To MediaTek & folks:
Your hardware QoS looks good and works great (with my limited tests) until LXC (Linux containers) kicks in. There is a little nagging compatibility issue with LXC in your HQoS supporting codes in PPE.
Whenever lxc-start or lxc-stop is invoked from the command line, your codes spit out this horrible warning (but seems harmless to system stability from my check):
[ 13.722547] ------------[ cut here ]------------
[ 13.727178] sysctl net/netfilter/nf_conntrack_qos: data points to kernel global data: 0xffffffc080dfa6cc
[ 13.736736] WARNING: CPU: 2 PID: 3539 at register_net_sysctl_sz+0xe0/0x140
[ 13.831491] CPU: 2 UID: 0 PID: 3539 Comm: lxc-start Tainted: G O 6.12.55 #0
[ 13.839835] Tainted: [O]=OOT_MODULE
[ 13.843315] Hardware name: Banana Pi BPI-R4 (2x SFP+) (DT)
[ 13.848790] pstate: 60400005 (nZCv daif +PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 13.939903] Call trace:
[ 13.942341] register_net_sysctl_sz+0xe0/0x140
[ 13.946777] nf_conntrack_pernet_init+0x150/0x2c0
[ 13.951477] ops_init+0x70/0x128
[ 13.954701] setup_net+0xc0/0x2f0
[ 13.958009] copy_net_ns+0x13c/0x2bc
[ 13.961579] create_new_namespaces+0x110/0x2c0
[ 13.966016] unshare_nsproxy_namespaces+0x5c/0xa0
[ 13.970710] ksys_unshare+0x11c/0x3b4
[ 13.974368] __arm64_sys_unshare+0x10/0x20
[ 13.978458] invoke_syscall.constprop.0+0x4c/0xd0
[ 13.983155] do_el0_svc+0x3c/0xd0
[ 13.986461] el0_svc+0x18/0x60
[ 13.989509] el0t_64_sync_handler+0x118/0x124
[ 13.993858] el0t_64_sync+0x150/0x154
[ 13.997513] ---[ end trace 0000000000000000 ]---
The issue looks like your addition of sysctl variable “nf_conntrack_qos” isn’t namespace compatible. Would be good if you look into this and get it addressed.
My tests done in OpenWrt master branch + your PPE patches.
Cheers
