which ND proxy do you use here (and how does this work, i only know the “normal” way to have an own /64 on each subnet and radvd for advertising it)? have not done much with ipv6. i have a /48 over tunnelbroker.net, so i have enough subnets for using radvd…by default somebody get a /64 first and after a while (collecting points) a larger subnet can be “purchased” with these points, like i did some time ago
Oh yeah, I remember playing the HE IPv6 qualification game a long time ago. By now, most commercial private VDSL and DOCSIS connections I’ve seen already provide native IPv6 and usually delegate /64 or even /56 to the CPE.
ND proxy is a Linux kernel feature (like ARP proxy on v4), you can enable that using sysctl. In OpenWrt we got our own IPv6 management stack (as ISC stack would be overkill and dnsmasq doesn’t allow doing IPv6 delegation properly). See
Do you mean sysctl featue e.g net.ipv6.conf.wan.proxy_ndp = 1, and ip -6 neigh add proxy <client_ipv6_addr> dev <wan>?
It’s quite inconvenient to use unless you use static ip for every client, or your ipv6 management tracks any client and it’s ip.
For general purpose linux distro i used ndppd.
As far as Alex debugged it,problem with slowdown is here:
https://elixir.bootlin.com/linux/v5.12-rc6/source/lib/rhashtable.c#L429
Maybe static size hashtable is better?
I’ve found (i hope
) a typo in rhashtable_params definition that is likely causes halts and slow-downs.
For now i’m testing this patch - looks great after 40mins. Previously problems has started after 15-30 min, depends on traffic.
Nice, head_offset was defined twice
Also lookup should use key, not head, and it uses cookie.
Can you test it on 5.10? If not - i can, but a bit later. @graphine can you also test it?
P.S. my R2 uptime is 1:21 - far away beyond previous maximum.
Is the patch above enough? I’ve added it to my repo in 5.12 and 5.10 (hnat-branches)
Btw. I rebased my 5.12 trees (add mt6625l patches to rc, updated it to rc6 and rebased hnat onto rc)
i see you did conversion from mutex to spinlock…but this does not fixed anything right? was this preinitialized? as i see no DEFINE_SPINLOCK() and no spin_lock_init()
had run 50 iterations of iperf3 without slowdown (100mbit only till now)
On 1gbit/s i see throughput of ~850 mbit with 10-30 retransmitts each round, no cpu usage on test-r2 (main-r2 where iperf3 server is running is ~ 150% cpu, ksoftirq~90%+iperf3~55%). sometimes i see connection refused (on 1G only) on starting new round (round 4,50)… iperf_hnat.log (59,9 KB)
seems like the connection reset is fixed by a sleep 1
( for i in {1..50};do echo "======== ROUND $i ========"; iperf3 -c 192.168.0.10;sleep 1;done ) 2>&1 | tee -a ~/iperf_hnat_sleep.log
iperf_hnat_sleep.log (62,3 KB)
the retransmitts can be there because of a ~25m cable between my switch and main-r2 (inside wall)
with second laptop i still see retransmitts (maybe switch-config) but a throughput of ~930Mbit/s, checked switchconfig, enabled flowcontrol-auto-neg for port of second laptop, but still same retransmitts, but no slowdown…after ~150 iterations (~930 Mbit,20-35 retransmitts each round), test-r2 is up now 3h30m
last 2 iperf-sessions iperf_hnat_sleep2.log (62,3 KB) iperf_hnat_sleep.log (187,1 KB)
if i do iperf3 between client-laptop and test-r2, i see no retransmitts, test-r2 to iperf-server-laptop, have <10 retransmitts in each full round. so retransmitts seem to caused by hnat, but not that much
It doesn’t fix anything, so we likely don’t need it, or mutex. I use spinlock defined in rhashtable, spin_lock_init is here:
https://elixir.bootlin.com/linux/v5.12-rc6/source/lib/rhashtable.c#L1027
P.S R2 uptime is 9:12 - still alive
did 250 iperf3-interations (~42Min) after last log, still stable, no hang…always 930Mbit/s, ~20-35 Retransmitts on each run (i guess laptops network cards do more than r2, but this is ok)
root@bpi-r2:~# uname -a
Linux bpi-r2 5.10.25-bpi-r2-hnat #1 SMP Sat Apr 10 13:36:00 CEST 2021 armv7l GNU/Linux
root@bpi-r2:~# uptime
19:37:19 up 5:04, 1 user, load average: 0.00, 0.00, 0.00
root@bpi-r2:~# nft --version
nftables v0.9.8 (E.D.S.)
root@bpi-r2:~#
iperf_hnat_sleep3.log.gz (22,0 KB)
so it looks like 5.10-hnat (including the 2 fixes: mutex+rhashtable_params) is stable enough for productive
root@bpi-r2:~# nft list ruleset
table ip filter {
flowtable f {
hook ingress priority filter + 10
devices = { lan3, lan0, wan }
flags offload;
chain input {
type filter hook input priority filter; policy accept;
chain output {
type filter hook output priority filter; policy accept;
chain forward {
type filter hook forward priority filter; policy accept;
ip protocol { tcp, udp } flow add @f
table ip nat {
chain post {
type nat hook postrouting priority filter; policy accept;
oifname "wan" masquerade
chain pre {
type nat hook prerouting priority filter; policy accept;
root@bpi-r2:~#
btw. i’ve noticed that nft reverts order of devices
have defined it as
devices = { wan, lan0, lan3 }
in file, and loaded with nft -f file
but it seems that https-connections are not nat’ed
in firewall i see sometimes my client-laptops-ip (192.168.90.x instead of the one from test-r2’s wan i see in iperf3), http/80 (e.g. this forum) goes over correctly…very strange…already rebooted test-r2…maybe firewall/routing-related
Applied to openwrt, seems previous issues are gone.
How did you measured re transmits?
See my iperf logs…
I see…
I’ve also tested for it:
9 rounds with offload: 2 attempts with retransmit (56 and 1); 7 attempts without it.
perf_hnat.log (11.6 КБ)
(slow speed because of wifi on a server, but R2-NAT is connected to wan and lan0)
Both cables are ~2m both links 1G
UPD:
I’ve also deleted spinlock/mutex patches - after fixing rhashtable_param seems to be functional w/o locks. (I’ll test it for a while)
You use 5.10 or 5.12? Afair 5.12 have patch for trgmii clock
Mhm,seems like i have it accidentally removed
https://patchwork.kernel.org/project/linux-mediatek/patch/[email protected]/
5.12 - Your branch with mutex rolled-back.
P.S. sometimes there are retransmits, but i also may have it with offload off.
Deng qingfang posted your fix
And there is another fix for ppe
tried to add flowtable to my router running 5.10-hnat
define iflan="lanbr0"
define ifwan="ppp8"
define ifoffload={$ifwan,$iflan}
table ip filter {
flowtable ft {
hook ingress priority filter + 10;
devices = $ifoffload;
flags offload;
# nft.sh
/usr/local/sbin/firewall/ruleset_new_v4+v6.nft:89:12-13: Error: Could not process rule: Operation not supported
flowtable ft {
if i remove the devices line, i got no error…i guess i need something to allow flowtable on ppp or bridge
but found nothing related ;(
if i hardcode the interfaces i got this:
/usr/local/sbin/firewall/ruleset_new_v4+v6.nft:93:14-19: Error: syntax error, unexpected quoted string, expecting string or '$'
devices = {"ppp8","lanbr0"};
if i leave the quotes, i got the “operation not supported” again
There are mentions of PPPoE in mtk_offload code (do you use it?), may be you should try to use wan interface, which is used for ppp instead of ppp?
Traffic is forwarded to ppp8,not to vlan or wan-port. I see patches for pppoe push and bridge support
so i guess problem is more in nft command,but found no device type check
http://git.netfilter.org/nftables/commit/src?id=92911b362e9067a9a335ac1a63e15119fb69a47d
