Hi, thanks for your work. But my Banana PI M2 Berry wont boot with this images. I tried a lot of sd cards and it doesnt boot. Only the green LED comes on.
Sorry for my english… If I using U3 class card, Androind not booting. (Freezing on green LED status.) I tried use SDHC card class10 and my Banana working. Random maybe, but some experience for you. Have a nice day and thanks author
Have any body installed this image successfully?
and if yes how??
Is there gpu driver in this image ?
Or it is just like the others : missing several drivers, which are present not working properly and stuff like that.
i tried a lot of SD Cards. Sandisk Extreme, Intenso, Toshiba and so on. Nothing worked, but then i took a cheap Qumox 32 GB SDHC and it runs very great, stable and fast. Play Store is in Image too and works without Error’s. I hope this helps somebody.
Hi I tried it but my screen is flickering continuously? Its resolution is 1080/1920 60. setting in android is same. UBUNTU has no issue with same setup.
I’m using it on an m2 ultra hdmi out to a 24" tv. Installed kodi, I get minor flickers but everything seems to be working well. You can’t install to an SD, it has to be burned to emmc.
Bonjour
I installed Android 6 (version present in the download) for LCD7. I connected a 7 “screen on the Banana-Pi, I have the display on the screen 7” and another screen connected to the HDMI port. Until all is well, except that my 7 "screen is a touch screen and the touch does not work with this android! Would anyone have the solution to have the touch function?
J’ai installé Android 6 (version présente dans le téléchargement) pour LCD7. J’ai branché un écran 7" sur la Banana-Pi, j’ai l’affichage sur l’ecran 7" ainsi que sur un autre écran branché sur le port HDMI. Jusque la tout va bien, sauf que mon écran 7" est un écran tactile et que le tactile ne fonctionne pas avec cet android! Quelqu’un aurait il la solution pour avoir la fonction tactile?
The Phoenix Card Software, which you mentioned isn’t avaiable for Mac OS…
I tried with dd disk dump via terminal and this HDMI Image, it won’t work on M2 Berry sadly. I have an fast Sandisk SD Card. Any recommendations?
Balea Etcher, which i use normally says there aren’t any partition table. how do you flashed succesfully?
can someone kindly please post the link to the downloadable image file for Android ?
the link in Google drive is not public ! and the link on that other service is Chinese Only!!
I face the same issue on Mac too… I did not have luck with any method under Mac…
Now image copy should act the same on any OS, so I am suspecting the issue is related to the SD Card itself (I figured that size, brand, etc. make a difference) no idea its a trial and error -
can someone assist how to successfully burn the image on Mac and a working image to use for Android ??
the android version works fine, but the battery is always on 0% i just connect to my wifi at home and keep disconnecting, dont know thats problem because the low battery or something wrong with the version, i installed the linux version before the android, there was everything fine with the wifi connection, a solution would be nice, or someone have the same problem or some advice??
