[Banana pi Accessories] BPI-RTC module and how to use it on banana pi
how to use it:
it can use on raspberry pi and banana pi .
1:Product Specification:
2:Produce Overview: The RTC module is specifically designed for BananaPi. It communicated with BananaPi through I2C bus. There is a Maxim DS3231 and 0.2uF SuperCapacitor on the board to keep the real time for a long time after the BananaPi has power off.
3:Produce Features: Use Maxim DS3231 chip 0.2uF Super Capacitor Can be operated by a shell 4:Port: Banana Pi connection port
5: conncet on BPI
6 ,code :
unit Uit_DS3231;
{$mode objfpc}{$H+}
interface
uses
  Classes, SysUtils, TWI;
const
  DS3231_WriteAddress 0xD0 //器件写地址
  DS3231_ReadAddress 0xD1 //器件读地址
  DS3231_SECOND 0x00 //秒
  DS3231_MINUTE 0x01 //分
  DS3231_HOUR 0x02 //时
  DS3231_WEEK 0x03 //星期
  DS3231_DAY 0x04 //日
  DS3231_MONTH 0x05 //月
  DS3231_YEAR 0x06 //年
  DS3231_SALARM1ECOND 0x07 //秒
  DS3231_ALARM1MINUTE 0x08 //分
  DS3231_ALARM1HOUR 0x09 //时
  DS3231_ALARM1WEEK 0x0A //星期/日
  DS3231_ALARM2MINUTE 0x0b //分
  DS3231_ALARM2HOUR 0x0c //时
  DS3231_ALARM2WEEK 0x0d //星期/日
  DS3231_CONTROL 0x0e //控制寄存器
  DS3231_STATUS 0x0f //状态寄存器
  BSY 2 //忙
  OSF 7 //振荡器停止标志
  DS3231_XTAL 0x10 //晶体老化寄存器
  DS3231_TEMPERATUREH 0x11 //温度寄存器高字节(8位)
  DS3231_TEMPERATUREL 0x12 //温度寄存器低字节(高2位)
type
  TDS3231 = class
  private
    class var FInstance: TDS3231;
    class function GetInstance: TDS3231; static;
  public
    class procedure Release;
    class property Instance: TDS3231 read GetInstance;
  private
    FTWI0: TTWI;
    constructor Create;
    destructor Destroy; override;
  public
    function GetByte(Addr, Reg: Byte): Byte;
  end;
implementation
  const TDS3231ADDR = $34;
class function TDS3231.GetInstance: TDS3231;
begin
  if FInstance = nil then FInstance:= TDS3231.Create;
  Result:= FInstance;
end;
class procedure TDS3231.Release;
begin
  FreeAndNil(FInstance);
end;
constructor TDS3231.Create;
begin
  inherited Create;
  FTWI0:= TTWI.Create(TWI_0);
end;
destructor TDS3231.Destroy;
begin
  FTWI0.Free;
  inherited Destroy;
end;
function TDS3231.GetByte(Addr, Reg: Byte): Byte;
begin
  FTWI0.Read(TDS3231ADDR, Reg, Result);
end;
end.
What is the code ? …‘Lolcode’ , ‘Ook!’ , ‘Velato’, ‘Brainfuck’ ?
I test: root@osirisBpiM3:~ # nano code … root@osirisBpiM3:~ # chmod +x code
root@osirisBpiM3:~ # ./code ./code: line 1: unit: command not found ./code: line 3: {: command not found ./code: line 5: interface: command not found ./code: line 7: uses: command not found ./code: line 9: Classes,: command not found ./code: line 11: const: command not found ./code: line 13: DS3231_WriteAddress: command not found ./code: line 15: DS3231_ReadAddress: command not found ./code: line 17: DS3231_SECOND: command not found ./code: line 19: DS3231_MINUTE: command not found ./code: line 21: DS3231_HOUR: command not found ./code: line 23: DS3231_WEEK: command not found ./code: line 25: DS3231_DAY: command not found ./code: line 27: DS3231_MONTH: command not found ./code: line 29: DS3231_YEAR: command not found ./code: line 31: DS3231_SALARM1ECOND: command not found ./code: line 33: DS3231_ALARM1MINUTE: command not found ./code: line 35: DS3231_ALARM1HOUR: command not found ./code: line 37: DS3231_ALARM1WEEK: command not found ./code: line 39: DS3231_ALARM2MINUTE: command not found ./code: line 41: DS3231_ALARM2HOUR: command not found ./code: line 43: DS3231_ALARM2WEEK: command not found ./code: line 45: DS3231_CONTROL: command not found ./code: line 47: DS3231_STATUS: command not found ./code: line 49: BSY: command not found ./code: line 51: OSF: command not found ./code: line 53: DS3231_XTAL: command not found ./code: line 55: syntax error near unexpected token (' ./code: line 55: DS3231_TEMPERATUREH 0x11 //温度寄存器高字节(8位) ’
&&& :upside_down:
&& @sinovoip
I speak five languages ​​, but … Unfortunately I do not know Chinese . Would it be possible comments in the code … write in English ?
How can I set the alarm ? Can you write the simplest example in C ?
Thank you eW
pleae check here:
https://bananapi.gitbooks.io/bpi-accessories/content/en/rtcmodule.html
it is code like free pascal
Sorry, I can’t compile - use ‘pure’ Debian, only console - have you this file compiled?
