Now this is available for BPI-R64/R3/R3mini/R4.
The files can be found here:
https://ftp.woudstra.mywire.org/uartboot/
Find the correct mtk_uartboot
executable for your system. I have build files for the R64, R3, R3mini, R4. Only the R3 is tested at the moment.
Make sure you have socat installed, edit /dev/ttyXXXX (twice), and run :
sudo ./mtk_uartboot -p uart-bpir3m-atf.bin -f uart-bpir3m-fip.bin --aarch64 -s /dev/ttyUSB0
Or
sudo bash -c "./mtk_uartboot -p uart-bpir3m-atf.bin -f uart-bpir3m-fip.bin --aarch64 -s /dev/ttyUSB0 ; socat - /dev/ttyUSB0,raw,echo=0,b115200"
The fip file is quite large, so get a cup of coffee when uploading it to the R3mini.
It has my standard archlinuxarm initrd for emmc inside, which drops to a bash shell. The initrd can run my installscript and/or debootstrap. First setup your internet connection on eth0 or any other interface (defaults to wan):
bpir-dhcpc eth0
Now youâre ready to use âbpir-buildâ âbpir-toolboxâ âdebootstrapâ âwgetâ âcurlâ ânanoâ âpartedâ âmkfs-btrfsâ âtarâ âxzâ âgzipâ âzstdâ, etc, etc.
You could use:
bpir-toolbox --nand-format
It will download necessary files and install uboot on nand. This version of U-Boot uses the standard distroboot and is setup to scan sd/emmc - nvme - nand, for extlinux.conf in this order. Need to have the boot flag set on the partition where this file can be found. If nothing is found on sd/emmc/nvme, it loads the same rescue initrd, but now from nand.
I need to add more documentation about âbpir-toolboxâ, but you can look into the file to see which options to use. âbpir-buildâ to install on nvme is added pretty recently also, so also needs documentation and testing.
Run
bpir-build -F
and go through menu to install on nvme
