I just started to configure openwrt and I noticed that I cannot enable wifi:
root@OpenWrt:/# uci show wireless
uci: Entry not found
I also think that there is something odd in logs:
[ 36.454476] /../mt_wifi/embedded/mcu/andes_core.c:956 assert FALSEfailed
[ 36.461165] CPU: 0 PID: 4331 Comm: ifconfig Tainted: P 5.4.171 #0
[ 36.468709] Hardware name: Bananapi BPI-R3 (DT)
[ 36.473220] Call trace:
[ 36.475657] dump_backtrace+0x0/0x120
[ 36.479302] show_stack+0x14/0x20
[ 36.482603] dump_stack+0xb4/0xf4
[ 36.486099] AndesSendCmdMsg+0x764/0xdb8 [mt_wifi]
[ 36.491001] chip_cmd_tx+0x40/0x50 [mt_wifi]
[ 36.495330] MtCmdFwStartReq+0xc4/0x160 [mt_wifi]
[ 36.500084] ShowHeraRelatedInfoProc+0xed0/0x2880 [mt_wifi]
[ 36.505704] mt_load_fw+0x10c/0x2f0 [mt_wifi]
[ 36.510111] NICLoadFirmware+0xc/0x18 [mt_wifi]
[ 36.514690] WfMcuInit+0x184/0x410 [mt_wifi]
[ 36.519011] WfInit+0x5c/0x290 [mt_wifi]
[ 36.522984] mt_wifi_init+0x338/0x688 [mt_wifi]
[ 36.527564] mt_wifi_open+0x114/0x218 [mt_wifi]
[ 36.532145] virtual_if_init_handler+0x40/0xa8 [mt_wifi]
[ 36.537504] RTMP_COM_IoctlHandle+0x87c/0x19c8 [mt_wifi]
[ 36.542865] main_virtual_if_open+0x8c/0x1c0 [mt_wifi]
[ 36.547987] __dev_open+0xcc/0x150
[ 36.551372] __dev_change_flags+0x134/0x198
[ 36.555537] dev_change_flags+0x20/0x60
[ 36.559356] devinet_ioctl+0x3e8/0x748
[ 36.563089] inet_ioctl+0x1f4/0x370
[ 36.566562] sock_do_ioctl+0x48/0x2c0
[ 36.570208] sock_ioctl+0x318/0x518
[ 36.573682] do_vfs_ioctl+0xa4/0xb28
[ 36.577240] ksys_ioctl+0x44/0x90
[ 36.580539] __arm64_sys_ioctl+0x1c/0xb8
[ 36.584446] el0_svc_common.constprop.2+0x7c/0x110
[ 36.589219] el0_svc_handler+0x20/0x80
[ 36.592951] el0_svc+0x8/0x1c8
[ 36.596017] WiFi@C03L1,load_fw_v1() 888: load fw fail
[ 36.601058] WiFi@C03L1,mt_load_fw() 1344: fw download fail
[ 37.585367] 8021q: adding VLAN 0 to HW filter on device lan5
[ 37.621976] 7986@C12L1ra0,rt28xx_ap_ioctl() 870: interface is down, cmd [8be2] return!!!
[ 37.631135] 7986@C12L1ra0,rt28xx_ap_ioctl() 870: interface is down, cmd [8be2] return!!!
[ 37.643459] 7986@C12L1ra0,rt28xx_ap_ioctl() 870: interface is down, cmd [8be2] return!!!
[ 37.652431] 7986@C12L1ra0,rt28xx_ap_ioctl() 870: interface is down, cmd [8be2] return!!!
[ 37.661454] 7986@C12L1ra0,rt28xx_ap_ioctl() 870: interface is down, cmd [8be2] return!!!
[ 37.692205] 7986@C12L1ra0,rt28xx_ap_ioctl() 870: interface is down, cmd [8be2] return!!!
[ 37.715679] br-lan: port 1(lan1) entered disabled state
[ 37.726334] mt7530 mdio-bus:1f lan1: configuring for phy/gmii link mode
more logs here: https://pastebin.com/Szuz6qHk and here: https://pastebin.com/sAFNp6SA
I am tried booting from sdcard(image from Banana Pi BPI-R3 OpenWRT image), nand, and nor. Always the same. I am running OpenWrt 21.02-SNAPSHOT
What could be the reason?
