Ok, I hope we’ll manage to pick up that change in OpenWrt without breaking existing images and devices out there…
Regarding BL32/OP-TEE: Will MediaTek provide patches or a source repository to build OP-TEE? I’m asking because using OP-TEE and fTPM paves the road towards ARM System Ready (ie. standardized UEFI boot), which would obviously be very useful (at least on devices using eMMC/uSD storage) to install and run unmodified general purpose OS (given kernel driver support for the SoC and peripherals is present, of course).
I personally don’t like the UEFI approach to depend on a single DOS/FAT filesystem to load boot artifacts from, uImage.FIT single image would be my preference (as in that way the same image can work on NOR, NAND, eMMC and uSD). However, SystemReady seems to be what industry converges towards, esp. when it comes to white-label hardware.
i tried the new way for creating the gpt on emmc (works on sdmmc without problems) on bpi-r3.
emmc-boot does not find fip partition, but it is there
EC: 0000 0000 [2000]
BL2: v2.9(release):v2.9.0-349-g55576307fd8c emmc
ERROR: Partition 'fip' not found
ERROR: FIP boot source initialization failed with -2
when i boot from nand and boot kernel+initrd and run parted on the emmc i see this:
# parted /dev/mmcblk0
GNU Parted 3.3
Using /dev/mmcblk0
Welcome to GNU Parted! Type 'help' to view a list of commands.
(parted) p
Model: MMC 008GB0 (sd/mmc)
Disk /dev/mmcblk0: 7818MB
Sector size (logical/physical): 512B/512B
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
2 4194kB 4719kB 524kB u-boot-env
3 4719kB 6816kB 2097kB factory
4 6816kB 8913kB 2097kB fip
5 8913kB 114MB 105MB fat16 boot
6 114MB 6556MB 6442MB ext4 rootfs
(parted)
so it looks right for me…do you have any idea?
this is how i built the partition table:
device=emmc does create a partition with label gpt instead of the bl2 partition
if i flash the older gpt image (generated by the python2-tool) fip partition is found, but if i then try parted, i get the error that main gpt is corrupt
GNU Parted 3.5
Using /dev/mmcblk0
(parted) p
Error: The primary GPT table is corrupt, but the backup appears OK, so that will
be used.
OK/Cancel?
do i miss anything when creating the partition with sgdisk?
Atf code for finding fip partition seems completely common for sd+emmc so i wonder why sd works and emmc not. I see there is a dump function…can i simply trigger it with increasing loglevel on compile? @ericwoud do you tried emmc on r3 yet and can help to debug this?
I have started on emmc many times, but it was version v2.8.
I remember, for R3 v2.8 used fixed ‘fip’ partition and did not search for partition name on R3. it was different from the R64, which did use the partlabel.
I changed that in my own fork of v2.8, to also use partlabel.
v2.9 is is common code, all model search fip partition.
This is how I create the gpt:
I have changed the name ‘fip’ to ‘bpir3-emmc-fip’ also in atf code, and it finds it ok.
is this your emmc-partition table? looks like the sdmmc one with bootable bl2 as first one…
i made for emmc the gpt-part instead based on the partition sheme i got in an older atf version, but my last misses this first one completely and causes different numbering (so boot and root-partition number do not match same on sdmmc)
but it looks like this first one breaks, see top-commit message
I use the same partition layout, sdmmc and emmc. I also use a trick on R3 so I do not have to use mmcblk0boot0. I already did on R64, but that trick did not work on R3, so I have another one. But it also works using mmcblk0boot0.
On R3mini the trick probably won’t work, so probably need to use mmcblk0boot0.
But if in your case parted complains about corrupt got table, then maybe this is why atf will also not be able to use it …
the old gpt img file works in gpt but also complains the gpt error which cannot be fixed (wants to use the backup-gpt which is the “fixed” from my image)…i cannot fix/print the partition from the old gpt.img (generated by the python2 script)
it looks like the first partition (from offset 0 with label gpt) breaks the verify-function in bl2…i try to remove it and add bl2-partition like i do for sdmmc…
i know, this is because of partition-numbering (to have boot=5 and root=6 when bl2 is missing), took this from an older json-file i got from bpi/mtk
have now manually created my gpt
# sgdisk -a 1 -n 1:34:8191 -A 1:set:2 -t 1:8300 -c 1:"bl2" /dev/mmcblk0
# sgdisk -a 1 -n 2:8192:9215 -A 2:set:63 -t 2:8300 -c 2:"u-boot-env" /dev/mmcblk0
# sgdisk -a 1 -n 3:9216:13311 -A 3:set:63 -t 3:8300 -c 3:"factory" /dev/mmcblk0
# sgdisk -a 1 -n 4:13312:17407 -A 4:set:63 -t 4:8300 -c 4:"fip" /dev/mmcblk0
# sgdisk -a 1024 -n 5:17408:222207 -t 5:8300 -c 5:"boot" /dev/mmcblk0
# sgdisk -a 1024 -n 6:222208:12805120 -t 6:8300 -c 6:"rootfs" /dev/mmcblk0
# sgdisk -p /dev/mmcblk0
[ 715.532262] mmcblk0: p1 p2 p3 p4 p5 p6
Disk /dev/mmcblk0: 15269888 sectors, 7.3 GiB
Sector size (logical/physical): 512/512 bytes
Disk identifier (GUID): 4C990539-7275-49B2-A19C-5F72A91B3FFC
Partition table holds up to 128 entries
Main partition table begins at sector 2 and ends at sector 33
First usable sector is 34, last usable sector is 15269854
Partitions will be aligned on 2-sector boundaries
Total free space is 2464734 sectors (1.2 GiB)
Number Start (sector) End (sector) Size Code Name
1 34 8191 4.0 MiB 8300 bl2
2 8192 9215 512.0 KiB 8300 u-boot-env
3 9216 13311 2.0 MiB 8300 factory
4 13312 17407 2.0 MiB 8300 fip
5 17408 222207 100.0 MiB 8300 boot
6 222208 12805120 6.0 GiB 8300 rootfs
at least i have now the fip partition found…but booting fip does not work…maybe i have to flash fip again
Partition 'bl2' found, check for fip
Partition 'u-boot-env' found, check for fip
Partition 'factory' found, check for fip
Partition 'fip' found, check for fip
Partition 'fip' match fip ;)
i guess bl12 and fip are bundled (bl2 checks checksum of fip or something like this)
edit: yes reflashed bl2+fip from same compilation fixes emmc bootup…so sd+emmc partition-table should be same to work. @ericwoud thanks for looking into it, no need for further digging/testing
Thx for the info,but then it is unclear why the fip cannot be started and needed to be reflashed…used same offsets/sectors on recreation the gpt.with the bin gpt i flashed for testing fip was loaded and after that i only flashed bl2 with debug-code and recreated the gpt with sgdisk.
Now that i know that sdmmc gpt works too on emmc,easiest way for install on r3 is to simply flash sdmmc image (from initrd booted via spi-nand/nor) to emmc and maybe reflash fip afterwards and flash bl2 to boot0 (but eric says boot0 is not needed).
Build emmc ATF, but pack it with sdmmc bootrom-header. Then set the R3 switches in SD boot mode, but switch the MMC hardware to emmc. Set the MMC CSD boot to 7. Et voila, you can boot emmc without mmcblk0boot0.
This is caused by invalid value of ‘num of sectors’ of the MBR:
VERBOSE: MBR header entry has an invalid number of sectors
VERBOSE: Failed to access image id=28 (-22)
ERROR: Failed to parse partition with image id = 28
The ‘num of sectors’ is intended to be the total number of blocks of the eMMC user data area.
However the actual number of blocks varies between emmc chips.
That is, all GPT header generated by tool offline can’t know the number of blocks, and that’s why the value is invalid (Filled with ffffffff).
Of course you can recreate the MBR/GPT online using parted. But to make it always work, I have to patch the ATF to tell it the actual ‘num of sectors’ before parsing MBR.
