Power over Ethernet on R64?
I read that the Banana Pi R64 has Power over Ethernet capability. If so is that for receiving power or both being powered and powering? I was wondering if I could power another device via PoE using the R64 if the other device has a PoE hat?
Also, if it does support PoE could the connect handle data at the same time?
Thanks,
Aaron
yes ,bue you need buy PoE module.
https://wiki.banana-pi.org/Banana_Pi_BPI-R64#PoE_support
Ah ok! Does that need to be connected itself to ethernet to both the main R64 then the other device?
no ,just DIP PoE module on board ,so it support PoE function
BPI-R64%20PoE
