BPi-R1 new image: raspbian-lite-bpi-m1-m1p-r1.img 2016-07-12
2016-07-12-raspbian-lite-bpi-m1-m1p-r1.img.zip
  1. based on RASPBIAN JESSIE LITE 2016-05-27(support rpi3 rpi2 rpi1)
  2. BPI-M1 / BPI-M1P / BPI-R1 u-boot-2016.05, kernel 3.4.112 (based on armbian’s build)
  3. username & password: pi/bananapi , root/bananapi
  4. support HDMI 1080P & 720P(default)
  5. support GMAC
  6. support WIFI
  7. support SATA
  8. support bpi-bootsel cmd can switch to (bpi-m64 & bpi-m3 & bpi-m2 & bpi-m2p & bpi-m1-m1p-r1)
  9. support boot.scr (boot.cmd) to fatload script.bin & uImage & uInitrd
  10. support boot.scr to set video 1080P & 720P & 480P …
  11. based on armbian’s build env. & rootfs, thanks for armbian (http://www.armbian.com)
  12. github from GitHub - armbian/build: Armbian Linux build framework generates custom Debian or Ubuntu image for x86, aarch64, riscv64 & armhf by armbian’s work
  13. special thanks for linux-sunxi’s work (https://linux-sunxi.org)
  14. thanks for raspberry.org’s work(https://www.raspberrypi.org/downloads/raspbian)
Google Drive: https://drive.google.com/file/d/0B_YnvHgh2rwjRXRuWHJ5V3BJTmc/view?usp=sharing
MD5: 302063f7417079390da79334258dd538
The Google drive link does not work anymore. If anyone can please share it, it would be great! Thank you Or where can I get the latest version of Raspbian Lite for Bpi-M1+
Several classes better: https://www.armbian.com/download/?tx_maker=sinovoip
Nightly update includes also this latest major fix:
I need this image. but google drive link is dead here is baidu link: http://pan.baidu.com/s/1jIjkOJW buh i am unable to download it because baidui requires chinese telephone number.
Please re-activate google drive link.
thanks in advance
Why … if you have much better option?
because respberian lite version is best suitable for my project. if you have this lite version for m1, can you share the image with me?
thanks.
Raspberian Lite is Debian ported to RPi. Armbian is Debian designed for M1 and similar computer. Armbian is best suited for any project on your board. There is no Raspberian Lite for this board. Rpi foundation is not making it for anything else then Rpi. Hardware features are different which means none of them will work out of the box.
This is your best (and only) option.
Can you please re-upload the link? The link is not working and I want to test out your Raspbian images! If you want to re-upload it, could you please upload it in Google Drive/mediafire/mega.nz?
Thank you in advance!
mhog
I am very thinks fou you that you can share this.
