yelvlab
(Hao Wang)
April 9, 2019, 12:01pm
I burned R2’s Openwrt 18.06 image, but after I booted it, I found that I couldn’t install the software via opkg. The configuration I changed would be overwritten after the reboot. How can I handle this?
Installing curl (7.60.0-3) to root...
Collected errors:
* verify_pkg_installable: Only have 0kb available on filesystem /overlay, pkg curl needs 44
* opkg_install_cmd: Cannot install package curl.
frank-w
(Frank W.)
April 9, 2019, 2:12pm
2
you need a kind of overlayfs (or squashfs)…
maybe this helps: Bpir2wrt Openwrt-Fork for BPI-R2
yelvlab
(Hao Wang)
April 10, 2019, 1:05am
3
Hi,frank
Thank you very much, let me try to do something
yelvlab
(Hao Wang)
April 10, 2019, 3:25am
4
+ OUTPUT_FILE=/home/hulk/disk/BPI-R2-openwrt/openwrt/build_dir/target-arm_cortex-a7+neon-vfpv4_musl_eabi/linux-mediatek_mt7623/mtk-bpi-r2-SD.img
+ PRELOADER_FILE=/home/hulk/disk/BPI-R2-openwrt/openwrt/staging_dir/target-arm_cortex-a7+neon-vfpv4_musl_eabi/image/mtk-bpi-r2-preloader-sd.bin
+ UBOOT_FILE=/home/hulk/disk/BPI-R2-openwrt/openwrt/staging_dir/target-arm_cortex-a7+neon-vfpv4_musl_eabi/image/mtk-bpi-r2-uboot.bin
+ KERNEL_FILE=/home/hulk/disk/BPI-R2-openwrt/openwrt/build_dir/target-arm_cortex-a7+neon-vfpv4_musl_eabi/linux-mediatek_mt7623/tmp/openwrt-mediatek-mt7623-7623n-bananapi-bpi-r2-initramfs-kernel.bin
+ ROOTFS_FILE=/home/hulk/disk/BPI-R2-openwrt/openwrt/build_dir/target-arm_cortex-a7+neon-vfpv4_musl_eabi/linux-mediatek_mt7623/root.squashfs
+ BS=1024
+ PRELOADER_OFFSET=0
+ UBOOT_OFFSET=320
+ KERNEL_OFFSET=2048
+ ROOTFS_OFFSET=67584
+ dd bs=1024 if=/home/hulk/disk/BPI-R2-openwrt/openwrt/staging_dir/target-arm_cortex-a7+neon-vfpv4_musl_eabi/image/mtk-bpi-r2-preloader-sd.bin of=/home/hulk/disk/BPI-R2-openwrt/openwrt/build_dir/target-arm_cortex-a7+neon-vfpv4_musl_eabi/linux-mediatek_mt7623/mtk-bpi-r2-SD.img seek=0
dd: failed to open '/home/hulk/disk/BPI-R2-openwrt/openwrt/staging_dir/target-arm_cortex-a7+neon-vfpv4_musl_eabi/image/mtk-bpi-r2-preloader-sd.bin': No such file or directory
Makefile:70: recipe for target 'install-images' failed
make[5]: *** [install-images] Error 1
make[5]: Leaving directory '/home/hulk/disk/BPI-R2-openwrt/openwrt/target/linux/mediatek/image'
Makefile:19: recipe for target 'install' failed
make[4]: *** [install] Error 2
make[4]: Leaving directory '/home/hulk/disk/BPI-R2-openwrt/openwrt/target/linux/mediatek'
Makefile:13: recipe for target 'install' failed
make[3]: *** [install] Error 2
make[3]: Leaving directory '/home/hulk/disk/BPI-R2-openwrt/openwrt/target/linux'
time: target/linux/install#32.43#5.90#44.75
target/Makefile:23: recipe for target 'target/linux/install' failed
make[2]: *** [target/linux/install] Error 2
make[2]: Leaving directory '/home/hulk/disk/BPI-R2-openwrt/openwrt'
target/Makefile:19: recipe for target '/home/hulk/disk/BPI-R2-openwrt/openwrt/staging_dir/target-arm_cortex-a7+neon-vfpv4_musl_eabi/stamp/.target_install' failed
make[1]: *** [/home/hulk/disk/BPI-R2-openwrt/openwrt/staging_dir/target-arm_cortex-a7+neon-vfpv4_musl_eabi/stamp/.target_install] Error 2
make[1]: Leaving directory '/home/hulk/disk/BPI-R2-openwrt/openwrt'
/home/hulk/disk/BPI-R2-openwrt/openwrt/include/toplevel.mk:216: recipe for target 'world' failed
make: *** [world] Error 2
sone errors,I don’t know, how can I get rid of these mistakes?
frank-w
(Frank W.)
April 10, 2019, 8:43am
5
you miss the preloader file (maybe not present in the github because of .gitignore), but you can get it on official repo
maybe don’t use it…
as gary said: do not use mtk-bpi-r2-preloader-sd.bin…
you can try to move back with
git checkout commit-id
commit-overview
e.g. using 51b0bac as commit-id
the right one seems to be this: https://github.com/BPI-SINOVOIP/BPI-R2-LEDE-Uboot/tree/master/bpi_r2_preloader (for SD) see this commit:
https://github.com/garywangcn/bpi-r2_lede/commit/b1d4a37d92d992e10a29611a244d817428e3bc7d
