Yurannich
(Yurannich)
Hi all! I want to use MA5671A SFP ONU in bpi-r4 but cannot connect via pppoe session
logread says, that:
Tue May 21 11:26:40 2024 daemon.warn pppd[5189]: Timeout waiting for PADO packets
Tue May 21 11:26:40 2024 daemon.err pppd[5189]: Unable to complete PPPoE Discovery
Tue May 21 11:26:40 2024 daemon.info pppd[5189]: Exit.
Tue May 21 11:26:40 2024 daemon.info pppd[5295]: Plugin pppoe.so loaded.
Tue May 21 11:26:40 2024 daemon.info pppd[5295]: PPPoE plugin from pppd 2.4.9
Tue May 21 11:26:40 2024 daemon.notice pppd[5295]: pppd 2.4.9 started by root, uid 0
frank-w
(Frank W.)
2
Which image/version do you use?
Vendor image seems to have this issue
Yurannich
(Yurannich)
3
I use an openwrt latest snapshot
Yurannich
(Yurannich)
4
Worked only with vlan:
Wed May 22 06:41:54 2024 daemon.info pppd[3410]: Plugin pppoe.so loaded.
Wed May 22 06:41:54 2024 daemon.info pppd[3410]: PPPoE plugin from pppd 2.4.9
Wed May 22 06:41:55 2024 daemon.notice pppd[3410]: pppd 2.4.9 started by root, uid 0
Wed May 22 06:42:05 2024 daemon.info pppd[3410]: PPP session is 314
Wed May 22 06:42:05 2024 daemon.warn pppd[3410]: Connected to ****** via interface eth2.22
Wed May 22 06:42:05 2024 daemon.info pppd[3410]: Using interface pppoe-WAN_SFP
Wed May 22 06:42:05 2024 daemon.notice pppd[3410]: Connect: pppoe-WAN_SFP <--> eth2.22
Wed May 22 06:42:08 2024 daemon.notice pppd[3410]: PAP authentication succeeded
Wed May 22 06:42:08 2024 daemon.notice pppd[3410]: peer from calling number ***** authorized
Wed May 22 06:42:08 2024 daemon.notice pppd[3410]: local IP address *****
Wed May 22 06:42:08 2024 daemon.notice pppd[3410]: remote IP address *****
Wed May 22 06:42:08 2024 daemon.notice pppd[3410]: primary DNS address ****
Wed May 22 06:42:08 2024 daemon.notice pppd[3410]: secondary DNS address ****
Wed May 22 06:42:08 2024 daemon.notice netifd: Network device 'pppoe-WAN_SFP' link is up
frank-w
(Frank W.)
5
Which kernelversion? Maybe you can look if ppe patch is there and try after dropping it? Or does your ISP require the vlan (like mine)
I am the law
I mean ISP. I am try drop patch and write here after that. Kernel 6.6.30
Yurannich
(Yurannich)
7
If you remove the patch, nothing changes.
frank-w
(Frank W.)
8
Ok,thanks for testing,was worth a try…
Have you enabled some kind of hardware acceleration? If yes try without it
Yurannich
(Yurannich)
9
Okay, I’ll try and post the results here
