Powering BPI-P2 Pro with internal battery
I’m using the BPI-P2 Pro for a compact device and would like to know if it’s possible to power it using an internal battery directly on the board (UPS-style), without using USB-C and without external cables.
From the documentation, I see:
  • Power is normally via PoE or USB-C
  • The 12-pin header exposes GPIO/interfaces, but I don’t see a clear 5V power input for the board
My question:
  • Is there any on-board pin/header/test point intended to power the board from a regulated 5V source (battery + UPS circuit)?
Thanks for your clarification.
By using a type C adapter that meets the 5V/2A specification, you can power the P2Pro.
Thank you for your replay. My goal is to power the board with on-board power without using external power (TYPE C).
OK, but this board does not have an onboard battery designed.
Try to look at Hardware issue with 5V output at GPIO port
