BPI-R1_OpenWrt_V4.0
MD5: CB597EE79A6E27630AD7F903D23C4A7B
http://pan.baidu.com/s/1mg8Gjna
https://drive.google.com/file/d/0B3EGHv0FSPOGeHJNdmVXS3UtMUU/view?usp=sharing
BPI-R1_OpenWrt_V4.0
Hi! Whatâs new? Is there any changelog to read? I cannot see a thread on the forum, too.
Regards,
Hi, I can not access to OpenWRT with IP address 192.168.1.1 Is this correct address or itâs changed?
Regards.
you must configure the first without wan connection OpenWR. and the IP to 192.168.3.1 if you have multiple routers
Give your knowledge further
OK, but I can not access to OpenWRT on address 192.168.1.1 if this default address. DHCP not work on any port by default and i was tried with lot of different addresses on my PC (10.0.0.10, 10.0.1.10, 192.168.1.10âŚ) and can not access to OpentWRT.
Do you see a WiFi connection? If so you can connect via WiFi and then enter the router setup.
No, WiFi didnât work by default also, and no DHCP on any port. I was find solution on different way. When i mount this image in linux i discovered that in folder /etc/config not exist file ânetworkâ for network configuration. Iâm copied that file from OpenWRT image from user db260179 and now dhcp work on 4 lan ports and wan also, and i can access to web interface
Great work garcha! Thanks for updating us so new users can see how to make DHCP and WiFi work.
HI, I have the same issue when use the OpenWrt version. Please give more information to resolved the WiFi&LAN issue. Thanks
I want to know how to make DHCP and WiFi work in BPI-R1. Thanks
The answer is simple and applies to all sorts of products here: Do NOT use the âofficialâ OS images. Theyâre broken more or less. if you want OpenWRT choose the version community member db260179 provides (at the bananapi.com forum). If you want Debian go with Armbian or Bananian.
Thanks tkaiser, I get this. but Iâm not sure db260179 provides openwrt image(WiFi working??).
Wi-Fi is broken by design. Only the marketing guys from the manufacturer think Itâs useable.
For the most common problems (and how to partially solve them) have a look at the pinned threads here http://forum.armbian.com/index.php/forum/7-allwinner-a10a20/ and here http://forum.armbian.com/index.php/topic/372-hardware-mod-bpi-r1/
hello everyone OpenWrt 4.0 not work dhcp server and openvrt what are problems?
Hi is there GPIO on Banana Pi R1 available with openWRT?
wiringPi Ohr any other stuff?
Greetings Elluminatus
Can nobody help me?
we not test wiringpi on openwrt;
but you can reference below:
https://bananapi.gitbooks.io/bpi-r1/content/en/bpi-r1wiringpi.html
i found a new image of openwrt 4.0 that has a ton of stuff fixed. it took me days to find this information. so here is a link to the firmware i used.
https://bananapi.gitbooks.io/bpi-r1/content/en/davidbethamopenwrt-bpir1prebuilt.html
https://drive.google.com/file/d/0B6IsHEp4ZveFeHhFdExFZ0hPOFE/view?usp=sharing
these are the images i used enjoy
Maybe because @sinovoip forgets to send users to linux-sunxi wiki? There all relevant information including link to the working OpenWRT image from David is present since ages: http://linux-sunxi.org/Lamobo_R1#Images
