Bpi m2 zero get blue screen 'no signal' and no wifi and no ethernet
Hi!
im hold:
  • bpi m2 zero
  • kingston sd card hc 4 gb, 10 class
  • windows 7 pc
  • 3100mA usb
im do:
  1. format sd card
  2. write image to sd card (im use win32diskimager)
  3. activate boot partition
  4. put sd card in bpi
  5. put hdmi cable
  6. put power usb cable
  7. get blue screen ‘no signal’ on display
  8. connect bpi to ethernet socket on my router
  9. bpi is not found in devices list in router web interface
im also editing wpa_supplicant file, and im get trouble - all chars in edited file replaced to “я” char
my question: how to fix it? how to get work system? tenx
you can see here:
http://wiki.banana-pi.org/Getting_Started_with_M2_Zero
I followed the instructions and got problems:
$ df -h
/dev/sdf1        7,5G          32K  7,5G            1% /media/user/...
$ bpi-copy raspbian.img /dev/sdf1
SRC=raspbian.img
DST=/dev/sdf1
COPYMODE=imagetodisk
imagetodisk
bpi-copy(v1.3.4(github)), bananapi image & disk tools
Usage: bpi-copy [OPTIONS]...
   bpi-copy [ --help | -v | --version ]
   bpi-copy IMGFILE
   bpi-copy IMGDIR
   bpi-copy IMGFILE DEVICE
   bpi-copy DEVICE IMGFILE
Warning: Try to write raspbian.img to BOOTDISK /dev/sdf1
ERROR: This command can only be used by root.
$ sudo bpi-copy raspbian.img /dev/sdf1
SRC=raspbian.img
DST=/dev/sdf1
imagetodisk
   bpi-copy IMGFILE
   bpi-copy IMGDIR
Пн дек 23 20:06:05 MSK 2019
*** start COPY (blue led on ) .....
INFO: /dev/sdf1 NOT THE removable device!! EXIT!!
solution: use 8 gb fdd, win32diskimager and official image. topic close
