BPI M2U OTG port as normal USB port?
Hello, is it possible to configure the usb otg port as a normal usb port? On the BPI M1, I could modify a file called script.fex, and build script.bin, to do this. Now I am modifying all sys_config.fex files and using bpi-tools to compile everything. But I am not able to make it work. Probably not using the correct settings under the usbc0 section in sys_config.fex.
Thanks, Silvy
You need to edit sun8iw11p1.dtsi or sun8iw11p1-emmc.dtsi for mmc.
Do you have some time to give a clue/instruction ?
Am searching… coming back soon.
