WED and beamforming on BPI-R3
Guess you are not using 802.11r fast transition :wink:
I’m still trying to see if we can use wed and bridge, since I really like using 802.11r. It is the first reason I changed to using bananapi routers in the first place. (mwlwifi did not support it at that time and development had halted.)
Not yet…i try to get wed working first without bridges :slight_smile: (except the lanbr0) and leaving wlan0/1 as independ interfaces for now…but need to check if flow offload also works when lanports bridged…and the if the pppoe offload also works.
Setting up a basic system for replacing my r2 in near future…
But i guess with the option you found we can also use acceleration within bridges.
@frank-w Were you able to get the WED working?
@dangowrt any idea why it complains about operation not supported in my case? WED and beamforming on BPI-R3 - #117 by ghostbuster91
Not yet,i contacted lorenzo to get a hint how to get it working with mainline linux
lorenzo pointed me to this commit i applied on top of my 6.5-main tree:
e2486c27c56f (HEAD → 6.5-main, origin/6.5-main) wifi: mt76: mt7915 add tc offloading support
after this is added, the nftables rules with wlan0/1 can be applied and i have the debugfs entry (but still empty)…need to complete my wifi-setup for further testing
cat /sys/kernel/debug/ppe0/bind
edit: had to fix some bugs in my setup and now traffic itself works, but debugfs is still empty…i see packets increasing on the forwarding-rule for offload, but nothing shown in ā€œppe0-bindā€
ct state established flow add @f counter packets 1206 bytes 318372
my current nftables:
note: wireless-next (maybe 6.6-rcX) seems to have broken firmware-load and renamed wmac driver (CONFIG_MT7986_WMAC => CONFIG_MT798X_WMAC)
firmware-load is fixed with this: try to fix wed firmware issue #2 Ā· frank-w/BPI-Router-Linux@9a5789f Ā· GitHub
but it looks like ppe does not kick in for wifi-devices…
I assume that nothing has changed since your last message. Do you know if there is any upstream issue for this that we could track?
No nothing changed…made some debug with lorenzo but he was busy in last time and he had the mmc-issue in uboot multiple times…openwrt was working but not vanilla kernel
