I can press the power button and the led will turn on but after that it goes dark. nothing happens.
no lights on the WAN port. Any suggestions ?
Hi
Have you inserted sd-card with bpi-r2 image? Which one? Do you see partitions on sdcard when inserted in pc? Have you pressed powerbutton long enough (~10seconds)
I did not pressed it for 10 secs, I will try that. I left the device at work =( I will play with it on Monday. It is a project for work, or maybe I will drive tomorrow. It is a project at work. We really like the specs of the device we hope to get it working.
I will keep you posted.
That did it man. I had to keep it press for 10 seconds. Is there a way to shorten this ? or turning the device on by default if it gets power.
You can bridge powerbutton (need to disable in software) or bring 5v to otg-port
There are a few possibilities here:
Which OS are you trying to boot with? I’ve had very good results using the Armbian for the bpi-r2
your sd-card maybe does not want to play along, you could need to try another one.
Just remember to hold the boot-thing down until you see the lights go on.
I am using OpenWRT and it is loading from sd right now. all of it is working fine so far. I just want to finish writing the code and do a demo in here =)
We will also install a modem to this board. This thing is nice =) all of it is working after the boot.
Thanks for the help!
