@ericwoud Whatās current mainline status of your patches? Sorry to bother but itās quite difficult to track them since they are separated to different series.
There is an issue that needs some solution, so it is halted. Soon I will ask how the maintainers of netfilter want to continue, see if Florianās question can get an answer, if they want to continue at all I was on holidays, so it has been a while nothing happened.
@ericwoud can you reproduce this issue when using WED with your patch? Bridger internet issues when roaming between multiple APs with bridger installed Ā· Issue #6 Ā· nbd168/bridger Ā· GitHub
Iām curious if itās bridgerās issue or WEDās issue.
You can try applying these 2:
netfilter: flow: Add bridge_vid member
netfilter: nf_flow_table_core: teardown direct xmit when destination changed
It handles removing the fastpath flow entry when a fdb entry is deleted, including deletion when roaming.
I canāt try this now, but I sent these patches to original issue to look for someone to test them.
Ok, but I think this is not the final patch, it will change some moreā¦
@ericwoud Hi, Iām seeing some of your patches are already merged. I wonder what is still left to be done? They are too separated so Iām not sure if I missed something.
Still plenty, so need to have a lot more patienceā¦
Although some are only needed for vlan and/or double-vlan or pppoe-in-q.
