Hi is there any way to use I2S or analog audio (mic in and speaker output) on the P2 board
I want to use BPI P2 to make camera intercom powered using POE but not when I got the board I see that there is no audio connectivity
Hello, P2 doesn’t have I2s on 40pin but Pcm pins instead.
http://wiki.banana-pi.org/Banana_Pi_BPI-P2_Zero#GPIO_PIN_define
Here is the datasheet of PA18-PA21, you could config these pins in sys_config.fex in bsp code:
the gpio function as you can see is “function2”
