Bpi-m2 lvds screen not working plz help
(ricky long) #1
I have a banana pi m2 and the lemaker 7"LCD module and I can’t get anything other than a blank screen PLZ help
(bpi team) #2
are you use waht image , please download
http://www.banana-pi.org/download.html
Android 4.4 External link 3.0 7"Touchscreen 01/06/2015
and use right way to burn you SD card .
http://www.banana-pi.org/start.html , how to burn android image to SD card
(ricky long) #3
This is the image I used and all I get is a blank screen
(bpi team) #4
are you use PhoenixCard tool to burn SD card??
(ricky long) #5
I’ve burned android images to other sd cards using Phoenix card I have no problems with the hdmi version just with my 7" LCD module
(ricky long) #6
Is there a difference between the android 4.4 LCD image on this website (banana-pi.org) and the android 4.4 LCD image on bananapi.com?
(bpi team) #7
is same ,but we have test ,it is working fine.
(ricky long) #8
I’ve tried other images with the 7" LCD module and nothing happens with the android image (4,4 LCD) the screen comes on but stays a blank white screen, what could be the reason for this then? I’m so confused npw
(bpi team) #9
we have success test ok , and new image will support it.
(Hakan) #10
This screen not android display. No you’re not related . Look, it works and you have been saying for help? Rasperry pi lot better than you. :rage:
(ricky long) #12
I’m asking for help cause I’ve tried everything everyone’s said and my screen isn’t working all I get is a blank gray screen I only have the one pi board and screen and the screen I’ve had only a few days so I didn’t think it would be defective but that’s what I’m down to believe at this point I guess
(bpi team) #13
please download andorid LCD verion , it support touch screen.
please give us more message.
1, what TP are you used ,
2, use the right way to burn your image. http://www.banana-pi.org/start.html
3, can you give us more boot message???
(BPI_Justin) #14
HI: Please check on the MD5 checksum of Android images you downloaded, and to see if the LCD-cable is in right position.
(ricky long) #15
Tp? Touchpanel? I’m using the lemaker 7" LCD module, android 4.4 LCD os burned to the sd card using Phoenix card, I’m not getting any messages the screen turns on an just stays a blank white screen
(ricky long) #16
How do I check the md5 checksum?
(braindead) #17
do u know if it starts up into the os? maybe u can try find it in the network than we can atleast know that the system is not faulty, and thats it is a screen issue
(ricky long) #18
I believe it does as it only turns on with the android 4.4lcd os but it just remains a blank gray/white screen
(BPI_Justin) #19
HI: It seems to me that the actual root cause is that you’re not using BPI 7" LCD module. As a matter of fact, we don’t know the spec. of your LCD, therefore we’re afraid we 're not able to give you suggestions. Maybe you’d love to consider purchasing a BPI 7" LCD module. http://www.aliexpress.com/store/product/New-100-original-high-quality-Banana-Pro-Pi-7-inch-LCD-Display-Touch-Screen-Raspberry-Pi/302756_32339310545.html
BPI 7" LCD module demo:
(ricky long) #20
I am using a banana pi 7" LCD module it’s the lemaker version not the bpi version, it’s made for the banana pi/ banana pro or the banana pi m1/m1+ which the lvds should be the same as the banana pi m2
(BPI_Justin) #21
Hi:
Would you please provide the following info for us to check on? (please be sure that they are all BPI products & images)
1). Photo(s) of the Board
2). Photo(s) of the LCD
3). Checksum of Android images (see this as reference http://winmd5.com/)
