BPI-M2 Ultra/BPI-M2 Berry new image: 2017-11-13-ubuntu-16.04-mate-desktop-beta2-bpi-m2u-sd-emmc.img
(bpi team) #1
2017-11-13-ubuntu-16.04-mate-desktop-beta2-bpi-m2u-sd-emmc.img.zip
  1. based on ubuntu 16.04.3 LTS Mate Desktop
  2. support BPI-M2 Ultra & BPI-M2 Berry kernel 3.10.108 & uInitrd
  3. username & password: pi/bananapi , root/bananapi
  4. support LCD 7" with GT touch
  5. support LCD 5"
  6. support HDMI 1080P & 480P & 720P (default)
  7. support GMAC
  8. support WIFI
  9. support BT (with bluetoothctl can setup)
  10. support SATA
  11. support UART (default set 2 pin mode for /dev/ttyS2)
  12. support I2C (test with bpi_test_lcd1602)
  13. support SPI (test with bpi_test_hello & bpi_test_52pi)
  14. support eMMC (support boot from eMMC)
  15. support Battery (BPI-M2 Ultra only)
  16. support IR (getevent can test, BPI-M2 Ultra only)
  17. support touch screen (can control desktop or getevent to test)
  18. support power key (getevent can test)
  19. support OTG (BPI-M2 Ultra only)
  20. support CAMERA ov5640 (guvcview / cap / ffmpeg-3.1.4 support video H.264 hw encode)
  21. support uEnv.txt to fatload uImage
  22. support bpi-bootsel to set LCD7" / LCD5" / HDMI (720P & 1080P & 480P)
  23. support bpi-copy to write SD/eMMC with img.zip file
  24. support video play 1080p with vdpau (mpv , vlc, smplayer)
  25. support xrdp
  26. support chromium 62.0.3202.75
  27. support wiringpi 2.44 (https://github.com/BPI-SINOVOIP/BPI-WiringPi2 , thanks to http://wiringpi.com/ & https://github.com/WiringPi/WiringPi
  28. support rpi.gpio 0.6.3 for python (https://github.com/BPI-SINOVOIP/RPi.GPIO , thanks to https://sourceforge.net/projects/raspberry-gpio-python/)
  29. Thanks for linux-sunxi community (http://linux-sunxi.org/ )
  30. Special thanks for Daniel Andersen with BPI-M2U-bsp ( https://github.com/dan-and )
  31. Special thanks for Alex support with camera functions ( https://github.com/avafinger )
  32. ref. https://github.com/BPI-SINOVOIP/BPI-M2U-bsp
  33. ref. https://bananapi.gitbooks.io/bpi-m2-ultra-open-source-single-board-computer/content/
Google Drive:
https://drive.google.com/file/d/19PI9yuL9iFa4bU6dh7ym3tcCHhjAh-cM/view?usp=sharing
baidu cloud:
http://pan.baidu.com/s/1nvccOlz
MD5: 4655b896a3c4e1958a15bb8ca45ac4fe
FILESIZE: 1780632239 (~1698MB)
UNPACK: 7296MB (eMMC size)
Banana Pi M2 Berry
(customer) #2
What has changed since your previous release? Why should someone use this release over another? Was something fixed? How about a ChangeLog!!!?!?!
#3
Has anyone tested this build?
I’ve been using the Ubuntu mate image . It’s been OK, but SATA performance is seriously lacking. My M2U decided to crash and go into a boot loop. After turning off for 30 mins it was fine. Have this problem whenever I change to a different ROM, need to wait 30 mins before m2u will stop boot looping. Maybe the voltage issue mentioned here.
Will be looking at moving away from BPI once there is a good alternative with faster SATA performance, stable ROM, and better performance.
(Artem) #4
After manual PowerOff my board doesn’t want to start normally. On the terminal I see this log:
[    7.033536] android_usb gadget: Number of LUNs=3
[    7.044257]  lun0: LUN: removable file: (no medium)
[    7.061390]  lun1: LUN: removable file: (no medium)
[    7.078359]  lun2: LUN: removable file: (no medium)
[    7.097324] android_usb gadget: android_usb ready
[    7.114358] sunxi-rtc rtc: setting system clock to 2010-01-01 00:00:10 UTC (1262304010)
[    7.144089] ALSA device list:
[    7.159256]   #0: audiocodec
[    7.174289]   #1: sndhdmi
[    7.190749] Freeing unused kernel memory: 296K
Loading, please wait...
starting version 229
Begin: Loading essential drivers ... done.
Begin: Running /scripts/init-premount ... done.
Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done.
Begin: Running /scripts/local-premount ... done.
Begin: Will now check root file system ... fsck from util-linux 2.27.1
[/sbin/fsck.ext4 (1) -- /dev/mmcblk0p2] fsck.ext4 -a -C0 /dev/mmcblk0p2
BPI-ROOT contains a file system with errors, check forced.
<1>BPI-ROOT: |=
|  1.3%   <\r><1>BPI-ROOT: |=                                                       /  2.5%   <\r><1>BPI-ROOT:
|==                                                      -  3.8%   <\r><2><1>BPI-ROOT:
|===                                                     \  5.1%   <\r><2><1>BPI-ROOT:
|====                                                    |  6.4%   <\r><1>BPI-ROOT:
|====                                                    /  7.6%   <\r><1>BPI-ROOT:
|=====                                                   -  8.9%   <\r><2><1>BPI-ROOT:
|======                                                  \ 10.2%   <\r><2><1>BPI-ROOT:
|======                                                  | 11.5%   <\r><2><1>BPI-ROOT:
|============                                            / 21.6%   <\r><1>BPI-ROOT:
|=============                                           - 22.9%   <\r><2><1>BPI-ROOT:
|==============                                          \ 24.2%   <\r><2><1>BPI-ROOT:
|==============                                          | 25.5%   <\r><1>BPI-ROOT:
|===============                                         / 26.7%   <\r><2><1>BPI-ROOT:
|================                                        - 28.0%   <\r><2><1>BPI-ROOT:
|================                                        \ 29.3%   <\r><1>BPI-ROOT:
|==================                                      | 31.8%   <\r><2><1>BPI-ROOT:
|===================                                     / 33.1%   <\r><2><1>BPI-ROOT:
|========================                                - 42.0%   <\r><1>BPI-ROOT:
|=========================                               \ 44.5%   <\r><2><1>BPI-ROOT:
|==========================                              | 45.8%   <\r><2><1>BPI-ROOT:
|==========================                              / 47.1%   <\r><2><1>BPI-ROOT:
|===================================                     - 62.4%   <\r><1>BPI-ROOT:
|====================================                    \ 63.6%   <\r><2><1>BPI-ROOT:
|=====================================                   | 66.2%   <\r><2><1>BPI-ROOT:
|=======================================                 / 70.5%   <\r><2><1>BPI-ROOT:
|========================================                - 71.7%   <\r><2><1>BPI-ROOT:
|=========================================               \ 72.5%   <\r><2><1>BPI-ROOT:
=========================================               | 73.8%   <\r><2><1>BPI-ROOT:
|==========================================              / 74.7%   <\r><2><1>BPI-ROOT:
|==========================================              - 75.9%   <\r><2><1>BPI-ROOT:
|===========================================             \ 77.1%   <\r><1>BPI-ROOT:
|============================================            | 78.1%   <\r><2><1>BPI-ROOT:
|============================================            / 79.1%   <\r><1>BPI-ROOT:
|=============================================           - 79.9%   <\r><1>BPI-ROOT:
|=============================================           \ 81.2%   <\r><1>BPI-ROOT:
|==============================================          | 82.3%   <\r><2><1>BPI-ROOT:
|===============================================         / 83.6%   <\r><2>BPI-ROOT: <1>
        <\r><2>
Directory inode 299070, block #0, offset 0: directory corrupted
BPI-ROOT: UNEXPECTED INCONSISTENCY; RUN fsck MANUALLY.
<9>(i.e., without -a or -p options)
fsck exited with status code 4
done.
Failure: File system check of the root filesystem failed
The root filesystem on /dev/mmcblk0p2 requires a manual fsck
Rebooting automatically due to panic= boot argument
[   24.093636] CPU1: shutdown
[   24.111707] CPU2: shutdown
[   24.129621] CPU3: shutdown
[   24.146284] drivers/cpufreq/cpufreq.c:reboot_notifier_call: stop none boot cpus done
[   24.167574] drivers/devfreq/sunxi_dramfreq.c:sunxi_dramfreq_reboot: stop dramfreq done
[   24.197196] [alarmtimer] have no shutdown alarm! alarmtimer_shutdown 330
[   24.220177] sunxi-mmc sdc2: try to disable cache
[   24.238038] sunxi-mmc sdc2: sdc set ios: clk 50000000Hz bm PP pm ON vdd 7 width 8 timing LEGACY(SDR12) dt B
[   24.262045] sunxi-mmc sdc2: sdc set ios: clk 50000000Hz bm PP pm ON vdd 7 width 1 timing LEGACY(SDR12) dt B
[   24.285533] sunxi-mmc sdc2: sdc set ios: clk 400000Hz bm PP pm ON vdd 7 width 1 timing LEGACY(SDR12) dt B
[   24.309007] sunxi-mmc sdc2: sdc set ios: clk 400000Hz bm PP pm ON vdd 7 width 1 timing LEGACY(SDR12) dt B
[   24.334715] sunxi-mmc sdc2: sdc set ios: clk 400000Hz bm PP pm ON vdd 7 width 1 timing LEGACY(SDR12) dt B
[   24.370400] sunxi-mmc sdc2: sunxi_mmc_do_shutdown_com: mmc shutdown exit..ok
[   24.390722] [ohci2-controller]: ohci shutdown start
[   24.408566] [ohci2-controller]: ohci shutdown end
[   24.426102] [ehci2-controller]: ehci shutdown start
[   24.443731] [ehci2-controller]: ehci shutdown end
[   24.460978] [ohci1-controller]: ohci shutdown start
[   24.478278] [ohci1-controller]: ohci shutdown end
[   24.495160] [ehci1-controller]: ehci shutdown start
[   24.512061] [ehci1-controller]: ehci shutdown end
[   24.528427] sunxi_ohci_hcd_shutdown, ohci0-controller is disable, need not shutdown
[   24.548156] sunxi_ehci_hcd_shutdown, ehci0-controller is disable, need not shutdown
[   24.567726] Restarting system.
[   24.581882]
[   24.591861] Restarting Linux version 3.10.108-BPI-M2U-Kernel (root@bpi-iot-ros-ai) (gcc version 5.4.0 20160609 (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.4) ) #1 SMP Sat Nov 11 19:20:49 CST 2017
[   24.591861]
[     0.33]HELLO! BOOT0 is starting!
(lorddestruction6@freemail.hu) #5
there is the answer for your question in the log you have posted :
It have helped me aswell many times :slight_smile:
(Artem) #6
Yes, I did. My post was just for information (for developers) for the future
