Please apply the following two patches in order.
[1st patch]: modify the common code in order to prepare for adding correct MT7622 thermal support.
diff --git a/drivers/thermal/mtk_thermal.c b/drivers/thermal/mtk_thermal.c
index acf4854..31dd1b4 100644
--- a/drivers/thermal/mtk_thermal.c
+++ b/drivers/thermal/mtk_thermal.c
@@ -120,18 +120,18 @@
* MT2701 has 3 sensors and needs 3 VTS calibration data.
* MT2712 has 4 sensors and needs 4 VTS calibration data.
-#define CALIB_BUF0_VALID BIT(0)
-#define CALIB_BUF1_ADC_GE(x) (((x) >> 22) & 0x3ff)
-#define CALIB_BUF0_VTS_TS1(x) (((x) >> 17) & 0x1ff)
-#define CALIB_BUF0_VTS_TS2(x) (((x) >> 8) & 0x1ff)
-#define CALIB_BUF1_VTS_TS3(x) (((x) >> 0) & 0x1ff)
-#define CALIB_BUF2_VTS_TS4(x) (((x) >> 23) & 0x1ff)
-#define CALIB_BUF2_VTS_TS5(x) (((x) >> 5) & 0x1ff)
-#define CALIB_BUF2_VTS_TSABB(x) (((x) >> 14) & 0x1ff)
-#define CALIB_BUF0_DEGC_CALI(x) (((x) >> 1) & 0x3f)
-#define CALIB_BUF0_O_SLOPE(x) (((x) >> 26) & 0x3f)
-#define CALIB_BUF0_O_SLOPE_SIGN(x) (((x) >> 7) & 0x1)
-#define CALIB_BUF1_ID(x) (((x) >> 9) & 0x1)
+#define CALIB_BUF0_VALID_V1 BIT(0)
+#define CALIB_BUF1_ADC_GE_V1(x) (((x) >> 22) & 0x3ff)
+#define CALIB_BUF0_VTS_TS1_V1(x) (((x) >> 17) & 0x1ff)
+#define CALIB_BUF0_VTS_TS2_V1(x) (((x) >> 8) & 0x1ff)
+#define CALIB_BUF1_VTS_TS3_V1(x) (((x) >> 0) & 0x1ff)
+#define CALIB_BUF2_VTS_TS4_V1(x) (((x) >> 23) & 0x1ff)
+#define CALIB_BUF2_VTS_TS5_V1(x) (((x) >> 5) & 0x1ff)
+#define CALIB_BUF2_VTS_TSABB_V1(x) (((x) >> 14) & 0x1ff)
+#define CALIB_BUF0_DEGC_CALI_V1(x) (((x) >> 1) & 0x3f)
+#define CALIB_BUF0_O_SLOPE_V1(x) (((x) >> 26) & 0x3f)
+#define CALIB_BUF0_O_SLOPE_SIGN_V1(x) (((x) >> 7) & 0x1)
+#define CALIB_BUF1_ID_V1(x) (((x) >> 9) & 0x1)
enum {
VTS1,
@@ -143,6 +143,11 @@
MAX_NUM_VTS,
+enum mtk_thermal_version {
+ MTK_THERMAL_V1 = 1,
+ MTK_THERMAL_V2,
/* MT2701 thermal sensors */
#define MT2701_TS1 0
#define MT2701_TS2 1
@@ -245,6 +250,9 @@
const int *controller_offset;
bool need_switch_bank;
struct thermal_bank_cfg bank_data[MAX_NUM_ZONES];
+ enum mtk_thermal_version version;
+ int (*extract)(struct mtk_thermal *mt, u32 *buf);
+ int (*convert)(struct mtk_thermal *mt, int sensno, s32 raw);
struct mtk_thermal {
@@ -358,6 +366,9 @@
static const int mt7622_vts_index[MT7622_NUM_SENSORS] = { VTS1 };
static const int mt7622_tc_offset[MT7622_NUM_CONTROLLER] = { 0x0, };
+static int mtk_thermal_extract_efuse_v1(struct mtk_thermal *mt, u32 *buf);
+static int raw_to_mcelsius_v1(struct mtk_thermal *mt, int sensno, s32 raw);
* The MT8173 thermal controller has four banks. Each bank can read up to
* four temperature sensors simultaneously. The MT8173 has a total of 5
@@ -398,6 +409,9 @@
.msr = mt8173_msr,
.adcpnp = mt8173_adcpnp,
.sensor_mux_values = mt8173_mux_values,
+ .version = MTK_THERMAL_V1,
+ .extract = mtk_thermal_extract_efuse_v1,
+ .convert = raw_to_mcelsius_v1,
@@ -428,6 +442,9 @@
.msr = mt2701_msr,
.adcpnp = mt2701_adcpnp,
.sensor_mux_values = mt2701_mux_values,
@@ -458,6 +475,9 @@
.msr = mt2712_msr,
.adcpnp = mt2712_adcpnp,
.sensor_mux_values = mt2712_mux_values,
@@ -482,6 +502,9 @@
.msr = mt7622_msr,
.adcpnp = mt7622_adcpnp,
.sensor_mux_values = mt7622_mux_values,
+ .version = MTK_THERMAL_V2,
@@ -515,6 +538,9 @@
.msr = mt8183_msr,
.adcpnp = mt8183_adcpnp,
.sensor_mux_values = mt8183_mux_values,
@@ -525,7 +551,7 @@
* This converts the raw ADC value to mcelsius using the SoC specific
* calibration constants
-static int raw_to_mcelsius(struct mtk_thermal *mt, int sensno, s32 raw)
s32 tmp;
@@ -594,9 +620,9 @@
raw = readl(mt->thermal_base +
conf->msr[conf->bank_data[bank->id].sensors[i]]);
- temp = raw_to_mcelsius(mt,
- conf->bank_data[bank->id].sensors[i],
- raw);
+ temp = conf->convert(mt,
+ conf->bank_data[bank->id].sensors[i],
+ raw);
* The first read of a sensor often contains very high bogus
@@ -698,9 +724,11 @@
writel(auxadc_phys_base + AUXADC_CON1_CLR_V,
controller_base + TEMP_ADCMUXADDR);
- /* AHB address for pnp sensor mux selection */
- writel(apmixed_phys_base + APMIXED_SYS_TS_CON1,
- controller_base + TEMP_PNPMUXADDR);
+ if (mt->conf->version == MTK_THERMAL_V1) {
+ /* AHB address for pnp sensor mux selection */
+ writel(apmixed_phys_base + APMIXED_SYS_TS_CON1,
+ controller_base + TEMP_PNPMUXADDR);
/* AHB value for auxadc enable */
writel(BIT(conf->auxadc_channel), controller_base + TEMP_ADCEN);
@@ -758,6 +786,51 @@
return of_translate_address(np, regaddr_p);
+ int i;
+ if (!(buf[0] & CALIB_BUF0_VALID_V1))
+ return -EINVAL;
+ mt->adc_ge = CALIB_BUF1_ADC_GE_V1(buf[1]);
+ for (i = 0; i < mt->conf->num_sensors; i++) {
+ switch (mt->conf->vts_index[i]) {
+ case VTS1:
+ mt->vts[VTS1] = CALIB_BUF0_VTS_TS1_V1(buf[0]);
+ break;
+ case VTS2:
+ mt->vts[VTS2] = CALIB_BUF0_VTS_TS2_V1(buf[0]);
+ break;
+ case VTS3:
+ mt->vts[VTS3] = CALIB_BUF1_VTS_TS3_V1(buf[1]);
+ break;
+ case VTS4:
+ mt->vts[VTS4] = CALIB_BUF2_VTS_TS4_V1(buf[2]);
+ break;
+ case VTS5:
+ mt->vts[VTS5] = CALIB_BUF2_VTS_TS5_V1(buf[2]);
+ break;
+ case VTSABB:
+ mt->vts[VTSABB] =
+ CALIB_BUF2_VTS_TSABB_V1(buf[2]);
+ break;
+ default:
+ break;
+ mt->degc_cali = CALIB_BUF0_DEGC_CALI_V1(buf[0]);
+ if (CALIB_BUF1_ID_V1(buf[1]) &
+ CALIB_BUF0_O_SLOPE_SIGN_V1(buf[0]))
+ mt->o_slope = -CALIB_BUF0_O_SLOPE_V1(buf[0]);
+ else
+ mt->o_slope = CALIB_BUF0_O_SLOPE_V1(buf[0]);
+ return 0;
static int mtk_thermal_get_calibration_data(struct device *dev,
struct mtk_thermal *mt)
@@ -793,42 +866,9 @@
goto out;
- if (buf[0] & CALIB_BUF0_VALID) {
- mt->adc_ge = CALIB_BUF1_ADC_GE(buf[1]);
- for (i = 0; i < mt->conf->num_sensors; i++) {
- switch (mt->conf->vts_index[i]) {
- case VTS1:
- mt->vts[VTS1] = CALIB_BUF0_VTS_TS1(buf[0]);
- break;
- case VTS2:
- mt->vts[VTS2] = CALIB_BUF0_VTS_TS2(buf[0]);
- break;
- case VTS3:
- mt->vts[VTS3] = CALIB_BUF1_VTS_TS3(buf[1]);
- break;
- case VTS4:
- mt->vts[VTS4] = CALIB_BUF2_VTS_TS4(buf[2]);
- break;
- case VTS5:
- mt->vts[VTS5] = CALIB_BUF2_VTS_TS5(buf[2]);
- break;
- case VTSABB:
- mt->vts[VTSABB] = CALIB_BUF2_VTS_TSABB(buf[2]);
- break;
- default:
- break;
- mt->degc_cali = CALIB_BUF0_DEGC_CALI(buf[0]);
- if (CALIB_BUF1_ID(buf[1]) &
- CALIB_BUF0_O_SLOPE_SIGN(buf[0]))
- mt->o_slope = -CALIB_BUF0_O_SLOPE(buf[0]);
- else
- mt->o_slope = CALIB_BUF0_O_SLOPE(buf[0]);
- } else {
+ if (mt->conf->extract(mt, buf)) {
dev_info(dev, "Device not calibrated, using default calibration values\n");
+ ret = -EINVAL;
out:
[2nd patch]: refine MT7622-specific settings to fix cpu-temp read error
- hardware init flow
- efuse layout
- raw_to_mcelsius formula
index 31dd1b4..65a86af 100644
@@ -38,6 +38,7 @@
#define TEMP_MONIDET0 0x014
#define TEMP_MONIDET1 0x018
#define TEMP_MSRCTL0 0x038
+#define TEMP_MSRCTL1 0x03c
#define TEMP_AHBPOLL 0x040
#define TEMP_AHBTO 0x044
#define TEMP_ADCPNP0 0x048
@@ -133,6 +134,20 @@
+ * Layout of the fuses providing the calibration data
+ * These macros could be used for MT7622.
+#define CALIB_BUF0_ADC_OE_V2(x) (((x) >> 22) & 0x3ff)
+#define CALIB_BUF0_ADC_GE_V2(x) (((x) >> 12) & 0x3ff)
+#define CALIB_BUF0_DEGC_CALI_V2(x) (((x) >> 6) & 0x3f)
+#define CALIB_BUF0_O_SLOPE_V2(x) (((x) >> 0) & 0x3f)
+#define CALIB_BUF1_VTS_TS1_V2(x) (((x) >> 23) & 0x1ff)
+#define CALIB_BUF1_VTS_TS2_V2(x) (((x) >> 14) & 0x1ff)
+#define CALIB_BUF1_VTS_TSABB_V2(x) (((x) >> 5) & 0x1ff)
+#define CALIB_BUF1_VALID_V2(x) (((x) >> 4) & 0x1)
+#define CALIB_BUF1_O_SLOPE_SIGN_V2(x) (((x) >> 3) & 0x1)
enum {
VTS1,
VTS2,
@@ -266,8 +281,10 @@
/* Calibration values */
s32 adc_ge;
+ s32 adc_oe;
s32 degc_cali;
s32 o_slope;
+ s32 o_slope_sign;
s32 vts[MAX_NUM_VTS];
const struct mtk_thermal_data *conf;
@@ -367,7 +384,9 @@
+static int mtk_thermal_extract_efuse_v2(struct mtk_thermal *mt, u32 *buf);
+static int raw_to_mcelsius_v2(struct mtk_thermal *mt, int sensno, s32 raw);
@@ -503,8 +522,8 @@
- .extract = mtk_thermal_extract_efuse_v1,
- .convert = raw_to_mcelsius_v1,
+ .extract = mtk_thermal_extract_efuse_v2,
+ .convert = raw_to_mcelsius_v2,
@@ -566,6 +585,36 @@
return mt->degc_cali * 500 - tmp;
+ s32 format_1 = 0;
+ s32 format_2 = 0;
+ s32 g_oe = 1;
+ s32 g_gain = 1;
+ s32 g_x_roomt = 0;
+ s32 tmp = 0;
+ if (raw == 0)
+ return 0;
+ raw &= 0xfff;
+ g_gain = 10000 + (((mt->adc_ge - 512) * 10000) >> 12);
+ g_oe = mt->adc_oe - 512;
+ format_1 = mt->vts[VTS2] + 3105 - g_oe;
+ format_2 = (mt->degc_cali * 10) >> 1;
+ g_x_roomt = (((format_1 * 10000) >> 12) * 10000) / g_gain;
+ tmp = (((((raw - g_oe) * 10000) >> 12) * 10000) / g_gain) - g_x_roomt;
+ tmp = tmp * 10 * 100 / 11;
+ if (mt->o_slope_sign == 0)
+ tmp = tmp / (165 - mt->o_slope);
+ else
+ tmp = tmp / (165 + mt->o_slope);
+ return (format_2 - tmp) * 100;
* mtk_thermal_get_bank - get bank
* @bank: The bank
@@ -831,6 +880,23 @@
return 0;
+ if (!CALIB_BUF1_VALID_V2(buf[1]))
+ return -EINVAL;
+ mt->adc_oe = CALIB_BUF0_ADC_OE_V2(buf[0]);
+ mt->adc_ge = CALIB_BUF0_ADC_GE_V2(buf[0]);
+ mt->degc_cali = CALIB_BUF0_DEGC_CALI_V2(buf[0]);
+ mt->o_slope = CALIB_BUF0_O_SLOPE_V2(buf[0]);
+ mt->vts[VTS1] = CALIB_BUF1_VTS_TS1_V2(buf[1]);
+ mt->vts[VTS2] = CALIB_BUF1_VTS_TS2_V2(buf[1]);
+ mt->vts[VTSABB] = CALIB_BUF1_VTS_TSABB_V2(buf[1]);
+ mt->o_slope_sign = CALIB_BUF1_O_SLOPE_SIGN_V2(buf[1]);
+ return 0;
@@ -902,6 +968,28 @@
MODULE_DEVICE_TABLE(of, mtk_thermal_of_match);
+static void mtk_thermal_turn_on_buffer(void __iomem *apmixed_base)
+ int tmp;
+ tmp = readl(apmixed_base + APMIXED_SYS_TS_CON1);
+ tmp &= ~(0x37);
+ tmp |= 0x1;
+ writel(tmp, apmixed_base + APMIXED_SYS_TS_CON1);
+ udelay(200);
+static void mtk_thermal_release_periodic_ts(struct mtk_thermal *mt,
+ void __iomem *auxadc_base)
+ int tmp;
+ writel(0x800, auxadc_base + AUXADC_CON1_SET_V);
+ writel(0x1, mt->thermal_base + TEMP_MONCTL0);
+ tmp = readl(mt->thermal_base + TEMP_MSRCTL1);
+ writel((tmp & (~0x10e)), mt->thermal_base + TEMP_MSRCTL1);
static int mtk_thermal_probe(struct platform_device *pdev)
int ret, i, ctrl_id;
@@ -910,6 +998,7 @@
struct resource *res;
u64 auxadc_phys_base, apmixed_phys_base;
struct thermal_zone_device *tzdev;
+ void __iomem *apmixed_base, *auxadc_base;
mt = devm_kzalloc(&pdev->dev, sizeof(*mt), GFP_KERNEL);
if (!mt)
@@ -944,6 +1033,7 @@
return -ENODEV;
+ auxadc_base = of_iomap(auxadc, 0);
auxadc_phys_base = of_get_phys_base(auxadc);
of_node_put(auxadc);
@@ -959,6 +1049,7 @@
return -ENODEV;
+ apmixed_base = of_iomap(apmixedsys, 0);
apmixed_phys_base = of_get_phys_base(apmixedsys);
of_node_put(apmixedsys);
@@ -984,6 +1075,11 @@
goto err_disable_clk_auxadc;
+ if (mt->conf->version == MTK_THERMAL_V2) {
+ mtk_thermal_turn_on_buffer(apmixed_base);
+ mtk_thermal_release_periodic_ts(mt, auxadc_base);
for (ctrl_id = 0; ctrl_id < mt->conf->num_controller ; ctrl_id++)
for (i = 0; i < mt->conf->num_banks; i++)
mtk_thermal_init_bank(mt, i, apmixed_phys_base,
Still wondering about the no calibration data on r2
