Mali-450 support by lima
Maybe hotplug event affect or is it only for HDMI?
HDMI probe can write wakeup_register somewhere and enable GPU at same?
Can you try in 5.5-merged (or somewhere) execute read “devmem 0x1000301C”? I have not currently board at hands… It should read status bits from wakeup register.
Found this:
So wlan enable tweaks power_register. Your dmesg was 1s. before wmt init before lima success.
If it is needed, then I have not it enabled (yet)
Thanks found something from 2016:
+	/* Enable the smi-common's power and clocks */
+	ret = mtk_smi_enable(common);
+	if (ret)
+		return ret;
+	/* Enable the larb's power and clocks */
+	ret = mtk_smi_enable(&larb->smi);
So there is some power enable/disable framework in mtk chips. It needs to check if GPU is power down. And find correct mtk_smi_enable for GPU…
File is mtk-smi.c. SMI seems to be related ethernet(?). Not:
SMI(Smart Multimedia Interface) driver. This driver is responsible to enable/disable iommu and control the power domain and clocks of each local arbiter. Yong Wu / Mediatek
GPU is in AXI bus but peripheral controller (=power_register) is in some other bus.
extern int wmt_detect_ext_chip_pwr_on(void); extern int wmt_detect_ext_chip_pwr_off(void);
wmt_detect_chip_pwr_on (void)
COMBO_PMU_PIN, \
COMBO_RST_PIN, \
COMBO_WIFI_EINT_PIN);
some init logs:
_wmt_detect_set_output_mode(COMBO_PMU_PIN);
_wmt_detect_output_low(COMBO_PMU_PIN);
_wmt_detect_set_output_mode(COMBO_RST_PIN);
_wmt_detect_output_low(COMBO_RST_PIN);
GPIO_COMBO_PMU_EN_PIN
hmm.. in  hiteq8735a_tb_n.dts
gpio_combo_pmu_en_pin = <&pio 21 0>; /* 2) GPIO_COMBO_PMU_EN_PIN */
some else:
+#define GPIO_COMBO_PMU_EN_PIN         GPIOEXT13
+#define GPIO_COMBO_PMU_EN_PIN_M_GPIO  GPIO_MODE_00
+#define GPIO_COMBO_PMU_EN_PIN_M_EINT  GPIO_MODE_02
So no yet get definition in mt7623. It maybe posible it tweak GPU on, but also posible it dosn’t do that.
devmemX/devmem2 0x1000301C
00000FFF
So GPU is offline for sure.
devmem2 0x10003014 w 0x00000001
devmem2 0x1000301C
00000FFE
So GPU is posible to put online… Need modularize lima to test if this trick is effective.
After hot boot:
devmem2 0x1000301C
00000FFF
modprobe lima
[  599.901524] lima 13040000.gpu: IRQ ppmmu4 not found
[  599.901532] lima 13040000.gpu: IRQ ppmmu5 not found
[  599.901540] lima 13040000.gpu: IRQ ppmmu6 not found
[  599.901547] lima 13040000.gpu: IRQ ppmmu7 not found
[  599.901581] lima 13040000.gpu: gp - mali450 version major 0 minor 0
[  599.901636] lima 13040000.gpu: pp0 - mali450 version major 0 minor 0
[  599.901691] lima 13040000.gpu: pp1 - mali450 version major 0 minor 0
[  599.901738] lima 13040000.gpu: pp2 - mali450 version major 0 minor 0
[  599.901790] lima 13040000.gpu: pp3 - mali450 version major 0 minor 0
[  599.901832] lima 13040000.gpu: IRQ pp4 not found
[  599.901839] lima 13040000.gpu: IRQ pp5 not found
[  599.901846] lima 13040000.gpu: IRQ pp6 not found
[  599.901853] lima 13040000.gpu: IRQ pp7 not found
[  599.901861] lima 13040000.gpu: l2 cache 8K, 4-way, 64byte cache line, 128bit external bus
[  599.901869] lima 13040000.gpu: l2 cache 128K, 4-way, 64byte cache line, 128bit external bus
[  599.901917] lima: ip-id: 25 ppmmu: 25
[  599.902568] lima 13040000.gpu: bus rate = 500500000
[  599.902578] lima 13040000.gpu: mod rate = 500500000
[  599.903197] [drm] Initialized lima 1.0.0 20190217 for 13040000.gpu on minor 1
This is 5.5-merged
Do i understand it right,you check status and switch on power for mali?
If yes you can try adding the regulator from 4.4 i’ve posted here
Yep I read first status register. As you can see 0th bit is 1 so mali is power off. Writing it to 1 power_on register is effective and mali stay on. Can check it from status register after writing. After boot it is powered off.
I booted 4.19-main and there is also GPU power off by default. So I think you can apply 4.19 lima patches to 4.19-main and do power on before load lima module…?
Is it GCPU_PDN flag?
devmem2 is it a userspace tool?
UPD, found devmem and tested.
bpi-r2-gentoo /lib/modules # dmesg -C
bpi-r2-gentoo /lib/modules # devmem 0x10003014 w 0x00000001
/dev/mem opened.
Memory mapped at address 0xb6f2b000.
Value at address 0x10003014 (0xb6f2b014): 0x0
Written 0x1; readback 0x0
bpi-r2-gentoo /lib/modules # devmem 0x1000301C
/dev/mem opened.
Memory mapped at address 0xb6f69000.
Value at address 0x1000301C (0xb6f6901c): 0xFFE
bpi-r2-gentoo /lib/modules # modprobe lima
[45599.640115] LIMA_INIT: lima_clk_init
[45599.640191] LIMA_INIT: lima_clk_init_err:0
[45599.640245] LIMA_INIT: lima_regulator_init_err:0
[45599.642151] LIMA_INIT: lima_dlbu_cpu no err:0
[45599.642230] lima 13040000.gpu: IRQ pmu not found
[45599.642248] lima 13040000.gpu: Lima_init_ip: ip:0, err:0
[45599.642327] lima 13040000.gpu: mmu gpmmu dte write: ADDR:0,val:cafebabe
[45599.642345] lima 13040000.gpu: mmu gpmmu dte read: ADDR:0,val:0
[45599.642356] lima 13040000.gpu: mmu gpmmu dte write test fail
[45599.642366] lima 13040000.gpu: Lima_init_ip: ip:1, err:-5
[45599.681835] lima: probe of 13040000.gpu failed with error -5
bpi-r2-gentoo /lib/modules # uname -r
5.5.0-rc5-bpi-r2-merged
P.S. after reboot:
bpi-r2-gentoo ~ # devmem 0x1000301C
/dev/mem opened.
Memory mapped at address 0xb6f03000.
Value at address 0x1000301C (0xb6f0301c): 0xFFF
Do you have any additional changes in code or dts? Can you show ‘git diff’?
I changed only lima, added debug in 5.5-merged.
I can show git diff after someone give more exact commandline parameters to run…
Now compiling Frank newest 4.19-main where added lima driver. Don’t know yet compiles it ok…
Btw I used:
Ok, after i chanded mt7623,dtsi
g3dsys: syscon@13000000 {
to
g3dsys: clock-controller@13000000 {
Your method worked.
[  120.071693] LIMA_INIT: lima_clk_init
[  120.071752] LIMA_INIT: lima_clk_init_err:0
[  120.071799] LIMA_INIT: lima_regulator_init_err:0
[  120.073328] LIMA_INIT: lima_dlbu_cpu no err:0
[  120.073383] lima 13040000.gpu: IRQ pmu not found
[  120.073391] lima 13040000.gpu: Lima_init_ip: ip:0, err:0
[  120.073446] lima 13040000.gpu: mmu gpmmu dte write: ADDR:0,val:cafebabe
[  120.073458] lima 13040000.gpu: mmu gpmmu dte read: ADDR:0,val:cafeb000
[  120.073540] lima 13040000.gpu: Lima_init_ip: ip:1, err:0
[  120.073578] lima 13040000.gpu: mmu ppmmu0 dte write: ADDR:0,val:cafebabe
[  120.073588] lima 13040000.gpu: mmu ppmmu0 dte read: ADDR:0,val:cafeb000
[  120.073641] lima 13040000.gpu: Lima_init_ip: ip:2, err:0
[  120.073674] lima 13040000.gpu: mmu ppmmu1 dte write: ADDR:0,val:cafebabe
[  120.073693] lima 13040000.gpu: mmu ppmmu1 dte read: ADDR:0,val:cafeb000
[  120.073746] lima 13040000.gpu: Lima_init_ip: ip:3, err:0
[  120.073773] lima 13040000.gpu: mmu ppmmu2 dte write: ADDR:0,val:cafebabe
[  120.073781] lima 13040000.gpu: mmu ppmmu2 dte read: ADDR:0,val:cafeb000
[  120.073855] lima 13040000.gpu: Lima_init_ip: ip:4, err:0
[  120.073882] lima 13040000.gpu: mmu ppmmu3 dte write: ADDR:0,val:cafebabe
[  120.073890] lima 13040000.gpu: mmu ppmmu3 dte read: ADDR:0,val:cafeb000
[  120.073946] lima 13040000.gpu: Lima_init_ip: ip:5, err:0
[  120.073958] lima 13040000.gpu: IRQ ppmmu4 not found
[  120.073964] lima 13040000.gpu: Lima_init_ip: ip:6, err:0
[  120.073973] lima 13040000.gpu: IRQ ppmmu5 not found
[  120.073979] lima 13040000.gpu: Lima_init_ip: ip:7, err:0
[  120.073988] lima 13040000.gpu: IRQ ppmmu6 not found
[  120.073994] lima 13040000.gpu: Lima_init_ip: ip:8, err:0
[  120.074002] lima 13040000.gpu: IRQ ppmmu7 not found
[  120.074008] lima 13040000.gpu: Lima_init_ip: ip:9, err:0
[  120.074034] lima 13040000.gpu: gp - mali450 version major 0 minor 0
[  120.074091] lima 13040000.gpu: Lima_init_ip: ip:10, err:0
[  120.074117] lima 13040000.gpu: pp0 - mali450 version major 0 minor 0
[  120.074180] lima 13040000.gpu: Lima_init_ip: ip:11, err:0
[  120.074208] lima 13040000.gpu: pp1 - mali450 version major 0 minor 0
[  120.074261] lima 13040000.gpu: Lima_init_ip: ip:12, err:0
[  120.074287] lima 13040000.gpu: pp2 - mali450 version major 0 minor 0
[  120.074338] lima 13040000.gpu: Lima_init_ip: ip:13, err:0
[  120.074362] lima 13040000.gpu: pp3 - mali450 version major 0 minor 0
[  120.074416] lima 13040000.gpu: Lima_init_ip: ip:14, err:0
[  120.074426] lima 13040000.gpu: IRQ pp4 not found
[  120.074433] lima 13040000.gpu: Lima_init_ip: ip:15, err:0
[  120.074441] lima 13040000.gpu: IRQ pp5 not found
[  120.074448] lima 13040000.gpu: Lima_init_ip: ip:16, err:0
[  120.074456] lima 13040000.gpu: IRQ pp6 not found
[  120.074463] lima 13040000.gpu: Lima_init_ip: ip:17, err:0
[  120.074471] lima 13040000.gpu: IRQ pp7 not found
[  120.074477] lima 13040000.gpu: Lima_init_ip: ip:18, err:0
[  120.074488] lima 13040000.gpu: l2 cache 8K, 4-way, 64byte cache line, 128bit external bus
[  120.074496] lima 13040000.gpu: Lima_init_ip: ip:19, err:0
[  120.074504] lima 13040000.gpu: l2 cache 128K, 4-way, 64byte cache line, 128bit external bus
[  120.074511] lima 13040000.gpu: Lima_init_ip: ip:20, err:0
[  120.074519] lima 13040000.gpu: Lima_init_ip: ip:21, err:0
[  120.074526] lima 13040000.gpu: Lima_init_ip: ip:22, err:0
[  120.074533] lima 13040000.gpu: Lima_init_ip: ip:23, err:0
[  120.074628] lima 13040000.gpu: Lima_init_ip: ip:24, err:0
[  120.074637] lima 13040000.gpu: Lima_init_ip: ip:25, err:0
[  120.075470] lima 13040000.gpu: bus rate = 500500000
[  120.075484] lima 13040000.gpu: mod rate = 500500000
[  120.076419] [drm] Initialized lima 1.0.0 20190217 for 13040000.gpu on minor 1
Atleast it looks like a light in the end of a tunnel :smiley:
I’ll tty to check devmem 0x1000301C in working 4.16-mt
i found https://bootlin.com/pub/mirror/ - works fine for me :slight_smile:
Could you please check g3dsys?
Yep, but next to find why only 1/2 of GPU is activated…
Hmm, I don’t modified it:
                compatible = "mediatek,mt7623-g3dsys",
                             "mediatek,mt2701-g3dsys",
                             "syscon";
                reg = <0 0x13000000 0 0x200>;
                #clock-cells = <1>;
                #reset-cells = <1>;
That is intresting to know. Lima driver says it don’t handle powermanagement yet.
As i know mt7632n’s mali450 has 1 GP and 4 PPs so everything seems ok
http://wiki.banana-pi.org/Banana_Pi_router_Comparison - bpi-r2 has mali450 MP4 i.e. 4 PPs
Strange… probably it’s unstable result. We need more tests and testers.:thinking:
This says 8:
This picture says 8:
This says 1-8:
So I’m quite sure there is 8 PP.
You mean that Mali450 MP4 means 4PP…!!!
MP4 is the version with four cores (so called fragment processors).
MP4 should have, 4 MP8 - 8, etc; some mali400 has only 2 they labalad as mali400-MP2.
Steps to include lima in 4-19-main (latest)
git clone --depth=10 --single-branch --branch=lima-4.19-rc4 https://gitlab.freedesktop.org/lima/linux/ lima-4.19-rc4
mkdir 4.19-main/drivers/gpu/drm/lima
cp lima-4.19-rc4/drivers/gpu/drm/lima/* 4.19-main/drivers/gpu/drm/lima/
cp lima-4.19-rc/include/uapi/drm/lima_drm.h 4.19-main/include/uapi/drm/
edit 4.19-main/drivers/gpu/drm/Makefile
add to end:  obj-$(CONFIG_DRM_LIMA) += lima/
edit 4.19-main/drivers/gpu/drm/Kconfig
Add latest source: source "drivers/gpu/drm/lima/Kconfig"
Then edit  arch/arm/configs/mt7623n_evb_fwu_defconfig
add:
CONFIG_DRM_LIMA=m
CONFIG_F2FS_FS=y
CONFIG_COMMON_CLK_MT2701_G3DSYS=y
Edit: 4.19-main/arc/arm/boot/dts/mt7623.dtsi
Add:
        mali: gpu@13040000 {
                compatible = "mediatek,mt7623-mali", "arm,mali-450";
                reg = <0 0x13040000 0 0x30000>;
                interrupts = <GIC_SPI 170 IRQ_TYPE_LEVEL_LOW>,
                             <GIC_SPI 171 IRQ_TYPE_LEVEL_LOW>,
                             <GIC_SPI 172 IRQ_TYPE_LEVEL_LOW>,
                             <GIC_SPI 173 IRQ_TYPE_LEVEL_LOW>,
                             <GIC_SPI 174 IRQ_TYPE_LEVEL_LOW>,
                             <GIC_SPI 175 IRQ_TYPE_LEVEL_LOW>,
                             <GIC_SPI 176 IRQ_TYPE_LEVEL_LOW>,
                             <GIC_SPI 177 IRQ_TYPE_LEVEL_LOW>,
                             <GIC_SPI 178 IRQ_TYPE_LEVEL_LOW>,
                             <GIC_SPI 179 IRQ_TYPE_LEVEL_LOW>,
                             <GIC_SPI 180 IRQ_TYPE_LEVEL_LOW>;
                interrupt-names = "gp", "gpmmu", "pp0", "ppmmu0", "pp1",
                                  "ppmmu1", "pp2", "ppmmu2", "pp3", "ppmmu3",
                                  "pp";
                clocks = <&topckgen CLK_TOP_MMPLL>,
                         <&g3dsys CLK_G3DSYS_CORE>;
                clock-names = "bus", "core";
                power-domains = <&scpsys MT2701_POWER_DOMAIN_MFG>;
                resets = <&g3dsys MT2701_G3DSYS_CORE_RST>;
build && install && boot
[   14.288947] lima: unknown parameter 'debug' ignored
[   14.290425] lima 13040000.gpu: bus rate = 500500000
[   14.290439] lima 13040000.gpu: mod rate = 500500000
[   14.295731] lima 13040000.gpu: mmu gpmmu dte write test fail
[   14.298761] lima 13040000.gpu: ttm finalized
[   14.298796] lima 13040000.gpu: Fatal error during GPU init
[   14.298941] lima: probe of 13040000.gpu failed with error -5
rmmod lima
modprobe lima
[  275.840275] lima 13040000.gpu: bus rate = 500500000
[  275.840290] lima 13040000.gpu: mod rate = 500500000
[  275.842618] lima 13040000.gpu: gp - mali450 version major 0 minor 0
[  275.842677] lima 13040000.gpu: pp0 - mali450 version major 0 minor 0
[  275.842727] lima 13040000.gpu: pp1 - mali450 version major 0 minor 0
[  275.842778] lima 13040000.gpu: pp2 - mali450 version major 0 minor 0
[  275.842932] lima 13040000.gpu: pp3 - mali450 version major 0 minor 0
[  275.842999] lima 13040000.gpu: l2 cache 8K, 4-way, 64byte cache line, 128bit external bus
[  275.843009] lima 13040000.gpu: l2 cache 128K, 4-way, 64byte cache line, 128bit external bus
[  275.845825] [drm] Initialized lima 1.0.0 20170325 for 13040000.gpu on minor 1
Added to: drivers/gpu/drm/lima/lima_device.c
int lima_device_init(struct lima_device *ldev)
        int err, i;
        struct resource *res;
        #ifdef CONFIG_MTK_COMBO_CHIP_CONSYS_7623
        void __iomem *wakeup_register;
        wakeup_register = ioremap(0x10003014 , 0x04);
        writel(0x00000001,wakeup_register); // this may be wrong, may need bitbang 0th bit to 1
        iounmap(wakeup_register);
        mdelay(1000);
        #endif
Enjoy. braah it seems to need some time to wake up. But now it works if unload and reload lima… (no need to tweak devmem more…)
Edit: added delay it need also #include <linux/delay.h>
There is still something odd, it need to load twice until it works.
        mdelay(100);
        wakeup_register = ioremap(0x10003000 , 0x04); // this is global reset register!!
        writel(0x00000010,wakeup_register); // this may be wrong, may need bitbang 5th bit to 1
        mdelay(100);
        #endif
Tryed GPU reset…
BTW it may be a nice idea to use readl(wakeup_register) in Mediatek modified driver to find out how does it exactly wakes up a gpu.
I think it’s here.
Hi why using rc4 and not release? Mhm,it seems there is no final for 4.19…
Why do you use wifi/bt config symbol ( CONFIG_MTK_COMBO_CHIP_CONSYS_7623)? can we now drop devmem calls now?
Have you tried regulator i linked?
have added first changes (till dtsi) to 4.19-lima, but it still seems not working
root@bpi-r2:~# rmmod lima
root@bpi-r2:~# dmesg | grep lima
[    0.000000] Linux version 4.19.92-bpi-r2-lima (frank@frank-G5) (gcc version 0
[   12.720819] lima 13040000.gpu: bus rate = 500500000
[   12.730790] lima 13040000.gpu: mod rate = 500500000
[   12.830678] lima 13040000.gpu: mmu gpmmu dte write test fail
[   12.925613] lima 13040000.gpu: ttm finalized
[   12.934621] lima 13040000.gpu: Fatal error during GPU init
[   12.944896] lima: probe of 13040000.gpu failed with error -5
root@bpi-r2:~#
root@bpi-r2:~#
root@bpi-r2:~# ./a.out 0x1000301C
/dev/mem opened.
Memory mapped at address 0xb6fe2000.
Value at address 0x1000301C (0xb6fe201c): 0xFFF
root@bpi-r2:~# mv a.out devmem2
root@bpi-r2:~# ./devmem2 0x10003014 w 0x00000001
/dev/mem opened.
Memory mapped at address 0xb6fbd000.
Value at address 0x10003014 (0xb6fbd014): 0x0
root@bpi-r2:~# modprobe lima
[  622.543242] lima 13040000.gpu: bus rate = 500500000
[  622.548184] lima 13040000.gpu: mod rate = 500500000
[  622.553394] [TTM] Zone  kernel: Available graphics memory: 247594 kiB
[  622.559852] [TTM] Zone highmem: Available graphics memory: 1029416 kiB
[  622.566400] [TTM] Initializing pool allocator
[  622.572377] lima 13040000.gpu: mmu gpmmu dte write test fail
[  622.578157] [TTM] Finalizing pool allocator
[  622.583236] [TTM] Zone  kernel: Used memory at exit: 0 kiB
[  622.588787] [TTM] Zone highmem: Used memory at exit: 0 kiB
[  622.594299] lima 13040000.gpu: ttm finalized
[  622.598561] lima 13040000.gpu: Fatal error during GPU init
[  622.604146] lima: probe of 13040000.gpu failed with error -5
root@bpi-r2:~#
I’ve tried - boots and inits from 1st attempt, without devmem.
bpi-r2-gentoo ~ # dmesg | grep lima
[   22.977847] LIMA_INIT: lima_clk_init
[   22.977911] LIMA_INIT: lima_clk_init_err:0
[   22.977965] LIMA_INIT: lima_regulator_init_err:0
[   22.982104] LIMA_INIT: lima_dlbu_cpu no err:0
[   22.982176] lima 13040000.gpu: IRQ pmu not found
[   22.982187] lima 13040000.gpu: Lima_init_ip: ip:0, err:0
[   22.982241] lima 13040000.gpu: mmu gpmmu dte write: ADDR:0,val:cafebabe
[   22.982251] lima 13040000.gpu: mmu gpmmu dte read: ADDR:0,val:cafeb000
[   22.982347] lima 13040000.gpu: Lima_init_ip: ip:1, err:0
[   22.982381] lima 13040000.gpu: mmu ppmmu0 dte write: ADDR:0,val:cafebabe
[   22.982389] lima 13040000.gpu: mmu ppmmu0 dte read: ADDR:0,val:cafeb000
[   22.982464] lima 13040000.gpu: Lima_init_ip: ip:2, err:0
[   22.982502] lima 13040000.gpu: mmu ppmmu1 dte write: ADDR:0,val:cafebabe
[   22.982510] lima 13040000.gpu: mmu ppmmu1 dte read: ADDR:0,val:cafeb000
[   22.982588] lima 13040000.gpu: Lima_init_ip: ip:3, err:0
[   22.982636] lima 13040000.gpu: mmu ppmmu2 dte write: ADDR:0,val:cafebabe
[   22.982645] lima 13040000.gpu: mmu ppmmu2 dte read: ADDR:0,val:cafeb000
[   22.982727] lima 13040000.gpu: Lima_init_ip: ip:4, err:0
[   22.982761] lima 13040000.gpu: mmu ppmmu3 dte write: ADDR:0,val:cafebabe
[   22.982769] lima 13040000.gpu: mmu ppmmu3 dte read: ADDR:0,val:cafeb000
[   22.982828] lima 13040000.gpu: Lima_init_ip: ip:5, err:0
[   22.982840] lima 13040000.gpu: IRQ ppmmu4 not found
[   22.982847] lima 13040000.gpu: Lima_init_ip: ip:6, err:0
[   22.982855] lima 13040000.gpu: IRQ ppmmu5 not found
[   22.982861] lima 13040000.gpu: Lima_init_ip: ip:7, err:0
[   22.982870] lima 13040000.gpu: IRQ ppmmu6 not found
[   22.982876] lima 13040000.gpu: Lima_init_ip: ip:8, err:0
[   22.982884] lima 13040000.gpu: IRQ ppmmu7 not found
[   22.982891] lima 13040000.gpu: Lima_init_ip: ip:9, err:0
[   22.982919] lima 13040000.gpu: gp - mali450 version major 0 minor 0
[   22.982978] lima 13040000.gpu: Lima_init_ip: ip:10, err:0
[   22.983008] lima 13040000.gpu: pp0 - mali450 version major 0 minor 0
[   22.983079] lima 13040000.gpu: Lima_init_ip: ip:11, err:0
[   22.983122] lima 13040000.gpu: pp1 - mali450 version major 0 minor 0
[   22.983198] lima 13040000.gpu: Lima_init_ip: ip:12, err:0
[   22.983232] lima 13040000.gpu: pp2 - mali450 version major 0 minor 0
[   22.983307] lima 13040000.gpu: Lima_init_ip: ip:13, err:0
[   22.983340] lima 13040000.gpu: pp3 - mali450 version major 0 minor 0
[   22.983397] lima 13040000.gpu: Lima_init_ip: ip:14, err:0
[   22.983408] lima 13040000.gpu: IRQ pp4 not found
[   22.983416] lima 13040000.gpu: Lima_init_ip: ip:15, err:0
[   22.983424] lima 13040000.gpu: IRQ pp5 not found
[   22.983430] lima 13040000.gpu: Lima_init_ip: ip:16, err:0
[   22.983438] lima 13040000.gpu: IRQ pp6 not found
[   22.983445] lima 13040000.gpu: Lima_init_ip: ip:17, err:0
[   22.983452] lima 13040000.gpu: IRQ pp7 not found
[   22.983459] lima 13040000.gpu: Lima_init_ip: ip:18, err:0
[   22.983468] lima 13040000.gpu: l2 cache 8K, 4-way, 64byte cache line, 128bit external bus
[   22.983477] lima 13040000.gpu: Lima_init_ip: ip:19, err:0
[   22.983485] lima 13040000.gpu: l2 cache 128K, 4-way, 64byte cache line, 128bit external bus
[   22.983492] lima 13040000.gpu: Lima_init_ip: ip:20, err:0
[   22.983499] lima 13040000.gpu: Lima_init_ip: ip:21, err:0
[   22.983507] lima 13040000.gpu: Lima_init_ip: ip:22, err:0
[   22.983514] lima 13040000.gpu: Lima_init_ip: ip:23, err:0
[   22.983606] lima 13040000.gpu: Lima_init_ip: ip:24, err:0
[   22.983615] lima 13040000.gpu: Lima_init_ip: ip:25, err:0
[   22.986047] lima 13040000.gpu: bus rate = 500500000
[   22.986060] lima 13040000.gpu: mod rate = 500500000
[   22.989753] [drm] Initialized lima 1.0.0 20190217 for 13040000.gpu on minor 1
/dev/mem opened.
Memory mapped at address 0xb6f00000.
Value at address 0x1000301C (0xb6f0001c): 0xFFF
lima-5.5-merged.txt (63.2 КБ)
bpi-r2-gentoo ~ # ls -la /dev/dri/
итого 0
drwxr-xr-x  3 root root        120 дек 31 16:00 .
drwxr-xr-x 16 root root      13900 дек 31 16:02 ..
drwxr-xr-x  2 root root        100 дек 31 16:00 by-path
crw-rw----  1 root video  226,   0 дек 31 16:08 card0
crw-rw----  1 root video  226,   1 дек 31 16:00 card1
crw-rw-rw-  1 root render 226, 128 дек 31 16:00 renderD128
