BPI-M3 new image:Armbian v4.70 / 30.11.2015 for BPI-M3
(bpi team) #1
  1. BPI-M3 kernel 3.4
  2. root/bananapi
  3. support HDMI 1080P & 720P
  4. support eMMC
  5. support GMAC
  6. support WIFI
  7. support SATA
  8. support bpi-bootsel cmd to switch mode
download link:
google drive
baidu cloud password: 1l88
MD5: 110f29c44140d67fe7ffc3b8b73f3483
#2
If it’s really from “30.11.2015” it doesn’t contain latest fixes: https://github.com/BPI-SINOVOIP/BPI-M3-bsp/commits/master
#3
Just as a warning: This is NOT an Armbian image but just the combination of outdated kernel/u-boot stuff with an Armbian rootfs where most things don’t work as expected. And it’s not worth the time to try out.
http://forum.armbian.com/index.php/topic/474-quick-review-of-banana-pi-m3/?p=3023
(Yoshihito Horigome) #4
/bin/systemd not enabled, such as it is, or what settings are required?
(Alexandr) #5
How to make work WiFi? BPI M3 Armbian
uname -a
Linux BPIodincM3 4.19.20-sunxi #5.75 SMP Sun Feb 10 21:36:17 CET 2019 armv7l GNU/Linux
(Igor) #6
I am not 100% sure but I think its fixed in 4.20.y (DEV) kernel.
(Alexandr) #7
Where I can get 4.20 kernel?
(Igor) #8
armbian-config -> alternative kernel (if you are using official Armbian, don’t know for 3rd party Armbian builds)
(Alexandr) #9
Thanx for answer! It did not help…
uname -a
Linux BPIodincM3 4.20.7-sunxi #5.75 SMP Fri Feb 8 09:02:10 CET 2019 armv7l GNU/Linux
lshw -c network
  *-network:0
       description: Ethernet interface
       physical id: 2
       logical name: eth0
       serial: 02:01:14:5f:08:07
       capacity: 1Gbit/s
       capabilities: ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=st_mac100 driverversion=Jan_2016 duplex=full ip=192.168.1.157 link=yes multicast=yes port=MII speed=100Mbit/s
  *-network:1 DISABLED
       physical id: 3
       logical name: dummy0
       serial: a2:a5:80:1c:98:27
       configuration: broadcast=yes driver=dummy driverversion=1.0
(Mahipal Nehra) #10
Great Configuration !! I liked it. I will use it for my web application development company.
Thanks,
