OpenWrt images for R4 Pro
Sorry, forgot to ask - does the image you kindly produced have wireless drivers for the BE14 module? I’ve got that also,
Please try without be14 for now,i use same config as 8x only added i2c,usband pci utils
A) OK, I’ll turn off the power switch. Or, do I need to physically remove it? B) To eliminate the SD card flashing as an issue, could you possibly generate a sysupgrade image I could flash please?
Many thanks again.
Just boot again same card without be14 mounted
Good afternoon @Dav1Dav, here’s a thread with the error you’re experiencing.
The best way is to use the images from @wozi; this will almost never happen to you.
releases
Secondly, check out my reply and my homemade video. It solves the red light problem: turn off the board, when the menu appears count to two, then turn the board back on. As long as you don’t disconnect the power cable, it won’t happen again. Anyway, use the images from @wozi; this hardly ever happens.
I hope this helps.
Seems there is a fixing patch for the crash…if i have it i can add to openwrt.
