Trying to run Ubuntu 24.04 from NVME on R4. I think I might be in over my head, but I’m determined to figure this out
I assembled my BPi-R4 with the BE14 WiFi 7 card and a 128GB m.2. The goal is to boot Ubuntu 24.04 from the NVME drive.
I have been at this for almost two days now, and every time I think I’m getting somewhere I end up lost again :expressionless:
Does a simple guide or anything exist on how to set this up? All the pieces seem to exist, I just don’t know how to put them together. I can atleast say that the NVME is detected and works when I boot from an SD card.
As of right now my stock NAND won’t boot, the eMMC won’t boot and I have the official Banana Pi Ubuntu image flashed to an SD Card which will boot.
I have documented nearly everything along the way but I saw no point in posting a novel of information that doesn’t work. But if there’s any info needed I likely have it noted down somewhere.
I did find this where they seem to have almost the same goal. Unfortunately I’m having a hard time following the steps.
I spend weeks getting nvme basicly to work and also at least a week to define a way for booting it :slight_smile:
Firat you have to understand that you cannot boot nvme directly. You have to boot from mmc or spi till uboot.
The first step then would be partitioning the nmve to match bootloader config. When using my uboot it uses first partition as fat for kernel and second as rootfs (ext4). Then prepare a rootfs from not running system (e.g.compress a tar.gz from sdcrad rootfs with external pc) and put it e.g. on usb-drive. Then boot up your r4 and boot from sdcard till linux and unpack your tar.gz to the nvme root,change fstab to match your partition. You can also boot from sdcard and use initramfs (can be found on my gdrive) to copy 1:1 (including rights) from sdcard to nvme. That was the way i used.copy kernel from sdcard to root-partition and you are prepared to do a manual boot from nvme (after mmc/spi to uboot).
Thank you for helping
I tried multiple times to get it to boot from emmc and every time I just got “System Halted” on reboot. That was flashing this image to eMMC only.
Is that the right file? Booting to emmc or nand first makes sense, but I couldn’t figure out how to make it work. Am I using the wrong image? Or doing something in the wrong order?
My NVME drive is still empty for now because I was trying to get uboot working first. Then I was going to setup the nvme next, but I never got uboot working without the sd card.
BL2 is only 2nd stage bootloader which has to be flashed to boot0 on emmc.
My full images are here:
https://drive.google.com/drive/folders/1A5S7_82Bg4EYxjzdQ5FKyBw9Qi2C3uK-?usp=drive_link
They are for sdmmc only,but can be flashed to emmc too,but it needs emmc bl2 on boot0
More information i put here: en:bpi-r4:start [FW-WEB Wiki]
For initrd you can use e.g. this.
https://drive.google.com/drive/mobile/folders/1WLWAR1FC-rF4n2SgFecBlU1ym_XKqAR_/15Y5Y3NAOwg_IMmN3k6hdb7pAQj9oTVTl/1_UtkNl0S44_Xy46NAEn1KoFDSOkQwAsb?sort=13&direction=a
Oh ok. So what would be the proper steps to get it going?
I re-flashed the latest official OpenWRT to nand and eMMC, just so I have a functioning environment to work in for now.
Im still not 100% sure Im following everything:
  1. Format the NVME first while I still have a functional environment. Partition1 is fat32 (~200MB) and partition2 is the rest of the space as ext4.
The partitioning makes sense, But I don’t think Im fully understanding what data from the sd card needs to go to which partitions on the NVME drive.
I have a NVME to USB adapter. Could I insert my nvme drive into the usb adapter and flash bpi-r4_noble_6.12.6-main.img with etcher just like I would for an sdcard? Then I can resize the ext4 partition later, create swap space, etc… My Main PC is a Mac and cannot read ext4
  1. Once I figure out step 2, I then modify the fstab file on the nvme drive to match, so something like:
/dev/nvme0n1p2 / ext4 defaults 0 1
/dev/nvme0n1p1 /boot vfat defaults 0 2
  1. Flash bpi-r4_noble_6.12.6-main.img to eMMC with:
dd if=bpi-r4_noble_6.12.6-main.img of=/dev/mmcblk0 conv=notrunc,fsync
  1. flash bpi-r4_emmc_bl2.img to boot0 with:
dd if=bpi-r4_emmc_bl2.img of=/dev/mmcblk0boot0 conv=notrunc,fsync
And now at this point I should be able to switch over to eMMC booting and get to Uboot, and select the nvme boot option? Is that the correct steps? Or did I miss anything?
On nvme you do not need the partitions from sdcard as you only need p1 as boot and p2 as rootfs. Sd image contains more partitions like for bl2 and fip. So just create 2 partitions and copy files with permissions/owner information and change etc/fstab.
When emmc is bootable so far and nvme prepared,you can try booting from nvme from emmc uboot. If that works you can modify uenv.txt on emmc boot partition for automatic boot (bootmenu_default and pathing out the askkernel from nvme-boot).
Ok I think I got it. I’ll be giving it try here soon.
Does anything special need to be done for the networking and WiFi to work? It’s still going to be used as a router, just not with OpenWRT.
Just to verify, when booting from SD card into Ubuntu to copy the partitions over the scared would be;
mmcblk0     179:0    0  29.7G  0 disk
├─mmcblk0p1 179:1    0     4M  0 part
├─mmcblk0p2 179:2    0   512K  0 part
├─mmcblk0p3 179:3    0     2M  0 part
├─mmcblk0p4 179:4    0     2M  0 part
├─mmcblk0p5 179:5    0   100M  0 part /boot
└─mmcblk0p6 179:6    0   6.4G  0 part /
And in this case mmcblk0p5 is whats cloned to the Fat32 partition on NVME, and mmcblk0p6 get cloned to the ext4 partition? The others can be ignored?
Right, p5 → p1,p6->p2
but you should not copy from running system.files may change while copy
I have ubuntu running from nvme ssd
  • I’m using bootloader on sdcard, because it’s for some reason hard to boot a custom one from nand, and emmc , easiest way is to grab sdcard image from @frank-w and use u-boot from this image
  • you can adjust uEnv.txt on /dev/mmcblk0p5, no need to copy it anywhere
  • there’s no need to mirror boot partitions from sd, you can create whatever you like , for example I have 1GB ext4 /boot partitions with multiple kernel variants selectable via boot menu
  • all you need to do is prepare boot vars , here is my setup for ubuntu
nvme_root_ubuntu=/dev/nvme0n1p3
ununtu_nvme_kernel=bpi-r4.itb
bootnvmeubuntu=run usenvme; setenv root $nvme_root_ubuntu; run buildargs; ext4load nvme 0:1 $kaddr $ununtu_nvme_kernel;bootm $kaddr
#bootmenu record, you should match your options count here
bootmenu_5=6. Boot ubuntu from nvme.=run bootnvmeubuntu
bootmenu_default=5
in this example - ext4load nvme 0:1 is location of boot partition , we using ext4load instead of fatload so we can use ext4 as boot partition filesystem
for kernel you can copy .itb file from sdcard , and it will work properly
one more small detail , if you plan to use non-root user , you should use kernel with
CONFIG_EXT4_FS_POSIX_ACL=y
CONFIG_EXT4_FS_SECURITY=y
options set , for moving files from SD card (if you do that directly on the router )
your running kernel should have this options aswell or you wouldnt be able to run some commands that requre security capabilities
I highly recoment to get access to u-boot’s console and make some tests there, you need to run
run usenvme
frist , and then you can play with your specific ssd layout
I’ve been at this all afternoon and still cant get it booting from eMMC. The nvme drive isn’t even coming into play yet, I cant even get to uboot. So the nvme is setup and should be ready to go, but I haven’t even made it far enough to try it yet.
The only way I have managed to get anywhere is by using an sd card.
My last attempt was to connect to the R4 via serial and booted into OpenWRT via eMMC. In there I got the nvme formatted and setup the partitions.
I then rebooted into OpenWRT via NAND to perform the flashing for the bl2 image and the mmc image. But I couldn’t, when booting using nand neither my flash drive or the nvme drive are visible so I had no way to get the image files to it.
I ended up rebooting OpenWRT via NAND again and did apk add sshfs so that I could use scp to flash the images.
  1. I ssh into the R4 and ran echo 0 > /sys/block/mmcblk0boot0/force_ro
Then from my computer I did:
  1. cat /Volumes/usb500/bpi-r4_emmc_bl2.img | ssh [email protected] "dd of=/dev/mmcblk0boot0 conv=notrunc,fsync"
  2. cat /Volumes/usb500/bpi-r4_noble_6.12.6-main.img | ssh [email protected] "dd of=/dev/mmcblk0 conv=notrunc,fsync bs=4M"
It looked like it worked…until I rebooted using eMMC:
F0: 102B 0000
FA: 1042 0000
FA: 1042 0000 [0200]
F9: 1041 0000
F3: 1006 0033 [0200]
F3: 4001 00E0 [0200]
F3: 4002 0000
F6: 102C 0000
F5: 1026 0000
00: 1005 0000
FA: 1042 0000
F9: 1041 0000
F3: 4002 0000
F6: 102C 0000
01: 102A 0001
02: 1005 0000
BP: 0200 00C0 [0001]
EC: 0000 0000 [2000]
MK: 0000 0000 [0000]
T0: 0000 00E3 [0101]
System halt!
I guess the emmc partition config (boot0 or boot1) need to be marked as bootable or maybe the bootbus config is not set or wrong.
mmc partconf 0 1 1 0
Maybe needed:
mmc bootbus 0 0 0 0
So boot from nand into uboot with emmc active and try the first command and if this still not works the second.
NAND and eMMC aren’t booting yet
which image did you flash to eMMC , are you sure that it is for correct media type?
That’s part of what I was just going to ask.
This is the image im flashing to the main part of the eMMC:
And this is the image for the boot0 portion:
bpi-r4_sdmmc_bl2.img
For right now the problem doesn’t involve my nvme drive yet, because I cant even get Ubuntu booting from the eMMC normally. So I haven’t had a chance to try setting up the NVME drive yet. Though it does work, I have it temporairly formatted and have been using it to store images and other files so I don’t have to keep using my flash drive.
Nothing works except booting from the SD Card. I was up until about 2am last night working on this. I feel like I’m on the right track, but there’s some piece of this process I’m just not understanding. To verify everything hardware wise is ok I even installed the latest snapshot of OpenWRT to the NAND and the eMMC, just to make sure it worked, and it boots just fine from both.
As an alternative, I’d be perfectly fine setting it up to boot from the NAND instead of the eMMC. In-fact it might even be better because then I can keep a backup OS on the eMMC incase anything ever goes wrong.
I also figured I’d mention that I have been doing all this using a serial connection. it’s a CH340G which no-one seems to like, but it’s been rock solid for me in MacOS.
Yeah, so far the only thing I can get to boot from either NAND or eMMC is OpenWRT.
I flashed the latest official snapshot just to make sure everything still worked and it wasn’t a hardware issue or me messing up something up big. OpenWRT can boot from NAND and eMMC perfectly every time. The issues don’t start until I try to setup Ubuntu.
This command ran fine, but made no difference.
mmc bootbus 0 0 0 0
This command threw an error about bootbus not being a valid argument. Despite the fact that if I run mmc --help the bootbus command is clearly listed.
You have to use the emmc one.
Ah, I didn’t catch that. Thought Im pretty sure I have tried both at some point. But I will download a fresh copy and flash it to make sure.
But was the bpi-r4_noble_6.12.6-main.img the correct image for the other part?
