[BPI-M3 ]How to burn linux images to eMMC Storage on your BPI-M3
OS: BPI-M3 Ubuntu15.10 (Kernel3.4) Version: 1.0 HDMI
Step 1: Start up the computer with the SD card which has been burnt with the Linux images.
Step 2: Put the images which you’d like to burn to the eMMC Storage to the USB drive.
Step 3: Run “fdisk -l” command line on your BPI-M3 and you can see the eMMC path as " /dev/mmcblk1"
sudo fdisk -l
Step 4:Switch to the path of images, and run the command. > sudo dd if=ubuntu-mate-15.10-desktop-armhf-raspberry-pi-2-bpi-m3-sd-emmc-20151203.img of=/dev/mmcblk1 bs=10MB
Step 5:When finish burning, remove the SD card, and restart the BPI-M3
Step 6:Check if the system starts normally on the eMMC boot
Video Demo on youbube:
Successfully burned Fedora to the eMMC! Thanks!
Finally ! Such a so complicated step to see that this board is really boring.
The new raspberry 3 wifi/bluetooth will kill this board without any surprise…for just 35 USD!
Sorry for bringing old threats to life, but it may be useful for someone: I just cloned my running ubuntu from the SD (8GB) to the eMMC:
sudo dd if=/dev/mmcblk0 of=/dev/mmcblk1 bs=10MB status=progress
Then sudo poweroff, remove the SD, power it on again, and it just boots…
You shoudn’t clone an alive OS, but it does the work quickly! Good luck
