Do you still think that it is not implemented in the driver ?
If not, do you have an idea where I can look into to solve this issue ?
I think driver is missing this partβ¦i donβt know where iw get the information about βmesh pointβ
I see some mesh_point references. Have you added this option?
In main.c mesh seems handled like normal AP
Yes,
it is included in the kmod-mac80211 package:
.config - OpenWrt Configuration
> Kernel modules > Wireless Drivers > Search (CONFIG_MAC80211_MESH)
βββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββ Search Results ββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββ
β Symbol: PACKAGE_MAC80211_MESH [=y] β
β Type : bool β
β Defined at tmp/.config-package.in:21883 β
β Prompt: Enable 802.11s mesh support β
β Depends on: PACKAGE_kmod-mac80211 [=y] β
β Location: β
β -> Kernel modules β
β -> Wireless Drivers β
β (1) -> kmod-mac80211..................... Linux 802.11 Wireless Networking Stack (PACKAGE_kmod-mac80211 [=y]) β
β
Mhm,i guess the ifdef i linked above only tells iw that mesh is supportedβ¦but i do not see that driver handles mesh anyhow in hardware (set any bit in any hardware register)
Iβm sure that the driver has issues with starting a mesh. They donβt send any beacons out. However, I still see ipv6 link local traffic when opening a monitor mode on a different device.
I had the time to debug today and finally wrote my first rfc-upstream-commit.
https://lore.kernel.org/linux-wireless/[email protected]/T/#u
Mesh works with this?
Congratulation to your fist patch submission
Small noteβ¦Fixes-tag needs to be directly above signed-off
Thanks! It works. You can try it here: https://github.com/openwrt/openwrt/pull/4652
I also updatet there the Patch. I think I will resend it via mailinglist with the correct Fixes: ... position.
@frank-w Here it is correct, or? https://github.com/openwrt/openwrt/pull/4652/files#diff-ce1668220610e9a21eba50965aef387a3e87b8475d010ce209f822e6bc884344R27
yes now itβs rightβ¦
edit: have now added it to my 5.15-rc tree
Nice, I have now increase tx-power. However, without my patch I still have no adhoc network⦠
Edit: @frank-w Could you maybe also ACK that on the wireless mailing list?
I cannot test mesh as i use only normal ac (mt7612)/bgn (r2 ap0).
If you give me some advice (hostapd config+how to test if mesh is working) i can test with mt7615 in second r2 + r64 with mt7622 wifi
To test unencrypted mesh you donβt need hostapd nor wpa_supplicant. You can create the mesh interface and join/create network using iw util.
For encrypted mesh (SAE) you do need wpa_supplicant.
hostapd is not used for mesh interfaces at all, unless you want combined Mesh+AP on the same radio, in that case you do need hostapd for the AP part and quite a bit of extra magic (see OpenWrt patches).
can you post the iw commands to create meshpoint and mesh client (connecting my 2 devices) and show commands to verify mesh works?
Can you point me to these openwrt patches?
Here is a good explanation: https://wiki.archlinux.org/title/ad-hoc_networking
iw wlan0 set type ibss
ip link set wlan0 up
iw interface ibss join bpi-mesh 2412
Now you should already see in a scan the other pi.
For 802.11s mesh mode itβs similar, just use type mesh instead of of type ibss and mesh join instead of ibss join.
root@bpi-r2:~# iw wlp1s0 set type ibss
root@bpi-r2:~# ip link set wlp1s0 up
RTNETLINK answers: Input/output error
root@bpi-r2:~# dmesg | grep wlp1s0
[ 15.208512] mt7615e 0000:01:00.0 wlp1s0: renamed from wlan0
root@bpi-r2:~# uname -a
Linux bpi-r2 5.15.0-rc4-bpi-r2 #1 SMP Sat Oct 16 20:43:57 CEST 2021 armv7l GNU/Linux
with patch
I think you probably have already an instance of wpa_supplicant running (usually this happens when people forget that NetworkManager takes care of all their interfaces and they will either have to stop NetworkManager or use NetworkManager for all configurationβ¦)
Do you try to do this with banana pi r2? I thought it has a different wifi card?
It is my r2,using mt7615 card.but not interal wifi (ap0)
and no wpa_supplicant/ hostapd runningβ¦but network-config done with systemd
tried stopping it, but error comes again
root@bpi-r2:~# service systemd-networkd stop
Warning: Stopping systemd-networkd.service, but it can still be activated by:
systemd-networkd.socket
root@bpi-r2:~#
maybe i need to set ip address first?
edit: wpa_supplicant is not installed in my (nearly fresh) bullseye image, hostapd is installed, but not running. i got the same error without the patchβ¦so at least not related to the patchβ¦
