):Read CONSYS chipId(0xfffff093)
Apr 5 21:42:12 kernel: [ 251.919991] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6620.defAnt'.
Apr 5 21:42:12 kernel: [ 251.920016] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6628.defAnt'.
Apr 5 21:42:12 kernel: [ 251.920027] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6630.defAnt'.
Apr 5 21:42:13 kernel: [ 252.474378] [STP] mtk_wcn_stp_psm_enable:[W] STP Not Ready, Dont do Sleep/Wakeup
modprobe stp_chrdev_bt:
Apr 5 21:43:44 kernel: [ 344.356686] [MTK-BT] BT_init: mtk_stp_BT_chrdev driver(major 192) installed
Apr 5 21:43:45 kernel: [ 344.694820] mtk_bt_hci_notify event(3)=HCI_NOTIFY_VOICE_SETTING
Apr 5 21:43:45 kernel: [ 344.739772] hci_reassembly: this workaround is applied for mediatek BT
Apr 5 21:43:45 kernel: [ 344.758592] mtk_bt_hci_flush: todo
modprobe wmt_chrdev_wifi:
Apr 5 21:44:23 kernel: [ 382.562824] [MTK-WIFI] WIFI_init: mtk_wmt_WIFI_chrdev driver(major 155) installed.
modprobe wlan_gen2
echo A > /dev/wmtWifi:
Apr 5 21:46:05 kernel: [ 485.079938] [MTK-WIFI] WIFI_open: WIFI_open: major 155 minor 0 (pid 1439)
Apr 5 21:46:05 kernel: [ 485.080086] [MTK-WIFI] WIFI_write: WIFI_write A
Apr 5 21:46:05 kernel: [ 485.124018] kalFirmwareImageMapping firmware size 225840
Apr 5 21:46:06 kernel: [ 486.309670] DEBUG: Passed wlanNetRegister 2264 devname:wlan%d
Apr 5 21:46:06 kernel: [ 486.310728] DEBUG: Passed wlanNetRegister 2273 devname:wlan0 (need to be used everywhere "wlan0" is used)
Apr 5 21:46:06 kernel: [ 486.310770] [MTK-WIFI] register_set_p2p_mode_handler: (pid 1451) register set p2p mode handler 9f5eac37
Apr 5 21:46:06 kernel: [ 486.310884] [MTK-WIFI] WIFI_write: WMT turn on WIFI success!
Apr 5 21:46:06 kernel: [ 486.310911] DEBUG: Passed WIFI_write 483 wlan0
Apr 5 21:46:06 kernel: [ 486.311129] DEBUG: Passed p2pNetRegister 1111,devname: ap%d
Apr 5 21:46:06 kernel: [ 486.312197] [MTK-WIFI] WIFI_write: Set wlan mode 0 --> 1
Apr 5 21:46:06 kernel: [ 486.312228] [MTK-WIFI] WIFI_write: WIFI_write
Apr 5 21:46:06 kernel: [ 486.312248] [MTK-WIFI] WIFI_write: WIFI_write invalid param
Apr 5 21:46:06 kernel: [ 486.312363] [MTK-WIFI] WIFI_close: WIFI_close: major 155 minor 0 (pid 1439)
âwlan0â and âap0â are now there.
modprobe mt76 modprobe mt7615e
âwlan1â is now also there.
Hostapd works on both.
However doing âecho 0 /dev/wmtWifiâ crashes the OS. I guess the driver is rly unstable
Last output I got:
Apr 5 21:53:55 kernel: [ 922.873786] [MTK-WIFI] WIFI_open: WIFI_open: major 155 minor 0 (pid 1439)
Apr 5 21:53:55 kernel: [ 922.873900] [MTK-WIFI] WIFI_write: WIFI_write 0
Apr 5 21:53:55 kernel: [ 944.769433] rcu: INFO: rcu_sched detected stalls on CPUs/tasks:
Apr 5 21:53:55 kernel: [ 944.769461] rcu: 0-...0: (4 ticks this GP) idle=9b2/1/0x40000000 softirq=2220/2222 fqs=1042
Apr 5 21:53:55 kernel: [ 944.769485] (detected by 3, t=2102 jiffies, g=3061, q=149)
Apr 5 21:53:55 kernel: [ 944.769498] Sending NMI from CPU 3 to CPUs 0:
Thank you very much @frank-w
A small update: The module âstp_chrdev_btâ doesnât have to be loaded for wifi to work, everything works still even with that module not loaded; Found that out by accident
Chrdev_bt is for bluetoothâŚdoes this break wifi?
For âcrashâ (it is rcu-stall,hanging process),do you use any cmdline param like net.ifnames=0 ? Or any other network-manager?
Hostap works on wlan0?
No it does not.
No network manager, I just use ip with my start script to asign ip addresses. . And no cmdline params like ânet.ifname=0â.
I never tried that, as I thought that wouldnât work from what I gathered from all the random posts, I thought that is why âap0â exists.
Ah, you have mt7615 and hostapd works on ap0 and device from mt7615âŚ
So we have now the rcu stall (when does this came up)? Maybe because mt7615 (see my patches for getting mt6625 wlan-device).
But it looks like you have the patch (or at least the debug lines) alreadyâŚ
And the crash on âecho 0â right (maybe same)? Any more info on this crash? Based on commit above you can add some debug-lines in the 0-block to trace this down (printks after each functional line like my prinktks)
Is also strange,seems like printed some lines above when count is <=0
Iâm currently using your 5.12-hnat branch kernel, I donât know what patches you already inserted there, so you would have to tell me
As to the devices:
mt6625 (internal module) is âwlan0â and âap0â
mt7615 (PCIe card) is âwlan1â
I have two hostapd instances running one on âap0â (internal module) and one on âwlan1â (PCIe card).
The stall happens while both cards are active (meaing they coexist in the system) and I want to disable the internal module with âecho 0 > /dev/wmtWifiâ. Basically I enter âecho 0 > /dev/wmtWifiâ and press ENTER and right after I press ENTER the stall happens. The whole system hangs and I have to RESET the system.
The lines I got are because I have âlogread -fâ running on another terminal.
I hope I could make myself understood Iâm sorry Iâm just bad at this
5.12-hnat contains the latest patches for mt6625
try adding this to 5.12-hnat:rcu_debug_on_reset.patch (2,5 KB)
i guess the problem is pf_set_p2p_mode (line 374 will be printed last, no 376)âŚthat was the problem i tried to fix with get_netdev(); function. in origin code the netdev was fixed to wlan0 but if you have another wifi-card this may differ, running pf_set_p2p_mode on wrong netdev resulted in hang. so please look if the right netdev is printed in 365. if this is correct and we know the location here, we have to dig deeperâŚafair rcu-stall results from unreleased lock, but this i had not found (all exits goto âdoneâ where this lock wr_mtx is released correctly, but afair there was a semaphore in pf_set_p2p_mode or later). Maybe it is because of you load mt7615 driver laterâŚimho i use last wifi-device as i guess last is created by this driver
btw. to prevent filesystem-problems you can boot into init-ramdisk
for this you need to add buildroot-initrd and build.sh (+conf for module filter) from 5.10-main (need to be commited because initrd is resetted first in mod2initrd)
git checkout 5.10-main -- build.sh build.conf utils/buildroot/rootfs_bpi-r2.cpio.gz
git commit -m "build.sh: add initrd"
after building do not install and run â./build.sh mod2initrdâ this should run install-choice too and installs kernel with the initrd
Ok applied the patch and this time I had to poweroff the device and added my UART debug USB device.
This time I can do âecho 0 > /dev/wmtWifiâ and the system just hangs here and there with NO OUTPUT anywhere. Nothing in syslog, dmesg, debug UART, nothing. The only thing that happens is that the terminal where I typed it in is now âsoft lockedâ as in I canât do âCTRL+Câ to do a sigterm.
You have to disable line in wifi.sh which prevents log to console (dmesg -D,printk line)âŚi guessed you did it because you see the stall message.
If you still do not see anything the hang occours before wifi-write function (or at least before my first printk)âŚbut the print with âWIFI_write: 0â is 2 lines before my first printkâŚnothing that can hang
Oh I donât use your âwifi.shâ file I wrote my own No information is left out here. Alpine uses openRC not systemd so I wrote my own service.
The few debug lines that are now new would be when it initilizes:
Jan 1 00:00:43 kernel: [ 29.485992] DEBUG: Passed wlanNetRegister 2264 devname:wlan%d
Jan 1 00:00:43 kernel: [ 29.487019] DEBUG: Passed wlanNetRegister 2273 devname:wlan0 (need to be used everywhere "wlan0" is used)
and
Jan 1 00:00:43 kernel: [ 29.487195] DEBUG: Passed WIFI_write 496 wlan0
Jan 1 00:00:43 kernel: [ 29.487397] DEBUG: Passed p2pNetRegister 1111,devname: ap%d
Sadly there is really no output after I type âecho 0 > /dev/wmtWifiâ
the first 2 were already there in your previous log and there you have posted this:
Apr 5 21:53:55 kernel: [ 922.873900] [MTK-WIFI] WIFI_write: WIFI_write 0 <<< this is already wifi_write function, 2 lines before my first printk
i wonder why the âwifi-write: 0â line does not occour now
WIFI_INFO_FUNC("WIFI_write %s\n", local);
can you test without the mt7615-card? or at least do not load the module for now
my wifi.sh does not depend on systemdâŚit is a basic bash-script
Yes youâre right just wanted to mention that I wrote my own service so it would funtion properly in OpenRC. I really canât report to you more than what there is, which in this case really is nothing
Yes I will test without.
