BananaPi BPI-M64(A64) New Image Android 8.1 & Ubuntu Release 2018-08-17
(ZB) #1
BananaPi BPI-M64(A64) New Image Android 8.1 Demo & Ubuntu V1.0 Release 2018-08-17
Android 8.1
Banana Pi BPI-M64 run android 8.1
Ubuntu Server 16.04
1.About this release
  • This release is for banana pi M64 board which is based on Allwinner A64, We have two images release,Android 8.1 is based on kernel 4.9 and Ubuntu 16.04 is based on kernel 3.10.
2.BPI-M64 Android 8.1 Features Map
3.BPI-M64 Ubuntu 16.04 Features Map
4.FAQ:
  1. when you use hostapd to create AP signal, but could not to see SSID, please use following ways to solve it:
    A. rmmod bcmdhd
    B. Check ap6212 firmware:
    C. modprobe driver when startup:
    D.create hostapd.conf(Demo)
    interface=wlan0
    ssid=test_m64
    driver=nl80211
    country_code=US
    hw_mode=b
    channel=1
    max_num_sta=5
    wpa=2
    auth_algs=1
    rsn_pairwise=CCMP
    wpa_key_mgmt=WPA-PSK
    wpa_passphrase=password
    logger_stdout=-1
    logger_stdout_level=2
    E. Reboot your device
Bananapi m64 Access point
Banana Pi BPI-M64 run Android 8.1 system
Need Help with M2U as WIFI Access Point
(Kiran Patil) #2
Hello @Jackzeng,
Why there is no new kernel 4.x supported for Ubuntu release ?
Thanks, Kiran.
(ZB) #3
Hello, thanks for your advice, kernel 4.x still being developed,next week I probably release a demo image with kernel 4.x to you.
(Kiran Patil) #4
Hi @Jackzeng,
I did below configuration to my current setup and now able to discover the SSID of HOTSPOT.
load_modules()
  case ${BOARD} in
  bpi-m3)
    modprobe bcmdhd
  bpi-m64)
    modprobe bcmdhd op_mode=2 firmware_path=/lib/firmware/ap6212/fw_bcm43438a1.bin
    #modprobe bcmdhd
And I want to connect back to other network it doesn’t allow as below.
pi@bpi-iot-ros-ai:~$ nmcli con down id "newnet"
Connection 'newnet' successfully deactivated (D-Bus active path: /org/freedesktop/NetworkManager/ActiveConnection/13)
pi@bpi-iot-ros-ai:~$ nmcli con up id "FAB_PF"
Error: Connection activation failed.
pi@bpi-iot-ros-ai:~$ nmcli -t -f active,ssid dev wifi | egrep '^yes' | cut -d\: -f2
pi@bpi-iot-ros-ai:~$ nmcli con up id "Fabritronix"
Dmesg command output:
[  271.124746] CFG80211-ERROR) __wl_cfg80211_scan : Invalid Scan Command at SoftAP mode
[  271.124772] CFG80211-ERROR) wl_cfg80211_scan : scan error (-22)
[  272.111108] CFG80211-ERROR) __wl_cfg80211_scan : Invalid Scan Command at SoftAP mode
[  272.111133] CFG80211-ERROR) wl_cfg80211_scan : scan error (-22)
[  273.097429] CFG80211-ERROR) __wl_cfg80211_scan : Invalid Scan Command at SoftAP mode
[  273.097457] CFG80211-ERROR) wl_cfg80211_scan : scan error (-22)
[  274.083784] CFG80211-ERROR) __wl_cfg80211_scan : Invalid Scan Command at SoftAP mode
[  274.083810] CFG80211-ERROR) wl_cfg80211_scan : scan error (-22)
[  275.070108] CFG80211-ERROR) __wl_cfg80211_scan : Invalid Scan Command at SoftAP mode
[  275.070134] CFG80211-ERROR) wl_cfg80211_scan : scan error (-22)
[  276.056514] CFG80211-ERROR) __wl_cfg80211_scan : Invalid Scan Command at SoftAP mode
[  276.056540] CFG80211-ERROR) wl_cfg80211_scan : scan error (-22)
[  277.042024] CFG80211-ERROR) __wl_cfg80211_scan : Invalid Scan Command at SoftAP mode
[  277.042051] CFG80211-ERROR) wl_cfg80211_scan : scan error (-22)
[  278.028361] CFG80211-ERROR) __wl_cfg80211_scan : Invalid Scan Command at SoftAP mode
[  278.028386] CFG80211-ERROR) wl_cfg80211_scan : scan error (-22)
[  279.014698] CFG80211-ERROR) __wl_cfg80211_scan : Invalid Scan Command at SoftAP mode
[  279.014724] CFG80211-ERROR) wl_cfg80211_scan : scan error (-22)
[  280.001038] CFG80211-ERROR) __wl_cfg80211_scan : Invalid Scan Command at SoftAP mode
[  280.001065] CFG80211-ERROR) wl_cfg80211_scan : scan error (-22)
How to configure such that I can switch back and forth between HOTSPOT to other network ?
Thanks, Kiran.
(Kiran Patil) #5
I will check with new image tomorrow or next week Monday and will report.
Our requirement is we should be able to switch between HOTSPOT and other network as it happens in our Ubuntu desktop (16.04).
Thanks, Kiran.
(Ronald Becerra) #6
Hi.
Could you provide the Google Drive Link. I don´t have a Baidu account and it’s very difficult to create one since I don´t have a chinese mobl number.
Kind regards.
(ZB) #7
hello, use hostapd, could work
(ZB) #8
hello, I have update, please check the google link.
(Eugene Kalashnikov) #9
Hi, I’m also interested in the 4.x kernel for Ubuntu. When will it be ready?
