BPI-R1_Debian_8_Docker_hdmi
MD5:0e3349ea78e790382461a538264b569d
https://drive.google.com/file/d/0B3EGHv0FSPOGSXVIaUVaRDBldE0/view
Release Note:
1,Support BPI-R1
2,uboot : 2015-7
3,linux kernel: 4.2.
4,ethernet work fine
5,WIFI driver work fine
6,user name/pass: pi/bananapi
7,this is just a test version.
running:
                torstenx1
                (Torsten)
                    November 18, 2015, 10:14am
              2
              I have do this.
It works fine with docker exept Network.
Can you please show how setup on Debian and Openwrt side.
Perhapst the right settings for config files on both systems.
OpenWRT :
/ # ifconfig
eth0      Link encap:Ethernet  HWaddr 02:42:AC:11:00:01
          inet addr:172.17.0.1  Bcast:0.0.0.0  Mask:255.255.0.0
          inet6 addr: fe80::42:acff:fe11:1/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:109 errors:0 dropped:0 overruns:0 frame:0
          TX packets:103 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:10560 (10.3 KiB)  TX bytes:8802 (8.5 KiB)
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
Debian :
docker0   Link encap:Ethernet  Hardware Adresse 5e:c2:49:a1:15:1b
          inet Adresse:172.17.42.1  Bcast:0.0.0.0  Maske:255.255.0.0
          inet6-Adresse: fe80::5cc2:49ff:fea1:151b/64 Gültigkeitsbereich:Verbindung
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metrik:1
          RX packets:194 errors:0 dropped:0 overruns:0 frame:0
          TX packets:194 errors:0 dropped:0 overruns:0 carrier:0
          Kollisionen:0 Sendewarteschlangenlänge:0
          RX bytes:13940 (13.6 KiB)  TX bytes:18954 (18.5 KiB)
eth0      Link encap:Ethernet  Hardware Adresse 02:99:04:43:33:02
          inet Adresse:192.168.2.209  Bcast:192.168.2.255  Maske:255.255.255.0
          inet6-Adresse: fd5b:4d92:9c66:0:99:4ff:fe43:3302/64 Gültigkeitsbereich:Global
          inet6-Adresse: fe80::99:4ff:fe43:3302/64 Gültigkeitsbereich:Verbindung
          RX packets:4415 errors:0 dropped:0 overruns:0 frame:0
          TX packets:2399 errors:0 dropped:0 overruns:0 carrier:0
          Kollisionen:0 Sendewarteschlangenlänge:1000
          RX bytes:374123 (365.3 KiB)  TX bytes:801452 (782.6 KiB)
          Interrupt:47
lo        Link encap:Lokale Schleife
          inet Adresse:127.0.0.1  Maske:255.0.0.0
          inet6-Adresse: ::1/128 Gültigkeitsbereich:Maschine
          UP LOOPBACK RUNNING  MTU:65536  Metrik:1
veth74bcedc Link encap:Ethernet  Hardware Adresse 5e:c2:49:a1:15:1b
          TX packets:200 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:16656 (16.2 KiB)  TX bytes:19518 (19.0 KiB)
wlan3     Link encap:Ethernet  Hardware Adresse ac:a2:13:c0:c6:6b
          UP BROADCAST MULTICAST  MTU:1500  Metrik:1
