Armbian Buster/Bionic: No Sata device detected
Hi all,
after successful install of Armbian Buster (Armbian_20.02.5_Bananapi_buster_current_5.4.26.img) on my Bananian M1/2?? (has MicroSD) all seems to be good…
All updates are there, but: The hard disk i connected to the board via Sata, with additional 5V power cable is not detected, dmesg|grep -i sata says:
“ahci-sunxi 1c18000.sata: PHY power up failed.”
Curious, because changing the Micro SD card to old raspbian os shows all devices, including the SATA parts. Power is given by original 2.5A supply.
Anything wrong with the images? Same problem on Armbian Bionic…
Thanks Bommel
Attached this way:
SATA is powered, measured 5V at the connector. (since my drive is connected directly to PSU) http://ix.io/2fzR
root@bananapi:/home/igorp# cat /proc/partitions
major minor  #blocks  name
   1        0       4096 ram0
   1        1       4096 ram1
   1        2       4096 ram2
   1        3       4096 ram3
 179        0    7761920 mmcblk0
 179        1    7602576 mmcblk0p1
   8        0  488386584 sda
   8        1  488385558 sda1
 254        0      51200 zram0
 254        1     507140 zram1
So you think there is not enough power?? Even there is no device attached?
