Rtl8822cs sdio board on M5
syntax error near unexpected token `then’
Not sure, but is your bash shell available? And the build is done through docker right?
I am not using docker, I build on Ubuntu 22.10 and I expect Bash is available. The only strange thing is that the build process request root password !
I migrate my PC to Ubuntu 23.04 and the build process terminated fine. The patch seems integrated well during build.
Now I will try to boot the board with this build.
I will let you know the next step.
Gérard
@boyi Thanks the board boot this build , it works on EMMC and the device wlan0 is there. Now I will configure and check that the device driver is stable. Gerard
@gege_fr My pleasure. That’s really good to know.
Regards.
I try to move my M5 board and its rtl8822cd board (sdio) to bookworm 24.2 build. After some research I discover that the sdio board has been integrate in the build and after adding
overlay_prefix=meson-sm1-bananapi-m5 overlays=rtl8822cs
to /boot/armbianEnv.txt and 88x2cs to /etc/modules
the interface seems recognized by Linux
root@bananapim5:/etc# iw dev phy#0 Interface wlan0 ifindex 3 wdev 0x1 addr 68:4e:05:f1:ac:2d type managed txpower -100.00 dBm root@bananapim5:/etc# 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 2: end0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP mode DEFAULT group default qlen 1000 link/ether 56:10:9e:9d:62:da brd ff:ff:ff:ff:ff:ff 3: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc mq state DOWN mode DEFAULT group default qlen 1000 link/ether 68:4e:05:f1:ac:2d brd ff:ff:ff:ff:ff:ff root@bananapim5:/etc#
As i can’t start the AP mode I try in client mode and the board works and connects a SSID.
After further investigations and comparaisons with 22. release, I saw the /lib/crda directory was missing in 24.2 distro and I copy it from 22.
dispit all my research I am blocked and can’t start hostapd.
I try the manual start of hostapdand got an error 47
root@bananapim5:/etc# sudo hostapd -d /etc/hostapd.conf random: getrandom() support available Configuration file: /etc/hostapd.conf ctrl_interface_group=0 nl80211: Supported cipher 00-0f-ac:1 nl80211: Supported cipher 00-0f-ac:5 nl80211: Supported cipher 00-0f-ac:2 nl80211: Supported cipher 00-0f-ac:4 nl80211: Supported cipher 00-0f-ac:6 nl80211: Supported cipher 00-0f-ac:8 nl80211: Supported cipher 00-0f-ac:9 nl80211: Supported cipher 00-0f-ac:10 nl80211: Supported cipher 00-0f-ac:11 nl80211: Supported cipher 00-0f-ac:12 nl80211: Supported cipher 00-0f-ac:13 nl80211: Supported vendor command: vendor_id=0x1a11 subcmd=4106 nl80211: Supported vendor command: vendor_id=0x1a11 subcmd=4107 nl80211: key_mgmt=0xf0f enc=0xfef auth=0x7 flags=0xa0058c0 rrm_flags=0x0 probe_resp_offloads=0x0 max_stations=0 max_remain_on_chan=5000 max_scan_ssids=9 nl80211: interface wlan0 in phy phy0 nl80211: Set mode ifindex 3 iftype 3 (AP) nl80211: Setup AP(wlan0) - device_ap_sme=1 use_monitor=0 nl80211: Subscribe to mgmt frames with AP handle 0xaaaae4195af0 (device SME) nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae4195af0 match=04 multicast=0 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae4195af0 match=0501 multicast=0 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae4195af0 match=0503 multicast=0 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae4195af0 match=0504 multicast=0 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae4195af0 match=06 multicast=0 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae4195af0 match=08 multicast=0 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae4195af0 match=09 multicast=0 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae4195af0 match=0a multicast=0 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae4195af0 match=11 multicast=0 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae4195af0 match=12 multicast=0 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae4195af0 match=7f multicast=0 nl80211: Register frame type=0xb0 (WLAN_FC_STYPE_AUTH) nl_handle=0xaaaae4195af0 match= multicast=0 nl80211: Enable Probe Request reporting nl_preq=0xaaaae419e4b0 nl80211: Register frame type=0x40 (WLAN_FC_STYPE_PROBE_REQ) nl_handle=0xaaaae419e4b0 match= multicast=0 rfkill: initial event: idx=0 type=1 op=0 soft=0 hard=0 nl80211: Add own interface ifindex 3 (ifidx_reason -1) nl80211: if_indices[16]: 3(-1) phy: phy0 BSS count 1, BSSID mask 00:00:00:00:00:00 (0 bits) wlan0: interface state UNINITIALIZED->COUNTRY_UPDATE Previous country code 00, new country code FR Continue interface setup after channel list update ctrl_iface not configured! RTM_NEWLINK: ifi_index=3 ifname=wlan0 operstate=2 linkmode=0 ifi_family=0 ifi_flags=0x1003 ([UP]) Channel list update timeout - try to continue anyway nl80211: Regulatory information - country=00 nl80211: 2402-2472 @ 40 MHz 20 mBm nl80211: 2457-2482 @ 20 MHz 20 mBm (no IR) nl80211: 2474-2494 @ 20 MHz 20 mBm (no OFDM) (no IR) nl80211: 5170-5250 @ 80 MHz 20 mBm (no IR) nl80211: 5250-5330 @ 80 MHz 20 mBm (DFS) (no IR) nl80211: 5490-5730 @ 160 MHz 20 mBm (DFS) (no IR) nl80211: 5735-5835 @ 80 MHz 20 mBm (no IR) nl80211: 57240-63720 @ 2160 MHz 0 mBm nl80211: Added 802.11b mode based on 802.11g information nl80211: Mode IEEE 802.11g: 2412 2417 2422 2427 2432 2437 2442 2447 2452 2457 2462 2467[NO_IR] 2472[NO_IR] 2484[DISABLED] nl80211: Mode IEEE 802.11a: 5180 5200 5220 5240 5260[NO_IR][RADAR] 5280[NO_IR][RADAR] 5300[NO_IR][RADAR] 5320[NO_IR][RADAR] 5500[NO_IR][RADAR] 5520[NO_IR][RADAR] 5540[NO_IR][RADAR] 5560[NO_IR][RADAR] 5580[NO_IR][RADAR] nl80211: Mode IEEE 802.11b: 2412 2417 2422 2427 2432 2437 2442 2447 2452 2457 2462 2467[NO_IR] 2472[NO_IR] 2484[DISABLED] ACS: Automatic channel selection started, this may take a bit ACS: Scanning 1 / 5 wlan0: nl80211: scan request nl80211: Passive scan requested Scan requested (ret=0) - scan timeout 10 seconds wlan0: interface state COUNTRY_UPDATE->ACS wlan0: ACS-STARTED Interface initialization will be completed in a callback (ACS) nl80211: Drv Event 33 (NL80211_CMD_TRIGGER_SCAN) received for wlan0 wlan0: nl80211: Scan trigger wlan0: Event SCAN_STARTED (47) received Unknown event 47 RTM_NEWLINK: ifi_index=3 ifname=wlan0 wext ifi_family=0 ifi_flags=0x1003 ([UP]) nl80211: Drv Event 34 (NL80211_CMD_NEW_SCAN_RESULTS) received for wlan0 wlan0: nl80211: New scan results available nl80211: Scan included frequencies: 2412 2417 2422 2427 2432 2437 2442 2447 2452 2457 2462 wlan0: Event SCAN_RESULTS (3) received ACS: Using survey based algorithm (acs_num_scans=5) nl80211: Fetch survey data wlan0: Event SURVEY (46) received No survey data received ACS: Scanning 2 / 5 wlan0: nl80211: scan request nl80211: Passive scan requested Scan requested (ret=0) - scan timeout 30 seconds nl80211: Drv Event 33 (NL80211_CMD_TRIGGER_SCAN) received for wlan0 wlan0: nl80211: Scan trigger wlan0: Event SCAN_STARTED (47) received Unknown event 47 RTM_NEWLINK: ifi_index=3 ifname=wlan0 wext ifi_family=0 ifi_flags=0x1003 ([UP]) nl80211: Drv Event 34 (NL80211_CMD_NEW_SCAN_RESULTS) received for wlan0 wlan0: nl80211: New scan results available nl80211: Scan included frequencies: 2412 2417 2422 2427 2432 2437 2442 2447 2452 2457 2462 wlan0: Event SCAN_RESULTS (3) received ACS: Using survey based algorithm (acs_num_scans=5) nl80211: Fetch survey data wlan0: Event SURVEY (46) received No survey data received ACS: Scanning 3 / 5 wlan0: nl80211: scan request nl80211: Passive scan requested Scan requested (ret=0) - scan timeout 30 seconds nl80211: Drv Event 33 (NL80211_CMD_TRIGGER_SCAN) received for wlan0 wlan0: nl80211: Scan trigger wlan0: Event SCAN_STARTED (47) received Unknown event 47 RTM_NEWLINK: ifi_index=3 ifname=wlan0 wext ifi_family=0 ifi_flags=0x1003 ([UP]) nl80211: Drv Event 34 (NL80211_CMD_NEW_SCAN_RESULTS) received for wlan0 wlan0: nl80211: New scan results available nl80211: Scan included frequencies: 2412 2417 2422 2427 2432 2437 2442 2447 2452 2457 2462 wlan0: Event SCAN_RESULTS (3) received ACS: Using survey based algorithm (acs_num_scans=5) nl80211: Fetch survey data wlan0: Event SURVEY (46) received No survey data received ACS: Scanning 4 / 5 wlan0: nl80211: scan request nl80211: Passive scan requested Scan requested (ret=0) - scan timeout 30 seconds nl80211: Drv Event 33 (NL80211_CMD_TRIGGER_SCAN) received for wlan0 wlan0: nl80211: Scan trigger wlan0: Event SCAN_STARTED (47) received Unknown event 47 RTM_NEWLINK: ifi_index=3 ifname=wlan0 wext ifi_family=0 ifi_flags=0x1003 ([UP]) nl80211: Drv Event 34 (NL80211_CMD_NEW_SCAN_RESULTS) received for wlan0 wlan0: nl80211: New scan results available nl80211: Scan included frequencies: 2412 2417 2422 2427 2432 2437 2442 2447 2452 2457 2462 wlan0: Event SCAN_RESULTS (3) received ACS: Using survey based algorithm (acs_num_scans=5) nl80211: Fetch survey data wlan0: Event SURVEY (46) received No survey data received ACS: Scanning 5 / 5 wlan0: nl80211: scan request nl80211: Passive scan requested Scan requested (ret=0) - scan timeout 30 seconds nl80211: Drv Event 33 (NL80211_CMD_TRIGGER_SCAN) received for wlan0 wlan0: nl80211: Scan trigger wlan0: Event SCAN_STARTED (47) received Unknown event 47 RTM_NEWLINK: ifi_index=3 ifname=wlan0 wext ifi_family=0 ifi_flags=0x1003 ([UP]) nl80211: Drv Event 34 (NL80211_CMD_NEW_SCAN_RESULTS) received for wlan0 wlan0: nl80211: New scan results available nl80211: Scan included frequencies: 2412 2417 2422 2427 2432 2437 2442 2447 2452 2457 2462 wlan0: Event SCAN_RESULTS (3) received ACS: Using survey based algorithm (acs_num_scans=5) nl80211: Fetch survey data wlan0: Event SURVEY (46) received No survey data received ACS: Trying survey-based ACS ACS: Unable to collect survey data ACS: All study options have failed Interface initialization failed wlan0: interface state ACS->DISABLED wlan0: AP-DISABLED ACS: Possibly channel configuration is invalid, please report this along with your config file. ACS: Failed to start wlan0: AP-DISABLED wlan0: Deauthenticate all stations nl80211: sta_remove → DEL_STATION wlan0 ff:ff:ff:ff:ff:ff → -22 (Invalid argument) hostapd_free_hapd_data: Interface wlan0 wasn’t started hostapd_deinit_driver: driver=0xaaaabe74e5a0 drv_priv=0xaaaae4198f20 → hapd_deinit nl80211: deinit ifname=wlan0 disabled_11b_rates=0 nl80211: Disable Probe Request reporting nl_preq=0x888822226c916c39 nl80211: Remove monitor interface: refcount=0 nl80211: Remove beacon (ifindex=3) netlink: Operstate: ifindex=3 linkmode=0 (kernel-control), operstate=6 (IF_OPER_UP) nl80211: Set mode ifindex 3 iftype 2 (STATION) nl80211: Teardown AP(wlan0) - device_ap_sme=1 use_monitor=0 nl80211: Unsubscribe mgmt frames handle 0x888822226c91d279 (AP teardown (dev SME)) hostapd_deinit_driver:bss[0]->drv_priv=0xaaaae4198f20 hostapd_cleanup_iface_partial(0xaaaae41939e0) Interface wlan0 disabled wlan0: interface state DISABLED->DISABLED hostapd_interface_deinit_free(0xaaaae41939e0) hostapd_interface_deinit_free: num_bss=1 conf->num_bss=1 hostapd_interface_deinit(0xaaaae41939e0) wlan0: interface state DISABLED->DISABLED hostapd_bss_deinit: deinit bss wlan0 wlan0: AP-DISABLED hostapd_cleanup(hapd=0xaaaae4196940 (wlan0)) wlan0: CTRL-EVENT-TERMINATING hostapd_free_hapd_data: Interface wlan0 wasn’t started hostapd_interface_deinit_free: driver=0xaaaabe74e5a0 drv_priv=(nil) → hapd_deinit hostapd_interface_free(0xaaaae41939e0) hostapd_interface_free: free hapd 0xaaaae4196940 hostapd_cleanup_iface(0xaaaae41939e0) hostapd_cleanup_iface_partial(0xaaaae41939e0) hostapd_cleanup_iface: free iface=0xaaaae41939e0 root@bananapim5:/etc#
Have you some suggestions or experiences on this kind of issue.
thanks in advance
kind regards
A readable version of terminal cut and past in the previous message.
phy#0
	Interface wlan0
		ifindex 3
		wdev 0x1
		type managed
		txpower -100.00 dBm
root@bananapim5:/etc# ip link
phy: phy0
ACS: Scanning 1 / 5
wlan0: ACS-STARTED
Unknown event 47
ACS: Scanning 2 / 5
Unknown event 47
ACS: Scanning 3 / 5
Unknown event 47
ACS: Scanning 4 / 5
Unknown event 47
ACS: Scanning 5 / 5
Unknown event 47
wlan0: AP-DISABLED
wlan0: AP-DISABLED
nl80211: sta_remove -> DEL_STATION wlan0 ff:ff:ff:ff:ff:ff --> -22 (Invalid argument)
hostapd_free_hapd_data: Interface wlan0 wasn't started
hostapd_deinit_driver: driver=0xaaaabe74e5a0 drv_priv=0xaaaae4198f20 -> hapd_deinit
wlan0: AP-DISABLED
hostapd_interface_deinit_free: driver=0xaaaabe74e5a0 drv_priv=(nil) -> hapd_deinit
