عمر_خالد
(عمر خالد)
January 5, 2026, 4:23pm
21
Hello, The Banana Pi BPI-R4 has never booted since first unboxing.
Current state:
Power LED red solid
Green LED solid
All LAN LEDs off
No Ethernet link
No serial output at all (completely silent)
Board appears powered but does not boot
Tested:
Multiple power supplies
Correct UART wiring (115200 8N1)
Boot with and without SD card
Multiple SD cards
Different OS images: Debian, OpenWrt, Ubuntu, Armbian
Result is always the same: no boot and no UART output.
frank-w
(Frank W.)
January 5, 2026, 4:45pm
22
How exactly have you connected uart? On photo it is not connected. Rx/tx need to be crossed,3.3v and gnd are necessary.
Afaik green led is only lighting when system booted to some state (based on image used).
عمر_خالد
(عمر خالد)
January 5, 2026, 6:30pm
23
HI @frank-w
UART wiring is confirmed:
TX/RX crossed, GND connected, 3.3V USB-TTL adapter.
Terminal: 115200 8N1, no flow control.
Tested again with NO SD card inserted.
Still absolutely no UART output (not a single character).
LAN LEDs remain off.
Green LED stays solid regardless of image or no SD.
This suggests the board never reaches BootROM stage.
frank-w
(Frank W.)
January 5, 2026, 9:12pm
24
You use the debug uart connector next to usb port? On photo this is not connected
عمر_خالد
(عمر خالد)
January 5, 2026, 9:24pm
25
I removed it to take a picture
ericwoud
(Eric W.)
January 5, 2026, 9:57pm
26
Holding the board like this i(specially at wintertime) you can kill it with static electricity.
FreddyS
(Freddy Solorzano)
January 8, 2026, 9:27pm
27
I just received my BPI R4 and it has the same condition. It’s dead. Can you check if a component underneath gets too hot as soon as you connect the board to power?
عمر_خالد
(عمر خالد)
January 9, 2026, 6:35pm
28
HI The component’s temperature is not normal.
hyf
(hyf9929)
January 14, 2026, 7:04am
29
What temperature range do your devices operate within approximately? The R4 board that is capable of functioning seems to have a relatively high temperature as well.
