Hello, My bpi m3 dram only show 1gb using the V5 image android 5.1.1. The original h9ccnnn8jtml that came with board was dead. I replace with new h9ccnnnjtal version. It boot up ok. But now i see the ram size only 1gb not 2gb. Can someone tell me what this mean? Wrong dram chip or cpu also dead??
are you try othe image ,and show same ???
please download newest image and test again
yes, i use new image and re-burn using phoenixsuit still no go. ram is 1gb.
boot dump from serial is below, please see.
[ 9.290587] SysRq : Emergency Remount R/O
[00][00]HELLO! BOOT0 is starting!
boot0 version : 4.0.0
rtc[1] value = 0x00010000
rtc[2] value = 0x00020000
rtc[3] value = 0x00030000
DRAM DRIVE INFO: V1.1
DRAM Type =7 (2:DDR2,3:DDR3,6:LPDDR2,7:LPDDR3)
DRAM normal_mode value: 00000001
DRAM CLK =672 MHZ
rsb_send_initseq: rsb clk 400Khz -> 3Mhz
PMU: AXP81X
ddr voltage = 1200 mv
ID CHECK VERSION: V0.2
using ic A83T
using axp AXP813
DRAM zq value: 00003bfb
dram size =1024
card boot number = 2
card no is 2
sdcard 2 line count 8
[mmc]: mmc driver ver 2015-04-13 16:05:39
[mmc]: ***Try SD card 2***
[mmc]: mmc 2 cmd 8 err 00000100
[mmc]: mmc 2 send if cond failed
[mmc]: mmc 2 cmd 55 err 00000100
[mmc]: mmc 2 send app cmd failed
[mmc]: ***Try MMC card 2***
[mmc]: mmc re-update_phase
[mmc]: 8bit ddr!!!
[mmc]: MMC ver 5.0
[mmc]: SD/MMC Card: 8bit, capacity: 7456MB
[mmc]: vendor: Man 00150100 Snr 0184364a
[mmc]: product: 8WMB3
[mmc]: revision: 5.2
[mmc]: ***SD/MMC 2 init OK!!!***
sdcard 2 init ok
The size of uboot is 000d4000.
sum=388d6332
src_sum=388d6332
set_mmc_para,sdly 50M 0
set_mmc_para,sdly 25M 0
Succeed in loading uboot from sdmmc flash.
Ready to disable icache.
Jump to secend Boot.
normal mode
[ 0.208]
U-Boot 2011.09-rc1-00000-gcf25114-dirty (Dec 09 2016 - 18:08:08) Allwinner Technology
[ 0.217]version: 2.1.0
normal mode
[ 0.295]pmbus: normal or secure os
ready
[ 0.299]PMU: AXP81X
[ 0.301]PMU: AXP81X found
BPI-M3:Set Uboot-[AXP81X]-Power
bat_vol=4354, ratio=100
[ 0.310]PMU: dcdc2 900
[ 0.312]PMU: pll1 1008 Mhz
AXI0=336 Mhz,PLL_PERIPH =1200 Mhz AHB1=200 Mhz, APB1=100 Mhz
set power on vol to default
dcdc1_vol = 3300, onoff=1
dcdc2_vol = 900, onoff=1
dcdc3_vol = 900, onoff=1
dcdc4_vol = 900, onoff=1
dcdc6_vol = 900, onoff=1
aldo1_vol = 1800, onoff=0
aldo2_vol = 1800, onoff=1
aldo3_vol = 3000, onoff=1
eldo2_vol = 1800, onoff=0
dldo1_vol = 3300, onoff=0
dldo2_vol = 3300, onoff=0
dldo3_vol = 2500, onoff=1
dldo4_vol = 2800, onoff=0
fldo2_vol = 900, onoff=1
gpio0_vol = 3300, onoff=1
gpio1_vol = 3300, onoff=1
find power_sply to end
supply=dcdc1
axp=axp81x, supply=dcdc1, vol=3300
reg addr=0x1c20b04, value=0xd, pmu_vol=3300
supply=dcdc1
reg addr=0x1c20b08, value=0xd, pmu_vol=3300
supply=dldo3
axp=axp81x, supply=dldo3, vol=1800
reg addr=0x1c20b0c, value=0x0, pmu_vol=1800
supply=dcdc1
reg addr=0x1c20b10, value=0xd, pmu_vol=3300
supply=dcdc1
reg addr=0x1c20b14, value=0xd, pmu_vol=3300
supply=dcdc1
reg addr=0x1c20b18, value=0xd, pmu_vol=3300
supply=dcdc1
reg addr=0x1c20b1c, value=0xd, pmu_vol=3300
supply=aldo3
axp=axp81x, supply=aldo3, vol=3000
reg addr=0x1f02f00, value=0xa, pmu_vol=3000
config gpio bias voltage finish
vbus exist
ac100 reg 0x00 = 0x101
ac100 reg 0xd0 = 0x0
ac100 reg 0xd1 = 0x0
__446__:(board.c:power_source_init)
[AXP81X]:[00]=[FC]
[AXP81X]:[01]=[30]
[AXP81X]:[02]=[02]
[AXP81X]:[03]=[51]
[AXP81X]:[04]=[00]
[AXP81X]:[05]=[00]
[AXP81X]:[06]=[00]
[AXP81X]:[07]=[00]
[AXP81X]:[08]=[00]
[AXP81X]:[09]=[00]
[AXP81X]:[0A]=[00]
[AXP81X]:[0B]=[00]
[AXP81X]:[0C]=[00]
[AXP81X]:[0D]=[00]
[AXP81X]:[0E]=[00]
[AXP81X]:[0F]=[0E]
[AXP81X]:[10]=[3F]
[AXP81X]:[11]=[00]
[AXP81X]:[12]=[20]
[AXP81X]:[13]=[C8]
[AXP81X]:[14]=[08]
[AXP81X]:[15]=[1A]
[AXP81X]:[16]=[1A]
[AXP81X]:[17]=[0B]
[AXP81X]:[18]=[15]
[AXP81X]:[19]=[00]
[AXP81X]:[1A]=[16]
[AXP81X]:[1B]=[00]
[AXP81X]:[1C]=[0B]
[AXP81X]:[1D]=[04]
[AXP81X]:[1E]=[00]
[AXP81X]:[1F]=[00]
[AXP81X]:[20]=[11]
[AXP81X]:[21]=[A8]
[AXP81X]:[22]=[A8]
[AXP81X]:[23]=[A8]
[AXP81X]:[24]=[A4]
[AXP81X]:[25]=[9E]
[AXP81X]:[26]=[A8]
[AXP81X]:[27]=[FC]
[AXP81X]:[28]=[0B]
[AXP81X]:[29]=[0B]
[AXP81X]:[2A]=[17]
[AXP81X]:[2B]=[00]
[AXP81X]:[2C]=[00]
[AXP81X]:[2D]=[B0]
[AXP81X]:[2E]=[40]
[AXP81X]:[2F]=[00]
[AXP81X]:[30]=[20]
[AXP81X]:[31]=[03]
[AXP81X]:[32]=[43]
[AXP81X]:[33]=[C8]
[AXP81X]:[34]=[C7]
[AXP81X]:[35]=[83]
[AXP81X]:[36]=[58]
[AXP81X]:[37]=[00]
[AXP81X]:[38]=[A5]
[AXP81X]:[39]=[1F]
[AXP81X]:[3A]=[85]
[AXP81X]:[3B]=[08]
[AXP81X]:[3C]=[FC]
[AXP81X]:[3D]=[16]
[AXP81X]:[3E]=[7C]
limit to 900
fel key old mode
run key detect
no key found
no key input
dram_para_set start
dram_para_set end
[ 0.657]DRAM: 1 GiB
relocation Offset is: 35af9000
user_gpio config
user_gpio ok
gic: normal or no secure os mode
script config pll_de to 504 Mhz
script config pll_video1 to 297 Mhz
Not Found clk pll_video in script
enable power vcc-hdmi-18, ret=0
DRV_DISP_Init end
[ 0.895]boot_disp.output_disp=1
[ 0.899]boot_disp.output_type=3
[ 0.902]boot_disp.output_mode=5
[ 0.905]fetch script data boot_disp.auto_hpd fail
disp1 device type(4) enable
attched ok, mgr1<-->device1, type=4, mode=5----
ready to set mode
workmode = 0
MMC: 2
[ 0.940][mmc]: mmc driver ver 2015-04-13 14:50:00
[ 0.945][mmc]: get sdc_phy_wipe fail.
[ 0.949][mmc]: get sdc0 sdc_erase fail.
[ 0.953][mmc]: get sdc_2xmode ok, val = 1
[ 0.957][mmc]: get sdc_ddrmode ok, val = 1
[ 0.961][mmc]: get sdc_f_max fail,use default 50000000Hz
[ 0.967][mmc]: get card_line ok, card_line = 8
[ 0.971][mmc]: get sdc_ex_dly_used fail,use default
[ 0.976][mmc]: SUNXI SD/MMC: 2
[ 0.990][mmc]: *Try SD card 2*
[ 0.993][mmc]: mmc 2 cmd 8 err 100
[ 0.999][mmc]: mmc send if cond failed
[ 1.003][mmc]: mmc 2 cmd 55 err 100
[ 1.008][mmc]: send app cmd failed
[ 1.011][mmc]: *Try MMC card 2*
[ 1.053][mmc]: mmc re-update_phase
[ 1.058][mmc]: mmc re-update_phase
[ 1.063][mmc]: mmc re-update_phase
[ 1.068][mmc]: ddr8
[ 1.070][mmc]: mmc re-update_phase
[ 1.083][mmc]: CID 0x15010038 0x574d4233 0x52018436 0x4adac18b
[ 1.088][mmc]: MMC ver 5.0
[ 1.091][mmc]: mmc clk 50000000
[ 1.094][mmc]: SD/MMC Card: 8bit, capacity: 7456MB
[ 1.099][mmc]: boot0 capacity: 4000KB,boot1 capacity: 4000KB
[ 1.105][mmc]: ***SD/MMC 2 init OK!!!***
[ 1.110][mmc]: erase_grp_size:0x400WrBlk * 0x200 = 0x80000 Byte
[ 1.116][mmc]: secure_feature 0x55
[ 1.119][mmc]: secure_removal_type 0x9
[ 1.123]sunxi flash init ok
the secure storage map is empty
no item name key_burned_flag in the map
sunxi secure storage has no flag
[ 1.137]usb burn from boot
delay time 0
[ 1.208]usb prepare ok
usb sof ok
vbus pc exist ,limit to pc
[ 1.509]usb probe ok
[ 1.512]usb setup ok
set address 0x1
[ 4.514]timer occur
[ 4.549]do_burn_from_boot usb : have no handshake
In: serial
Out: serial
Err: serial
--------fastboot partitions--------
-total partitions:11-
-name- -start- -size-
bootloader : 1000000 1000000
env : 2000000 1000000
boot : 3000000 1000000
system : 4000000 60000000
misc : 64000000 1000000
recovery : 65000000 2000000
cache : 67000000 30000000
metadata : 97000000 1000000
private : 98000000 1000000
alog : 99000000 5000000
UDISK : 9e000000 0
base bootcmd=run setargs_nand boot_normal
bootcmd set setargs_mmc
key 0
recovery key high 10, low 8
cant find fstbt value
misc partition found
to be run cmd=run setargs_mmc boot_normal
** Unable to use sunxi_flash 8:0 for fatload **
load file(sn.txt) error
serial is: 00000000000000000000
mount part name bootloader
cant open script.bin, maybe it is not exist
WORK_MODE_BOOT
board_status_probe
[ 4.652]pre sys mode
sunxi_bmp_logo_display
[ 4.690][mmc]: blkcnt should not be 0
[ 4.709]fetch script data boot_disp.output_disp fail
[ 4.714]screen_id =1, screen_width =1280, screen_height =720
[ 4.720]frame buffer address 46400000
[ 4.724]Hit any key to stop autoboot: 0
read boot or recovery all
[ 4.900]sunxi flash read :offset 3000000, 14659324 bytes OK
[ 4.913]ready to boot
[ 4.915][mmc]: mmc exit start
[ 4.927][mmc]: mmc 2 cmd 8 err 100
[ 4.932][mmc]: mmc send if cond failed
[ 4.936][mmc]: mmc 2 cmd 55 err 100
[ 4.941][mmc]: send app cmd failed
[ 4.953][mmc]: get sdc_phy_wipe fail.
[ 4.957][mmc]: get sdc0 sdc_erase fail.
[ 4.961][mmc]: get sdc_2xmode ok, val = 1
[ 4.965][mmc]: get sdc_ddrmode ok, val = 1
[ 4.969][mmc]: get sdc_f_max fail,use default 50000000Hz
[ 4.974][mmc]: get card_line ok, card_line = 8
[ 4.979][mmc]: get sdc_ex_dly_used fail,use default
[ 4.984][mmc]: mmc 2 exit ok
[ 4.987]
Starting kernel ...
[sun8i_fixup]: From boot, get meminfo:
Start: 0x40000000
ion_carveout reserve: 96m 128m
ion_reserve_common: ion reserve: [0x78000000, 0x80000000]!
ion_cma reserve: 120m 176m 512m
ion_reserve_common: ion reserve: [0x75000000, 0x80000000]!
------sun8i_smp_init_ops----37-----
[ 0.250084] CPU4: failed to boot: -22
[ 0.290079] CPU5: failed to boot: -22
[ 0.330056] CPU6: failed to boot: -22
[ 0.370077] CPU7: failed to boot: -22
[ 0.798042] config_pmux_para: script_parser_fetch err.
[ 0.798555] add_sys_pwr_dm: axp81x_aldo2 ldo already alwayson.
[ 0.798876] add_sys_pwr_dm: axp81x_aldo2 ldo already alwayson.
[ 0.798988] add_sys_pwr_dm: axp81x_aldo2 ldo already alwayson.
[ 1.001777] sunxikbd_script_init: key para not found, used default para.
[ 1.039711] sunxi_leds_fetch_sysconfig_para leds is not used in config
[ 1.050657] sunxi_oops: heming add OOPS_INFO_ADDR = -20
[ 1.058824] request gpio failed!
[ 1.347657] init: property_opt_for_mem: start!
[ 1.352909] init: property_opt_for_mem: ro.sf.lcd_density not set, disable adaptive memory function!
[ 1.528172] init: /dev/hw_random not found
[ 1.693570] init: /dev/hw_random not found
shell@android:/ $ [ 3.551614] failed to get normal led pin assign
[ 3.556722] failed to get standby led pin assign
[ 4.334399] init: Warning! Service bootclone needs a SELinux domain defined; please fix!
[ 4.344802] init: Warning! Service precopy needs a SELinux domain defined; please fix!
[ 4.357650] init: property_opt_for_mem: start!
[ 4.363751] init: property_opt_for_mem: width_dp = 800; height_dp = 480; screenSize = 2; bSupport64Bit = 0, g_total_mem = 1003
[ 4.484948] init: Warning! Service pvrsrvctl needs a SELinux domain defined; please fix!
[ 4.505323] init: cannot find '/system/bin/debuggerd64', disabling 'debuggerd64'
[ 4.517929] init: cannot find '/system/bin/install-recovery.sh', disabling 'flash_recovery'
[ 4.537218] android_usb: already disabled
[ 6.098817] init: Warning! Service sensors needs a SELinux domain defined; please fix!
[ 12.416144] init: Warning! Service preinstall needs a SELinux domain defined; please fix!
boot_dump.txt (11.1 KB)
I can see the sn.txt serial file error, is this what problem cause is? do i need to make new serial everytime i re-burn?
again, i try using sd card booting ubuntu mate, still seeing 1gb ram instead of 2gb…what is wrong??
Hello,Did you mean the original ram IC was broken? and you have replaced new one,but the Board doesn’t recognise it,right?
yes, sort of like that. The ram ic was broken, so i solder new one into it. The board can boot fine no problem it look like at least…just the ram size is not 2 gb. Board was send to me in good condition, 2gb ram, but I use in my project and broke the ram. Any advise??
Hello,could you make sure that the ram ic you replaced is 2Gb size? could you provide me the datasheet?
or could use the original same type ram ic ?
ok, i think i made a mistake reading the ram ic number. I read H9CCNNN8JTML, when it was suppose to be H9CCNNNBJTML, the latter is only 1Gb density. I found out today, I will order to replace with the same ram ic and see what happens.
Ok, now I have install new Dram, i can boot and into android using both SD-Card and internal EMMC…I have new problem with the EMMC part.
After I have boot new the 2Gb sdram…using android V5 in internal emmc, after running a while, I begin to get crashing. After android crash, not running anymore…cannot boot. I think i reflow correctly the sdram and not touching the emmc flash chip…
So , I heat the emmc chip again and voila…it boot again…after about running 1.5 hour…it crash again… This problem repeat everytime i reheat the chip, boot, crash and reheat the chip…what is wrong here?? very frustrating problem…
Any idea?? is this hardware problem…or emmc chip defect/broken? or something else is wrong?
