Is it possible to make NVME as boot instead of sdcard or NAND or EMMC?
Hi Frank,
Thanks for the heads up! In our case this is not an issue — we don’t copy a filesystem. We write the OpenWrt FIT image directly to a raw partition (p2) via dd, and the kernel is placed on p1 (ext4). No fstab involved, rootfs is mounted via overlayfs from the FIT image.
But good point for anyone trying to clone an existing SD/eMMC rootfs to NVMe — fstab would definitely need updating in that case.
Actually, any recent (systemd based) Linux distro does not need /etc/fstab entries for boot and root partitions. They will both be mounted correctly if setup correctly. Fstab can be useful if deviating from standard mount options, like not writing access times on ext4 for example…
Most easy setup on nvme: rootfs in btrfs partition. Since U-Boot supports it, one can boot without separate boot partition. A boot folder on the rootfs will just be fine in this case.
Quick update — we’ve finalized the NVMe deploy system for BPI-R4.
In addition to NVMe boot and sysupgrade support, we’ve added automatic p3 ext4 partition covering all remaining disk space. It’s available at /mnt/nvme0n1p3 after installation and is intended for general use — Docker, Podman, or any data storage.
Everything is documented and available at: GitHub - woziwrt/bpi-r4-deploy · GitHub
If you have any suggestions or ideas for improvement, we’d be happy to hear them!
Hi all (@wozi, @frank-w, @ericwoud),
quick update on my progress with the “BPI-R4 Pro 8X”. Current status after testing and debugging:
  • Boot (including NVMe) is working reliably
  • System itself is stable once running
  • Networking is completely non-functional (all ports show NO-CARRIER)
After quite a bit of testing, my current understanding is:
→ kernel / device tree / switch (DSA / MT7530) support for the 8X variant is not fully implemented yet (which all you already mentioned in your repos). I initially tried multiple approaches (including modifying FIT images and mixing kernel/DT sources), but results were inconsistent and unstable — which makes sense in hindsight, since proper support requires aligned kernel + DT + switch configuration. (erghh, I sooo hoped that it was an easy task.))
At this point, it seems clear that:
  • proper 8X support is still incomplete
  • and fixing this is not a simple “patch one file” task, but requires coordinated kernel-level work
  • will now try Franks 6.19 (just saw that - looks promissing)
(I also attempted to extract and modify the FIT image manually to use as a base — useful exercise, but not a viable solution in the current state.) So for now, I assume that waiting for upstream/kernel improvements is the realistic path forward. That said: I do have the hardware available and can test things locally. If anyone is actively working on 8X support (kernel, DT, switch/DSA) and needs testing or feedback, I’d be happy to help. I´ll be on standby in the meantime and place questions from time to time - I hope you guys dont mind.
You did not mention what image you are using. If it is mine, i just moved from 6.18-main to 6.19-main from Frank for linux-bpir4-git package, it is building now slowly and maybe finished in an hour or so.
Anyway, I cannot test r4pro, I do not have one.
ya, I am switching to 6.19 (i was still on 6.18)… true , will try that also … been on 18 for the past 4-5days. :wink: … saw that Frank did also update. Let me check.
linux-bpir4-git from 6.19-main is finished.
[BPI-R4 Pro 8X] 6.19 self-built (Frank base) – LAN/WAN findings + network config issues
I built my own image based on Frank’s 6.19 kernel (using his repos/pipeline) and tested it on a BPI-R4 Pro 8X. Boot works, kernel works, DSA works — but I ran into several networking issues during bring-up.
Current assumption
  • @frank-w´s setups likely work because of predefined roles/config
  • My issues seem to come from:
    • missing/incorrect userspace network config
    • unclear interface mapping
I’ll verify this further. I also plan to test @ericwoud´s 6.19 build to compare behavior.
What I observed
1. Kernel / hardware side
  • Kernel 6.19 boots fine
  • DSA initializes correctly
  • Switch + PHY detected:
    • mt7530
    • MaxLinear MxL86252
    • Aeonsemi AS21xxx
  • LAN ports get link and work after cleanup
Conclusion: Kernel / DT / DSA stack is working
2. Default network config problem
With the default setup (systemd-networkd):
  • lanbr0 is created automatically
  • interfaces get attached automatically
  • VLAN behavior seems to be applied implicitly
Result:
  • unstable connectivity
  • packet loss
  • ARP failures
Kernel log:
Dropping packet due to invalid outer 802.1Q tag: switch -1 port -1
3. Interface mapping (important)
My initial assumption was:
eth0 = WAN What it actually was:
eth0 → internal 10G link (not usable as WAN) eth1 → real WAN PHY (RJ45 combo port) eth2 → switch CPU port lan0–lan4 → front LAN ports
4. WAN behavior
  • Using eth0 → no connectivity (internal link only)
  • Using eth1:
    • PHY detected
    • Link comes up (1G)
    • works after proper routing cleanup
Working minimal config
After removing the default network config:
systemctl disable systemd-networkd systemctl disable systemd-networkd.socket systemctl disable systemd-networkd-wait-online
ip route flush table main
ip addr flush dev eth0 ip addr flush dev eth1 ip addr flush dev lan1 ip addr flush dev br0
ip addr add 192.168.2.200/24 dev eth1 ip link set eth1 up
ip route add 192.168.2.0/24 dev eth1 ip route add default via 192.168.2.1 dev eth1
Result:
  • stable link
  • ping to upstream router works
  • confirms WAN via eth1
Conclusion
  • Kernel 6.19 fixes the major “no network” issue
  • remaining problems are:
    • userspace network configuration
    • non-obvious interface mapping
Open questions for tomorrow
  • Is eth1 = WAN expected for bpi-r4pro 8X?
  • Is the default networkd config intended this way?
  • Am I missing part of Frank’s intended configuration?
  • Does Eric’s 6.19 build handle this mapping differently?
Next steps (on my side)
  • test Frank’s setup with the intended config
  • test Eric’s 6.19 build
  • compare behavior and defaults
Kernel 6.19 works LAN works after removing default networkd bridge/VLAN WAN is on eth1 (not eth0) eth0 appears to be an internal link
Note
Posting this in case others run into the same behavior and want to test without waiting. Also, please correct me if I am coming to conclusions that are simply wrong (might have happened once or twice in my lifetime :crazy_face: )
I think my setup still assumed this is eth0, so you may need to switch this in the settings, if you find that the underlying ethX of the dsa-ports is not brought link up.
https://wiki.fw-web.de/doku.php?id=en:bpi-r4pro:start#network
Newer kernels will use lan1-lan4 for mxl-ports and lan5 as internal.
The network-config is still the one from R4,have not made a way to use a dedicated one,so here is some manual work needed.
Btw. Upstream driver for mxl switch has issues with current firmware (1.0.70.70) and software bridge. I switched to this driver with kernel 7.0. we hope that mxl release new firnware in a few weeks.
Hi all ( @frank-w, @hErEsy, @ericwoud),
I decided to undertake a project that could be generally useful and demonstrate the practical applications of installing OpenWRT on NVMe. I set out on this journey, and after overcoming numerous obstacles that were thrown in my way, I finally arrived here
:point_right: https://github.com/woziwrt/bpi-r4-unifi
and here are some screenshots.
I’d be quite interested in your opinion on this result :slightly_smiling_face:
In case of this gets many replies, it may be better you post this in a separate topic?
I plan to do that, but when I noticed people in this thread talking about the BPI-R4 and NVMe, I wanted to let you know first😉
Thanks for all your help @frank-w & @wozi !
I found your GitHub page and ended up here. Is there any way I can make or compile this myself to work on bpi-r4 without WiFi? Your GitHub page shows it’s not supported. :sweat_smile::sob::pray:
Which github page do youean? You cannot directly boot from nvme…botloader needs to boot from spi or mmc,then in uboot you can switch to nvme
All is described here GitHub - woziwrt/bpi-r4-deploy · GitHub
Hi Frank! I spent all day trying to get Frank W to work with the latest release but I just couldn’t get it to boot from NVMe. It kept looking for bpi-r4.itb.
I even renamed my sysupgrade to bpi-r4.itb. It seemed to almost work but kept loading up “ conf-base#ov-sd’” and I couldn’t change it. Any ideas or suggestions?
Wozi, your build worked but was on a snapshot and I really wanted the latest release for stability. I tried to load my sysupgrade on your build but it breaks my sfp+ ports because it’s a different kernel. Plus you have more packages baked in that I prefer. It DOES work though. Thanks so much for sharing!
My image is debian but can basicly boot the initramfs.itb. but maybe the memory layout needs to be changed because of the size of the itb (setting loadaddr or kaddr to 0x5000000 via uEnv.txt). You can set all vars there.
loadaddr=0x5000000
kaddr=$loadaddr
nvme_boot=0:1
nvme_root=/dev/nvme0n1p2
fit=openwrt...-initramfs...itb
bootmenu_default=3
oh wow! Thanks so much for that.
Sounds like all I need to do is throw in uEnv.txt with the variables and it should boot. Let me give it a try! Thanks frank-w!
“Which exact OpenWrt image (sysupgrade / initramfs / other) works best for booting from NVMe with your U-Boot?”
I keep getting errors with the sysupgrade ITB.
