BananaPi BPI-M2Z(H2+) New Images Release 2019-04-30
BPI-M2Z Respbian 9.4
BPI-P2 Zero Respbian 9.4
BPI-M2Z Ubuntu Desktop 16.04
BPI-P2 Zero Desktop 16.04
1.About this release
This release is for banana pi M2Z & P2Zero board which is based on Allwinner H2+, We have three images release,Raspbian 9.4,Ubuntu 16.04 server & desktop , they are based on kernel 3.4.
The google drive file contains an image named 2019-01-08 (just as the previous version is named) and with a last modified date of 01.08.2019
Is this a fluke or…?
Reminder for update seconded, please and thank you.
I would download from Baidu, but it requires installation of BaiduNetdisk to download large files, which I’m not too keen on.
Banana Pi M2 Zero with this Raspbian 9.4: after about 2-3 minutes wifi goes down with some weird error messages and won’t get back up until rebooting. It’s probably some driver issue.
I’ll check Ubuntu 16.04 from those images, thanks!
Same wifi shutdown after ~3 minutes in Ubuntu Desktop Mate. I’m pretty sure it’s in the driver now. I’ll try with some usb wifi dongle, preferably one not based on broadcom chip.
After a complete apt-get upgrade, which required three reboot-and-run-upgrade runs due to wifi dying after three minutes, it seems the wifi is stable now, going on for 10 minutes now. I’ll try the same thing with Ubuntu image. Thanks for the great work!
Thanks, I’ll check this one later. I’m currently running a self-built Armbian (giving Ubuntu 18.04) and it works so well I don’t feel the need to switch.
Again… Dafuq is htis jocke?? There is no way go even on internet… NO GRUB, LOCKED ADMIN PASS:. Why?? How to rest or POST ADMIN PASS… passwd trick not work… it was SU SUDO locked…
Please… is this oficial support?? can you provide a ROOT PASS?? I cant even acces internet… there is NO FIRTST START make BOI console… just finalize to boot and it was LOCKED why?? Must i please a root pass?? or?? is dat distro broken?? NO GRUB so no chance to make it in console… i really dont wanna buy2buy thingi.
i can’t connect wo my wifi network, i’ve updated the firmware already. It says always wrong key but the key is right. Using ubuntu server??? what’s the problem here? wpa_supplicant.conf is set right. it works on raspbian but not with ubuntu server
