Banoffee Pi Server: A Banana Pi powered website
this websit do more works as below. Home
Banana Pi Set up Linux Set up Raspbian on a SATA hard disk Change default settings Resize the root partition
Banana Pi Cluster
Overview Setting up a Pyplate server Building the cluster Connecting the cluster to the internet Pyplate Multi-Site Scaling out Testing the cluster with live traffic
MySQL
Set up MySQL on a Banana Pi Setting up remote access to a MySQL database Setting up Master-Slave MySQL Replication Automate MySQL replication on four nodes
A Python MySQL Cluster Management Utility
DB Cluster Utils Command Line Usage Examples Error Recovery DB Cluster Utils Cluster API DB Cluster Utils Server API
GlusterFS
Set up GlusterFS on two nodes Setting up GlusterFS on four Banana Pi servers
Server Monitoring
Simple web based monitoring tools
Ganglia
Installing Ganglia on a Banana Pi Set up Ganglia on multiple clusters
