Huawei OptiXstar S800E XGSPON SPF+ ONU not detected
Will test out your sfp1 moddef0 output low dt changes. The advantage is that dt are applied almost immediately on boot. rc.local happens much much later. So on a cold boot, the connection should come up much faster.
I expect speed and duplex to be negotiated successfully . But flow control will be on auto which will not work for sfp devices i tried previously. And given in my case both sfp are connected to 10G, I rather hardcode it.
No issues pushing line rate for forwarding. As there are 3 ppe engines one each of the gmac. I had previously tested pushing near line rate forwarding between both sfp+ ports on two relatively fast machines with iperf3 --bidir. For traffic terminating at the bpi-r4, rss/lro are not available yet. So I am maxing out at 6.5Gbps+ on iperf3 receive on the device itself.
Also mtk has been active adding patches to the 6.6 kernel and happy days. HQoS was recently added. And from my limited testing it does improve latency on a 10G fiber thou only modestly as latency was pretty low already.
@j_g the above change to DT did not work. builds but system fails to boot up after sysupgrade. strange…
I can’t tell if there is an issue with that entry, but maybe taking one step back would be to try with LEDs instead? Can probably change led_green to use the moddef0 pin instead, and switch it to GPIO_ACTIVE_LOW?
Also curious, in your working hacked devicetree, when the link is up, does anything respond on the i2c bus where the S800E should have been? Still scratching my head on why the S800E doesn’t respond on i2c, but at least we can eliminate some possibilities such as bad power supply, or module held in reset.
still scratching my head on gpio-hog, i double checked seems correct. Maybe someone else can chip in. @ericwoud @frank-w
I left sftp1 i2c intact on device tree. And I just checked. This is with S800E active and link up. Nada… zip… nothing…
i2cdetect -y 3
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:                         -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: UU -- -- -- -- -- -- --
You need to remove the gpio from the sfp part. But with overlay cannot delete. But you can overwrite the gpio of the sfp with an unused one. Then it is free to hog.
Check dmesg log for conflicts
i have deleted the entire sfp1. it is free as i can control it from userspace. Don’t understand what u mean by overlay cannot delete.
I meant with a .dtbo cannot delete from .dtb
question: why active_high instead of active_low? Also does it matter? since it will be set to output-low.
I don’t think the polarity is as critical in gpio-hog, ultimately output-low is what we want to keep the mosfet active:
- output-low  A property specifying to set the GPIO direction as output with
	      the value low.
I picked active_high out of habit, in this context, active_low is semantically better since a p-channel mosfet gate/output is inverting in a high-side switch topology.
However, if you are going to try using leds instead of gpio-hog, GPIO_ACTIVE_LOW will make a difference since it provides the polarity context to default-state = "on";
managed to get gpio-hog added in. it should be:
gpios = <82 GPIO_ACTIVE_LOW>;`
as it is already nested in &pio.
BUT it does not work as intended. this is with a warm boot with S800E already powered on and S800E lost power upon reboot.
gpio-594 (                    |sfp1-mod-def0-power-) in  hi ACTIVE LOW
And if i change to:
gpios = <82 GPIO_ACTIVE_HIGH>;
then
gpio-594 (                    |sfp1-mod-def0-power-) in  lo
the above is with a warm reboot with the S800E already powered up. the S800E continues to be power up. I did not test a cold boot as I am pretty sure the S800E will fail to boot up as direction is still input.
what is clear is that the “output-low” is not working as intended in both case. Ideas?
current approach is to export gpio 594 and manage it from userland.
You could try to set pinctrl states default and sleep.
Then the pin will change to the configuration set at sleep state when shutting down and set to the default state again after (re)boot.
https://www.kernel.org/doc/Documentation/devicetree/bindings/pinctrl/pinctrl-bindings.txt
If I’m not mistakin, should change to sleep mode also at shutdown before reboot, but I cannot quickly find where this is documented.
@j_g can you help check, when bpi-r4 boots up with your EEPROM hack. Does S800E report usxgmill mode or does it automatically switches to 10gbase-R?
[   11.484218] mtk_soc_eth 15100000.ethernet eth1: switched to inband/10gbase-r link mode
[   13.704939] mtk_soc_eth 15100000.ethernet eth1: configuring for inband/10gbase-r link mode
[   13.754367] mtk_soc_eth 15100000.ethernet eth2: configuring for inband/10gbase-r link mode
I had to change phy-mode for sfp1 from usxgmill to 10gbase-r for the link to be up and working.
With the EEPROM hack:
root@OpenWrt:~# dmesg | grep eth0
[    4.236230] mtk_soc_eth 15100000.ethernet eth0: mediatek frame engine at 0xffffffc082700000, irq 106
[    4.506944] mtk_soc_eth 15100000.ethernet eth0: entered promiscuous mode
[    5.443141] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/internal link mode
[    5.451281] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 10Gbps/Full - flow control rx/tx
[   13.219595] mtk_soc_eth 15100000.ethernet eth0: Link is Down
[   13.241731] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/internal link mode
[   13.249895] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 10Gbps/Full - flow control rx/tx
[   13.284181] mtk_soc_eth 15100000.ethernet eth0: entered allmulticast mode
Edit1: I can’t confirm if eth1 is the right interface, but here are the logs:
root@OpenWrt:~# dmesg | grep eth1
[    4.245908] mtk_soc_eth 15100000.ethernet eth1: mediatek frame engine at 0xffffffc082700000, irq 106
[   11.713076] mtk_soc_eth 15100000.ethernet eth1: switched to inband/10gbase-r link mode
[   13.375314] mtk_soc_eth 15100000.ethernet eth1: configuring for inband/10gbase-r link mode
Edit2: might be better to show both interfaces, here’s dmesg after a fresh reboot
root@OpenWrt:~# dmesg | grep mtk_soc_eth
[    4.223854] mtk_soc_eth 15100000.ethernet: generated random MAC address 65:74:68:25:64:00
[    4.236265] mtk_soc_eth 15100000.ethernet eth0: mediatek frame engine at 0xffffffc082780000, irq 106
[    4.245957] mtk_soc_eth 15100000.ethernet eth1: mediatek frame engine at 0xffffffc082780000, irq 106
[    4.255617] mtk_soc_eth 15100000.ethernet eth2: mediatek frame engine at 0xffffffc082780000, irq 106
[    4.504808] mtk_soc_eth 15100000.ethernet eth0: entered promiscuous mode
[    5.439328] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/internal link mode
[    5.447496] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 10Gbps/Full - flow control rx/tx
[   11.711799] mtk_soc_eth 15100000.ethernet eth2: switched to inband/10gbase-r link mode
[   11.749734] mtk_soc_eth 15100000.ethernet eth1: switched to inband/10gbase-r link mode
[   13.225263] mtk_soc_eth 15100000.ethernet eth0: Link is Down
[   13.247536] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/internal link mode
[   13.255730] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 10Gbps/Full - flow control rx/tx
[   13.289913] mtk_soc_eth 15100000.ethernet eth0: entered allmulticast mode
[   13.381128] mtk_soc_eth 15100000.ethernet eth1: configuring for inband/10gbase-r link mode
[   13.424071] mtk_soc_eth 15100000.ethernet eth1: entered allmulticast mode
[   13.431098] mtk_soc_eth 15100000.ethernet eth1: entered promiscuous mode
[   13.476204] mtk_soc_eth 15100000.ethernet eth2: configuring for inband/10gbase-r link mode
[   13.518961] mtk_soc_eth 15100000.ethernet eth2: entered allmulticast mode
[   13.525880] mtk_soc_eth 15100000.ethernet eth2: entered promiscuous mode
[   15.624827] mtk_soc_eth 15100000.ethernet eth2: Link is Up - 10Gbps/Full - flow control off
wrt gpio-hog being stuck as an input, I can’t think of any answers at the moment. I don’t see the same pin used anywhere else, and output-low seems pretty explicit. I can only suggest an uglier hack (inserting it as a led in gpio-leds with default-state = "on"; with GPIO_ACTIVE_LOW)
eth2 is sfp1 or sfp-wan. From your dmesg, it automatically switches to 10gbase-r. I have a suspicion going to test it out. I am still extremely curious on why i2c can’t read S800E eeprom!
Just discovered another issue. the randomly generated MAC address is not random! My logs show the exact same “random” MAC address.
Edit: checked ifconfig, system doesn’t seems to use that random MAC address. Uses mac address stored in /etc/board.json
eth2 is the mac for left sfp (wan) eth1 is mac for sfp (lan) between wan-sfp and rj45 ports
Random address is normal as the macs not having an address burned into efuse or board. Fixed mac has to be done in software by reading from a file or from eeprom or similar
Am I reading this right?
This problem:
“A vicious circle, the module cannot change the mod-def0 signal from HI to LO because there is no power. BPI-R4 cannot supply power because mod-def0 HI.”
And its verdict:
“It cannot be circumvented by software. The logic is implemented via circuit, the software sees the module for a split second, and then it vanishes to never come back. The BPI-R3 had no such circuicy, and any other bit of SFP hardware I tested doesn’t either. The module only does not work in the stock BPI-R4. And given the circuit diagram for the R4 has a place for a brige in place of the mosfet drawn into the diagram, I highly assume this was at least to some degree accounted for. There are no ill effects to replacing the mosfet with a bridge. Other than the status LED being permanently lit.”
DOES work now (or is starting to work) through some software mods? No hardware modifications needed. Correct?
Currect. What is stated is the first issue with S800E
The 2nd issue is that i2c read of the S800E EEPROM has issues.
imho, if I have S800E and knowing what I know today. I will probably not go with bpi-r4.
dm7000s: It’s a software hack that “works” with caveats, most important being that SFP presence detection through mod-def0 will not work so your mileage may vary.
glassdoor: I actually picked up the bpi-r4 after seeing this thread :P. I assumed that a simple bridge over the mosfet would solve the issue, and was definitely not expecting the i2c issues that we are facing now. So far I am unsure if its an issue with the bpi-r4 design, or on Huawei’s side with the S800E.
That being said, the 3.3V SFP power mosfet implementation is (imo) unusual. Being able to toggle power to the SFP module could be handy for resetting misbehaving modules, but the mosfet could be better served by a dedicated GPIO pin instead of being tied to mod-def0.
Btw I’m not sure what it’s like where you’re at, but if there are half-decent phone repair shops around you, they might be able to help you bridge the WAN mosfet for a few dollars? Should be easy for them (just show them the photos from this thread), and could possibly save you some headache.
for what it’s worth. bpi-r4 is the only piece of gear with sfp+ i have have tested that does not work with s800E. It works on edgerouter infinity(really old kernel), ms-01(intel x710) and quite a few 10G/2.5G switches that have graced my test bench. All of them works except bpi-r4. For kicks i even tried it on a asus rt-be88u’s sfp+ port a few days back. and it just works.lol
Power and reading S800E were never an issues except bpi-r4!
Actually before you came along. I had sort of written off bpi-r4 with the s800e.
For the man on the street, getting the mosfet removed and bridging it should be easy. As you said plenty of mobile shop will easily do it for a quick buck. But circumventing i2c requires building your own custom images and “fingers crossed” the can of worms that might have been opened in the process.
imho. Not recommened if the intension is to pair with S800E
