So I tested with kernel 4.19.
I must set VLAN because my ISP is offering also IPTV and internet only is on VLAN id 300.
4.19.72-bpi-r2-main
ip link set dev eth1 up:
ip a:
eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 02:03:03:03:03:03 brd ff:ff:ff:ff:ff:ff
inet6 fe80::3:3ff:fe03:303/64 scope link
ip link add link eth1 name wan.300 type vlan id 300:
journalctl:
systemd-udevd[743]: ethtool: autonegotiation is unset or enabled, the speed and duplex are not writable.
systemd-udevd[743]: Using default interface naming scheme 'v243'.
ip a:
wan.300@eth1: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
ip link set dev wan.300 up:
ip a:
wan.300@eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
systemctl start [email protected]:
journalctl:
dhclient[811]: Internet Systems Consortium DHCP Client 4.4.1
dhclient[811]: Copyright 2004-2018 Internet Systems Consortium.
dhclient[811]: All rights reserved.
dhclient[811]: For info, please visit https://www.isc.org/software/dhcp/
dhclient[811]:
dhclient[811]: Listening on LPF/wan.300/02:03:03:03:03:03
dhclient[811]: Sending on LPF/wan.300/02:03:03:03:03:03
dhclient[811]: Sending on Socket/fallback
dhclient[811]: DHCPDISCOVER on wan.300 to 255.255.255.255 port 67 interval 3
dhclient[811]: DHCPDISCOVER on wan.300 to 255.255.255.255 port 67 interval 8
dhclient[811]: DHCPDISCOVER on wan.300 to 255.255.255.255 port 67 interval 15
dhclient[811]: DHCPDISCOVER on wan.300 to 255.255.255.255 port 67 interval 14
dhclient[811]: No DHCPOFFERS received.
dhclient[811]: No working leases in persistent database - sleeping.
This configuration is working on 4.4 and 4.14.
Next is to test without second gmac.
I will use 4.19-without2ndgmac but I must compile it first. I will give you know.
maybe you need to change mac? my isp needs different mac-adresses for all vlan.
the journalctl-message are strange:
i guess duplex/speed is only available for physical port (wan) and not for vlan, because there is only a tagging by software, but strange, that this message appears on virtual port. have you put wan up before setting vlan up?
I tried it already and not helps.
On kernel 4.14 MAC addresses are same also I have same errors form systemd-udevd but I get IP address so i really don’t understand the problem.
I tried with this commands order:
eth1 up -> wan up -> vlan 300 -> dhclient
no success
only diffrerence what I see is that on 4.14 kernel I have wan.300@wan but on 4.19 I have wan.300@eth1.
Oh…it should be wan.300@wan…you cannot define vlan on gmacs…something is wrong there
if i add a vlan in kernel 4.19 it looks right (as in 4.14)
ip link add link wan name wan.140 type vlan id 140
root@bpi-r2:~# ip link show wan.140
10: wan.140@wan: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode DEFAU
LT group default qlen 1000
you have created it the wrong way:
ip link add link eth1 name wan.300 type vlan id 300 #see eth1
i wonder why this is working in 4.14…it’s basicly wrong…you create a vlan on gmac instead of the dsa-port
I just checked 5.3.0-rc1-bpi-r2-phylink-2.5 and it works fine but i had some problems (I can’t bridge lan interfaces - kernel panic when cable plugged in)
I can use git now and cloudflared. As I could not use cloudlfared before, on 4.14, I switched to dnscrypt-proxy. On 4.14 had lot of timeouts when daemon was looking for servers. Now on 5.3 I have no timeouts at all - all server are avaliable.
I’m going back to 4.19 and do vlan as you mentioned above.
have now tried 5.4-gmac-branch and run dhclient on both gmacs (wan+lan2)
both are working and giving good traffic (lan2=940Mbit/s,wan~915-940Mbit/s) with iperf3 without retransmitts
Zusammenfassung
root@bpi-r2:~# ip link set wan up
[ 433.276386] mtk_soc_eth 1b100000.ethernet wan: PHY [mdio-bus:00] driver [Generic PHY]
[ 433.284343] mtk_soc_eth 1b100000.ethernet wan: configuring for phy/rgmii link mode
root@bpi-r2:~# [ 437.448610] mtk_soc_eth 1b100000.ethernet wan: Link is Up - 1Gbps/Full - flow control off
[ 437.456820] IPv6: ADDRCONF(NETDEV_CHANGE): wan: link becomes ready
root@bpi-r2:~#
root@bpi-r2:~#
root@bpi-r2:~# ip a
inet6 ::1/128 scope host
link/ether 62:16:69:7e:d6:fc brd ff:ff:ff:ff:ff:ff
inet6 fe80::6016:69ff:fe7e:d6fc/64 scope link
3: wan: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether 5a:8b:a4:e6:11:dc brd ff:ff:ff:ff:ff:ff
inet6 fe80::588b:a4ff:fee6:11dc/64 scope link
4: sit0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1000
link/sit 0.0.0.0 brd 0.0.0.0
5: lan0@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state LOWERLAYERDOWN group default qlen 1000
link/ether 08:00:00:00:00:01 brd ff:ff:ff:ff:ff:ff
inet 192.168.0.11/24 brd 192.168.0.255 scope global lan0
inet6 fe80::a00:ff:fe00:1/64 scope link
6: lan1@eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
7: lan2@eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
8: lan3@eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
root@bpi-r2:~# ip add del 192.168.0.11/24 dev lan0
root@bpi-r2:~# dhclient wan
root@bpi-r2:~# ip addr show wan
inet 192.168.0.105/24 brd 192.168.0.255 scope global dynamic wan
valid_lft 172791sec preferred_lft 172791sec
root@bpi-r2:~#
made same for lan2 (to use the other gmac)...also works in my test, only see a strange vlan-message on bringing up
root@bpi-r2:~# ip link set lan2 up
[ 594.156547] mt7530 mdio-bus:1f lan2: configuring for phy/gmii link mode
[ 594.163658] 8021q: adding VLAN 0 to HW filter on device lan2
root@bpi-r2:~# [ 598.328964] mt7530 mdio-bus:1f lan2: Link is Up - 1Gbps/Full - flow control off
[ 598.336307] IPv6: ADDRCONF(NETDEV_CHANGE): lan2: link becomes ready
root@bpi-r2:~#
root@bpi-r2:~# ip addr show lan2
7: lan2@eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
root@bpi-r2:~# dhclient lan2
inet 192.168.0.118/24 brd 192.168.0.255 scope global dynamic lan2
valid_lft 172798sec preferred_lft 172798sec
as far as we know now, trgmii seems to be broken for gmac1, after setting to rgmii or moving wan to the rgmii-configured gmac2 it’s reported to be fixed…
maybe change trgmii to rgmii in older kernel-versions without phylink (i guess the problem is also there, and rene took some values from the existing code)
