I have no mt7615 card…but tested an mt7612 and ath10k some time ago (imho before 5.4 was out)
I used mt7622 AP to connect / disconnect continuously with my mobile phone for hours, but couldn’t reproduce that connection issue. BTW, could you please enable the firmware debug log after boot up? Need to check if client is added/removed to/from staList correctly every time.
echo 2 > /sys/kernel/debug/ieee80211/phy1/mt76/fw_debug
[ 1918.379565] ieee80211 phy0: N9: (00062404577)StaRec[1] is added for staList
[ 1918.386614] ieee80211 phy0: N9: (00062404578)StaRec1 Tag 0x9
[ 1918.392444] ieee80211 phy0: N9: (00062404580)StaRec1 Tag 0xd
[ 1918.398268] ieee80211 phy0: N9: (00062404581)WTBL# Idx 1 Op 1
[ 1926.659687] ieee80211 phy0: N9: (00062676068)StaRec1 Tag 0x0
[ 1926.665522] ieee80211 phy0: N9: (00062676077)StaRec[1] is removed from staList
Hi, I guess the root cause is MSI. please try this patch https://patchwork.kernel.org/patch/11494641/
@Ryder.Lee Attached logs from FW.
MT7622_WIFI_FW_debug.7z (40.7 KB)
I restart R64 overnight and at the morning I was not able to connect to wifi even with devices that was connected before. If need more tests I will leave it running in that state for next few hours.
Thanks. I’ve co-worked with @Kosyak to reduce debugging scope today (in mt76-devel irc channel). I will make a patch to check sta_add flow soon.
I’m trying to include the patch you mentioned in the build, but my knowledge and understanding is simply not enough to get things right.
I had to make some modifications to the patch itself since it failed to apply to mt7622-rfb1.dts. I rewrote the section this way:
diff --git a/arch/arm64/boot/dts/mediatek/mt7622-rfb1.dts b/arch/arm64/boot/dts/mediatek/mt7622-rfb1.dts
index 3f783348c66a..2e6b4e37cb7d 100644
--- a/arch/arm64/boot/dts/mediatek/mt7622-rfb1.dts
+++ b/arch/arm64/boot/dts/mediatek/mt7622-rfb1.dts
@@ -244,18 +244,10 @@
-&pcie {
+&pcie0 {
pinctrl-names = "default";
- pinctrl-0 = <&pcie0_pins>, <&pcie1_pins>;
+ pinctrl-0 = <&pcie0_pins>;
status = "okay";
- pcie@0,0 {
- status = "okay";
- pcie@1,0 {
- status = "okay";
&pio {
But now I have this error upon build:
Error: /home/parallels/bpi-r64/openwrt/build_dir/target-aarch64_cortex-a53_musl/linux-mediatek_mt7622/linux-5.4.42/arch/arm64/boot/dts/mediatek/mt7622-elecom-wrc-2533gent.dts:168.1-6 Label or path pcie not found
FATAL ERROR: Syntax error parsing input tree
I figure it’s due to the following section in the mt7622-elecom-wrc-2533gent.dts file, but I don’t know what should I write there instead.
&pcie {
pinctrl-names = "default", "pcie1_pins";
pinctrl-1 = <&pcie1_pins>;
status = "okay";
pcie@0,0 {
status = "okay";
mt7615@0,0 {
reg = <0x0000 0 0 0 0>;
mediatek,mtd-eeprom = <&factory 0x05000>;
&pcie should probably be renamed to &pcie0 but what to do with the other lines?
Any advice?
Why not just disable the block with /* */ ? This dts is not needed for r64
Thank you. I renamed &pcie to &pcie0 just to make it compile.
But now it looks like that I’ve lost mk7615e completely.
Starting kernel ...
[ATF][ 23.907478]save kernel info
[ATF][ 23.910680]Kernel_EL2
[ATF][ 23.913436]Kernel is 64Bit
[ATF][ 23.916624]pc=0x41080000, r0=0x6bff6000, r1=0x0
INFO: BL3-1: Preparing for EL3 exit to normal world, Kernel
INFO: BL3-1: Next image address = 0x41080000
INFO: BL3-1: Next image spsr = 0x3c9
[ATF][ 23.934890]el3_exit
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 5.4.42 ([email protected]) (gcc version 8.4.0 (OpenWrt GCC 8.4.0 r13342-e35e40ad82)) #0 SMP Sat May 20
[ 0.000000] Machine model: Bananapi BPI-R64
[ 0.000000] On node 0 totalpages: 262096
[ 0.000000] DMA32 zone: 4096 pages used for memmap
[ 0.000000] DMA32 zone: 0 pages reserved
[ 0.000000] DMA32 zone: 262096 pages, LIFO batch:63
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv0.2 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] percpu: Embedded 20 pages/cpu s43608 r8192 d30120 u81920
[ 0.000000] pcpu-alloc: s43608 r8192 d30120 u81920 alloc=20*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1
[ 0.000000] CPU features: kernel page table isolation disabled by kernel configuration
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 258000
[ 0.000000] Kernel command line: board=bpi-r64 console=ttyS0,115200n1 earlyprintk root=/dev/mmcblk0p2 rootfstype=ext4 rootwait servi2
[ 0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.000000] Memory: 1018396K/1048384K available (6590K kernel code, 432K rwdata, 1896K rodata, 448K init, 285K bss, 29988K reserved,)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] rcu: CONFIG_RCU_FANOUT set to non-default value of 32.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] GIC: GICv2 detected, but range too small and irqchip.gicv2_force_probe not set
[ 0.000000] random: get_random_bytes called from start_kernel+0x2d4/0x430 with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 12.50MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049cda, max_idle_ns: 440795202628 ns
[ 0.000003] sched_clock: 56 bits at 12MHz, resolution 80ns, wraps every 4398046511080ns
[ 0.000169] Calibrating delay loop (skipped), value calculated using timer frequency.. 25.00 BogoMIPS (lpj=50000)
[ 0.000176] pid_max: default: 32768 minimum: 301
[ 0.000262] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
[ 0.000272] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
[ 0.001153] ASID allocator initialised with 65536 entries
[ 0.001202] rcu: Hierarchical SRCU implementation.
[ 0.001462] smp: Bringing up secondary CPUs ...
[ 0.001778] Detected VIPT I-cache on CPU1
[ 0.001815] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.001869] smp: Brought up 1 node, 2 CPUs
[ 0.001875] SMP: Total of 2 processors activated.
[ 0.001879] CPU features: detected: 32-bit EL0 Support
[ 0.001883] CPU features: detected: CRC32 instructions
[ 0.001984] CPU: All CPU(s) started at EL2
[ 0.001993] alternatives: patching kernel code
[ 0.005269] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.005283] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.005374] pinctrl core: initialized pinctrl subsystem
[ 0.005801] NET: Registered protocol family 16
[ 0.006082] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.017038] GPIO line 499 (asm_sel) hogged as output/high
[ 0.029753] SCSI subsystem initialized
[ 0.029903] libata version 3.00 loaded.
[ 0.030037] usbcore: registered new interface driver usbfs
[ 0.030063] usbcore: registered new interface driver hub
[ 0.030090] usbcore: registered new device driver usb
[ 0.030865] Bluetooth: Core ver 2.22
[ 0.030899] NET: Registered protocol family 31
[ 0.030902] Bluetooth: HCI device and connection manager initialized
[ 0.030910] Bluetooth: HCI socket layer initialized
[ 0.030916] Bluetooth: L2CAP socket layer initialized
[ 0.030927] Bluetooth: SCO socket layer initialized
[ 0.031408] clocksource: Switched to clocksource arch_sys_counter
[ 0.031880] thermal_sys: Registered thermal governor 'fair_share'
[ 0.031882] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.031887] thermal_sys: Registered thermal governor 'step_wise'
[ 0.031890] thermal_sys: Registered thermal governor 'user_space'
[ 0.031894] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.032150] NET: Registered protocol family 2
[ 0.032419] tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 8192 bytes, linear)
[ 0.032438] TCP established hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.032489] TCP bind hash table entries: 8192 (order: 5, 131072 bytes, linear)
[ 0.032594] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.032680] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.032701] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.032794] NET: Registered protocol family 1
[ 0.032813] PCI: CLS 0 bytes, default 64
[ 0.033576] workingset: timestamp_bits=46 max_order=18 bucket_order=0
[ 0.036898] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.036909] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.050240] mtk-tphy 1a0c4000.usb-phy: failed to get ref_clk(id-1)
[ 0.053430] mt-pmic-pwrap 10001000.pwrap: unexpected interrupt int=0x1
[ 0.067414] Serial: 8250/16550 driver, 3 ports, IRQ sharing disabled
[ 0.068049] printk: console [ttyS0] disabled
[ 0.088395] 11002000.serial: ttyS0 at MMIO 0x11002000 (irq = 118, base_baud = 1562500) is a ST16650V2
[ 0.629806] printk: console [ttyS0] enabled
[ 0.654669] 11004000.serial: ttyS1 at MMIO 0x11004000 (irq = 119, base_baud = 1562500) is a ST16650V2
[ 0.664352] 1100c000.serial: ttyS2 at MMIO 0x1100c000 (irq = 125, base_baud = 17499995) is a MediaTek BTIF
[ 0.674087] serial serial0: tty port ttyS2 registered
[ 0.679345] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 0.686878] libphy: Fixed MDIO Bus: probed
[ 0.714308] libphy: mdio: probed
[ 0.717576] mtk_soc_eth 1b100000.ethernet: generated random MAC address 6a:da:5c:29:1b:ae
[ 0.726019] mtk_soc_eth 1b100000.ethernet eth0: mediatek frame engine at 0xffffffc011500000, irq 134
[ 0.735173] mtk_soc_eth 1b100000.ethernet: generated random MAC address 66:08:0e:1e:72:8a
[ 0.743555] mtk_soc_eth 1b100000.ethernet eth1: mediatek frame engine at 0xffffffc011500000, irq 134
[ 0.752764] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.759288] ehci-pci: EHCI PCI platform driver
[ 0.763758] ehci-platform: EHCI generic platform driver
[ 0.769092] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.775295] ohci-platform: OHCI generic platform driver
[ 0.781056] usbcore: registered new interface driver usb-storage
[ 0.787444] rtc_mt7622 10212800.rtc: registered as rtc0
[ 0.793327] Driver for 1-wire Dallas network protocol.
[ 0.798682] mtk-thermal 1100b000.thermal: Device not calibrated, using default calibration values
[ 0.807869] mtk-wdt 10212000.watchdog: Watchdog enabled (timeout=31 sec, nowayout=0)
[ 0.815701] Bluetooth: HCI UART driver ver 2.3
[ 0.820142] Bluetooth: HCI UART protocol H4 registered
[ 0.825275] Bluetooth: HCI UART protocol BCSP registered
[ 0.830633] Bluetooth: HCI UART protocol Broadcom registered
[ 0.836306] Bluetooth: HCI UART protocol QCA registered
[ 0.867736] mtk-msdc 11240000.mmc: Got CD GPIO
[ 0.897879] NET: Registered protocol family 10
[ 0.902965] Segment Routing with IPv6
[ 0.906676] NET: Registered protocol family 17
[ 0.911139] 8021q: 802.1Q VLAN Support v1.8
[ 0.925745] mtk-pcie 1a143000.pcie: host bridge /pcie@1a143000 ranges:
[ 0.932298] mtk-pcie 1a143000.pcie: Parsing ranges property...
[ 0.938134] mtk-pcie 1a143000.pcie: MEM 0x20000000..0x27ffffff -> 0x20000000
[ 0.988509] mtk-msdc 11230000.mmc: phase: [map:fffffff] [maxlen:28] [final:9]
[ 0.996416] mmc0: new HS200 MMC card at address 0001
[ 1.002539] mmcblk0: mmc0:0001 008G30 7.28 GiB
[ 1.007975] mmcblk0boot0: mmc0:0001 008G30 partition 1 4.00 MiB
[ 1.014791] mmcblk0boot1: mmc0:0001 008G30 partition 2 4.00 MiB
[ 1.020775] mmcblk0rpmb: mmc0:0001 008G30 partition 3 4.00 MiB, chardev (250:0)
[ 1.029282] mmcblk0: p1 p2
[ 1.045492] mtk-pcie 1a143000.pcie: Port0 link down
[ 1.050519] mtk-pcie 1a143000.pcie: PCI host bridge to bus 0000:00
[ 1.056707] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.062190] pci_bus 0000:00: root bus resource [mem 0x20000000-0x27ffffff]
[ 1.069061] pci_bus 0000:00: scanning bus
[ 1.074279] pci_bus 0000:00: fixups for bus
[ 1.078459] pci_bus 0000:00: bus scan returning with max=00
[ 1.084251] mtk-pcie 1a145000.pcie: host bridge /pcie@1a145000 ranges:
[ 1.090783] mtk-pcie 1a145000.pcie: Parsing ranges property...
[ 1.096623] mtk-pcie 1a145000.pcie: MEM 0x28000000..0x2fffffff -> 0x28000000
[ 1.103932] mtk-pcie 1a145000.pcie: IRQ index 1 not found
[ 1.209357] mtk-pcie 1a145000.pcie: Port1 link down
[ 1.214328] mtk-pcie 1a145000.pcie: PCI host bridge to bus 0001:00
[ 1.220510] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 1.225993] pci_bus 0001:00: root bus resource [mem 0x28000000-0x2fffffff]
[ 1.232864] pci_bus 0001:00: scanning bus
[ 1.238011] pci_bus 0001:00: fixups for bus
[ 1.242193] pci_bus 0001:00: bus scan returning with max=00
[ 1.247885] mtk_hsdma 1b007000.dma-controller: Using 3 as missing dma-requests property
[ 1.256068] mtk_hsdma 1b007000.dma-controller: MediaTek HSDMA driver registered
[ 1.827418] mt753x gsw@0: LAN/WAN VLAN setting=wllll
[ 1.832837] mt753x gsw@0: Switch is MediaTek MT7531BE rev 0
[ 6.474879] xhci-mtk 1a0c0000.usb: xHCI Host Controller
[ 6.480115] xhci-mtk 1a0c0000.usb: new USB bus registered, assigned bus number 1
[ 6.489162] xhci-mtk 1a0c0000.usb: hcc params 0x01403198 hci version 0x96 quirks 0x0000000000210010
[ 6.498233] xhci-mtk 1a0c0000.usb: irq 130, io mem 0x1a0c0000
[ 6.504368] hub 1-0:1.0: USB hub found
[ 6.508134] hub 1-0:1.0: 2 ports detected
[ 6.512354] xhci-mtk 1a0c0000.usb: xHCI Host Controller
[ 6.517584] xhci-mtk 1a0c0000.usb: new USB bus registered, assigned bus number 2
[ 6.524980] xhci-mtk 1a0c0000.usb: Host supports USB 3.0 SuperSpeed
[ 6.531274] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 6.539587] hub 2-0:1.0: USB hub found
[ 6.543340] hub 2-0:1.0: 1 port detected
[ 6.547600] rtc_mt7622 10212800.rtc: setting system clock to 2020-05-29T11:36:50 UTC (1590752210)
[ 6.562687] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 6.570845] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 6.577818] Freeing unused kernel memory: 448K
[ 6.587407] Run /sbin/init as init process
[ 6.640761] init: Console is alive
[ 6.644264] init: - watchdog -
[ 6.683513] random: fast init done
[ 6.769251] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[ 6.782971] ehci-fsl: Freescale EHCI Host controller driver
[ 6.793066] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[ 6.808844] init: - preinit -
[ 6.889308] mtk_soc_eth 1b100000.ethernet: PPE started
[ 6.894490] mtk_soc_eth 1b100000.ethernet eth0: configuring for fixed/2500base-x link mode
[ 6.902809] mtk_soc_eth 1b100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
Press [ 6.919436] usb 1-2: new high-speed USB device number 2 using xhci-mtk
the [1], [2], [3] or [4] key and hit [enter] to select the debug level
[ 7.147106] usb-storage 1-2:1.0: USB Mass Storage device detected
[ 7.153441] random: procd: uninitialized urandom read (4 bytes read)
[ 7.153468] scsi host0: usb-storage 1-2:1.0
[ 8.197074] scsi 0:0:0:0: Direct-Access JetFlash Transcend 4GB 8.07 PQ: 0 ANSI: 2
[ 8.206292] sd 0:0:0:0: [sda] 7847936 512-byte logical blocks: (4.02 GB/3.74 GiB)
[ 8.213936] sd 0:0:0:0: [sda] Write Protect is off
[ 8.218728] sd 0:0:0:0: [sda] Mode Sense: 03 00 00 00
[ 8.223917] sd 0:0:0:0: [sda] No Caching mode page found
[ 8.229231] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 8.422453] sda: sda1
[ 8.425753] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 10.936852] mount_root: mounting /dev/root
[ 10.942710] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 10.948232] mount_root: loading kmods from internal overlay
[ 10.962171] kmodloader: loading kernel modules from //etc/modules-boot.d/*
[ 10.969796] kmodloader: done loading kernel modules from //etc/modules-boot.d/*
[ 11.097395] urandom-seed: Seed file not found (/etc/urandom.seed)
[ 11.110282] procd: - early -
[ 11.113237] procd: - watchdog -
[ 11.631049] procd: - watchdog -
[ 11.634313] procd: - ubus -
[ 11.641140] random: ubusd: uninitialized urandom read (4 bytes read)
[ 11.687434] random: ubusd: uninitialized urandom read (4 bytes read)
[ 11.693899] random: ubusd: uninitialized urandom read (4 bytes read)
[ 11.700507] procd: - init -
[ 11.781378] urngd: v1.0.2 started.
[ 11.801564] kmodloader: loading kernel modules from /etc/modules.d/*
[ 11.807706] random: crng init done
[ 11.811324] random: 6 urandom warning(s) missed due to ratelimiting
[ 11.825835] tun: Universal TUN/TAP device driver, 1.6
[ 11.841368] cryptodev: driver 1.10 loaded.
[ 11.848235] i2c /dev entries driver
[ 11.858441] hidraw: raw HID events driver (C) Jiri Kosina
[ 11.866060] Mirror/redirect action on
[ 11.873352] u32 classifier
[ 11.876092] input device check on
[ 11.879749] Actions configured
[ 11.900076] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 11.905411] Bluetooth: BNEP filters: protocol multicast
[ 11.910643] Bluetooth: BNEP socket layer initialized
[ 11.917486] usbcore: registered new interface driver btusb
[ 11.923904] usbcore: registered new interface driver cdc_wdm
[ 11.930150] Loading modules backported from Linux version v5.7-rc3-0-g6a8b55ed4056
[ 11.937735] Backport generated by backports.git v5.7-rc3-1-0-gc0c7d2bb
[ 11.945442] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 11.951393] Bluetooth: HIDP socket layer initialized
[ 11.966364] Bluetooth: RFCOMM TTY layer initialized
[ 11.971285] Bluetooth: RFCOMM socket layer initialized
[ 11.976438] Bluetooth: RFCOMM ver 1.11
[ 11.981809] usbcore: registered new interface driver ums-alauda
[ 11.988284] usbcore: registered new interface driver ums-cypress
[ 11.994636] usbcore: registered new interface driver ums-datafab
[ 12.000938] usbcore: registered new interface driver ums-freecom
[ 12.007256] usbcore: registered new interface driver ums-isd200
[ 12.013484] usbcore: registered new interface driver ums-jumpshot
[ 12.019863] usbcore: registered new interface driver ums-karma
[ 12.026067] usbcore: registered new interface driver ums-sddr09
[ 12.032307] usbcore: registered new interface driver ums-sddr55
[ 12.038592] usbcore: registered new interface driver ums-usbat
[ 12.048576] wireguard: WireGuard 1.0.20200520 loaded. See www.wireguard.com for information.
[ 12.057034] wireguard: Copyright (C) 2015-2019 Jason A. Donenfeld <[email protected]>. All Rights Reserved.
[ 12.076533] xt_time: kernel timezone is -0000
[ 12.081505] usbcore: registered new interface driver cdc_ether
[ 12.139656] mt7622-wmac 18000000.wmac: Invalid MAC address, using random address fa:2c:f2:67:82:e2
[ 12.149686] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[ 12.172091] PPP generic driver version 2.4.2
[ 12.177543] NET: Registered protocol family 24
[ 12.183392] usbcore: registered new interface driver qmi_wwan
[ 12.189357] mt7622-wmac 18000000.wmac: HW/SW Version: 0x8a108a10, Build Time: 20190801210006a
[ 12.189357]
[ 12.200925] kmodloader: done loading kernel modules from /etc/modules.d/*
[ 12.219505] mt7622-wmac 18000000.wmac: N9 Firmware Version: 2.0, Build Time: 20200131180931
[ 18.416722] mtk_soc_eth 1b100000.ethernet eth0: Link is Down
[ 18.425276] mtk_soc_eth 1b100000.ethernet: 0x100 = 0xffff9070, 0x10c = 0x100808ff
[ 18.432804] mtk_soc_eth 1b100000.ethernet: reset pse
[ 18.522186] mtk_soc_eth 1b100000.ethernet: PPE started
[ 18.527423] debugfs: Directory 'mtk_ppe' with parent '/' already present!
[ 18.534270] mtk_soc_eth 1b100000.ethernet eth0: configuring for fixed/2500base-x link mode
[ 18.542799] mtk_soc_eth 1b100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
[ 18.552071] br-lan: port 1(eth0) entered blocking state
[ 18.557369] br-lan: port 1(eth0) entered disabled state
[ 18.562825] device eth0 entered promiscuous mode
[ 18.573352] br-lan: port 1(eth0) entered blocking state
[ 18.578610] br-lan: port 1(eth0) entered forwarding state
[ 18.589158] mtk_soc_eth 1b100000.ethernet eth1: configuring for fixed/rgmii link mode
[ 18.597171] mtk_soc_eth 1b100000.ethernet eth1: Link is Up - 1Gbps/Full - flow control rx/tx
And here is iw dev output
root@OpenWrt:/# iw dev
phy#0
Interface wlan0
ifindex 4
wdev 0x1
addr fa:2c:f2:67:82:e2
type managed
txpower 6.00 dBm
multicast TXQ:
qsz-byt qsz-pkt flows drops marks overlmt hashcol tx-bytes tx-packets
0 0 0 0 0 0 0 0 0
you have an bpi-r64, right? not the reference-board or the elecom…
then you need to look in the mt7622-bananapi-r64.dts if the pcie0/1 are enabled. show us output of lspci
lspci is empty. I had to recompile once again to include busybox.
mt7622-bananapi-bpi-r64.dts is as follows.
* Copyright (c) 2018 MediaTek Inc.
* Author: Ryder Lee <[email protected]>
* SPDX-License-Identifier: (GPL-2.0 OR MIT)
/dts-v1/;
#include <dt-bindings/input/input.h>
#include <dt-bindings/gpio/gpio.h>
#include "mt7622.dtsi"
#include "mt6380.dtsi"
model = "Bananapi BPI-R64";
compatible = "bananapi,bpi-r64", "mediatek,mt7622";
aliases {
serial0 = &uart0;
chosen {
stdout-path = "serial0:115200n8";
bootargs = "earlycon=uart8250,mmio32,0x11002000 console=ttyS0,115200n1 swiotlb=512 debug loglevel=7 rootfstype=squashfs,ext4 earlyprintk block2mtd.block2mtd=/dev/mmcblk0,65536,eMMC,5 mtdparts=eMMC:768k(preloader)ro,512k(uboot),512k(uboot-env),256k(Factory),64M(firmware),2048M(usrdata)";
cpus {
cpu@0 {
proc-supply = <&mt6380_vcpu_reg>;
sram-supply = <&mt6380_vm_reg>;
cpu@1 {
gpio-keys {
compatible = "gpio-keys";
factory {
label = "factory";
linux,code = <BTN_0>;
gpios = <&pio 0 GPIO_ACTIVE_HIGH>;
wps {
label = "wps";
linux,code = <KEY_WPS_BUTTON>;
gpios = <&pio 102 GPIO_ACTIVE_HIGH>;
gsw: gsw@0 {
compatible = "mediatek,mt753x";
mediatek,ethsys = <ðsys>;
#address-cells = <1>;
#size-cells = <0>;
leds {
compatible = "gpio-leds";
green {
label = "bpi-r64:pio:green";
gpios = <&pio 89 GPIO_ACTIVE_HIGH>;
default-state = "off";
red {
label = "bpi-r64:pio:red";
gpios = <&pio 88 GPIO_ACTIVE_HIGH>;
memory {
reg = <0 0x40000000 0 0x40000000>;
reg_1p8v: regulator-1p8v {
compatible = "regulator-fixed";
regulator-name = "fixed-1.8V";
regulator-min-microvolt = <1800000>;
regulator-max-microvolt = <1800000>;
regulator-always-on;
reg_3p3v: regulator-3p3v {
regulator-name = "fixed-3.3V";
regulator-min-microvolt = <3300000>;
regulator-max-microvolt = <3300000>;
regulator-boot-on;
reg_5v: regulator-5v {
regulator-name = "fixed-5V";
regulator-min-microvolt = <5000000>;
regulator-max-microvolt = <5000000>;
regulator-boot-on;
&bch {
status = "disabled";
&btif {
status = "okay";
&cir {
pinctrl-0 = <&irrx_pins>;
status = "okay";
ð {
status = "okay";
gmac0: mac@0 {
compatible = "mediatek,eth-mac";
reg = <0>;
phy-mode = "2500base-x";
fixed-link {
speed = <2500>;
full-duplex;
pause;
gmac1: mac@1 {
reg = <1>;
phy-mode = "rgmii";
fixed-link {
speed = <1000>;
full-duplex;
pause;
mdio: mdio-bus {
#size-cells = <0>;
&gsw {
mediatek,mdio = <&mdio>;
mediatek,portmap = "wllll";
mediatek,mdio_master_pinmux = <0>;
reset-gpios = <&pio 54 0>;
interrupt-parent = <&pio>;
interrupts = <53 IRQ_TYPE_LEVEL_HIGH>;
status = "okay";
port5: port@5 {
compatible = "mediatek,mt753x-port";
reg = <5>;
phy-mode = "rgmii";
fixed-link {
speed = <1000>;
full-duplex;
port6: port@6 {
reg = <6>;
phy-mode = "sgmii";
fixed-link {
speed = <2500>;
full-duplex;
&i2c1 {
pinctrl-0 = <&i2c1_pins>;
status = "okay";
&i2c2 {
pinctrl-0 = <&i2c2_pins>;
status = "okay";
&mmc0 {
pinctrl-names = "default", "state_uhs";
pinctrl-0 = <&emmc_pins_default>;
pinctrl-1 = <&emmc_pins_uhs>;
status = "okay";
bus-width = <8>;
max-frequency = <50000000>;
cap-mmc-highspeed;
mmc-hs200-1_8v;
vmmc-supply = <®_3p3v>;
vqmmc-supply = <®_1p8v>;
assigned-clocks = <&topckgen CLK_TOP_MSDC30_0_SEL>;
assigned-clock-parents = <&topckgen CLK_TOP_UNIV48M>;
non-removable;
emmc@0 {
#size-cells = <1>;
compatible = "mmc-card";
reg = <0>;
partitions {
compatible = "fixed-partitions";
#size-cells = <1>;
partition@0 {
label = "preloader";
reg = <0x0000000 0x000c0000>;
read-only;
partition@c0000 {
label = "uboot";
reg = <0x00c0000 0x00140000>;
partition@140000 {
label = "uboot-env";
reg = <0x0140000 0x001c0000>;
factory: partition@1c0000 {
label = "Factory";
reg = <0x01c0000 0x00200000>;
partition@200000 {
label = "firmware";
reg = <0x0200000 0x02200000>;
partition@2200000 {
label = "usrdata";
reg = <0x2200000 0x82200000>;
&mmc1 {
pinctrl-0 = <&sd0_pins_default>;
pinctrl-1 = <&sd0_pins_uhs>;
status = "okay";
bus-width = <4>;
cap-sd-highspeed;
r_smpl = <1>;
cd-gpios = <&pio 81 GPIO_ACTIVE_LOW>;
vqmmc-supply = <®_3p3v>;
assigned-clocks = <&topckgen CLK_TOP_MSDC30_1_SEL>;
&nandc {
pinctrl-0 = <¶llel_nand_pins>;
&nor_flash {
pinctrl-0 = <&spi_nor_pins>;
flash@0 {
compatible = "jedec,spi-nor";
reg = <0>;
&pcie0 {
status = "okay";
&pcie1 {
pinctrl-0 = <&pcie1_pins>;
status = "okay";
&pio {
/* Attention: GPIO 90 is used to switch between PCIe@1,0 and
* SATA functions. i.e. output-high: PCIe, output-low: SATA
asm_sel {
gpio-hog;
gpios = <90 GPIO_ACTIVE_HIGH>;
output-high;
/* eMMC is shared pin with parallel NAND */
emmc_pins_default: emmc-pins-default {
mux {
function = "emmc", "emmc_rst";
groups = "emmc";
/* "NDL0","NDL1","NDL2","NDL3","NDL4","NDL5","NDL6","NDL7",
* "NRB","NCLE" pins are used as DAT0,DAT1,DAT2,DAT3,DAT4,
* DAT5,DAT6,DAT7,CMD,CLK for eMMC respectively
conf-cmd-dat {
pins = "NDL0", "NDL1", "NDL2",
"NDL3", "NDL4", "NDL5",
"NDL6", "NDL7", "NRB";
input-enable;
bias-pull-up;
conf-clk {
pins = "NCLE";
bias-pull-down;
emmc_pins_uhs: emmc-pins-uhs {
mux {
function = "emmc";
groups = "emmc";
conf-cmd-dat {
input-enable;
drive-strength = <4>;
bias-pull-up;
conf-clk {
pins = "NCLE";
bias-pull-down;
eth_pins: eth-pins {
mux {
function = "eth";
groups = "mdc_mdio", "rgmii_via_gmac2";
i2c1_pins: i2c1-pins {
mux {
function = "i2c";
groups = "i2c1_0";
i2c2_pins: i2c2-pins {
mux {
function = "i2c";
groups = "i2c2_0";
i2s1_pins: i2s1-pins {
mux {
function = "i2s";
groups = "i2s_out_mclk_bclk_ws",
"i2s1_in_data",
"i2s1_out_data";
conf {
pins = "I2S1_IN", "I2S1_OUT", "I2S_BCLK",
"I2S_WS", "I2S_MCLK";
drive-strength = <12>;
bias-pull-down;
irrx_pins: irrx-pins {
mux {
function = "ir";
groups = "ir_1_rx";
irtx_pins: irtx-pins {
mux {
function = "ir";
groups = "ir_1_tx";
/* Parallel nand is shared pin with eMMC */
parallel_nand_pins: parallel-nand-pins {
mux {
function = "flash";
groups = "par_nand";
pcie0_pins: pcie0-pins {
mux {
function = "pcie";
groups = "pcie0_pad_perst",
"pcie0_1_waken",
"pcie0_1_clkreq";
pcie1_pins: pcie1-pins {
mux {
function = "pcie";
groups = "pcie1_pad_perst",
"pcie1_0_waken",
"pcie1_0_clkreq";
pmic_bus_pins: pmic-bus-pins {
mux {
function = "pmic";
groups = "pmic_bus";
pwm7_pins: pwm1-2-pins {
mux {
function = "pwm";
groups = "pwm_ch7_2";
wled_pins: wled-pins {
mux {
function = "led";
groups = "wled";
sd0_pins_default: sd0-pins-default {
mux {
function = "sd";
groups = "sd_0";
/* "I2S2_OUT, "I2S4_IN"", "I2S3_IN", "I2S2_IN",
* "I2S4_OUT", "I2S3_OUT" are used as DAT0, DAT1,
* DAT2, DAT3, CMD, CLK for SD respectively.
conf-cmd-data {
pins = "I2S2_OUT", "I2S4_IN", "I2S3_IN",
"I2S2_IN","I2S4_OUT";
input-enable;
drive-strength = <8>;
bias-pull-up;
conf-clk {
pins = "I2S3_OUT";
bias-pull-down;
conf-cd {
pins = "TXD3";
bias-pull-up;
sd0_pins_uhs: sd0-pins-uhs {
mux {
function = "sd";
groups = "sd_0";
conf-cmd-data {
input-enable;
bias-pull-up;
conf-clk {
pins = "I2S3_OUT";
bias-pull-down;
/* Serial NAND is shared pin with SPI-NOR */
serial_nand_pins: serial-nand-pins {
mux {
function = "flash";
groups = "snfi";
spic0_pins: spic0-pins {
mux {
function = "spi";
groups = "spic0_0";
spic1_pins: spic1-pins {
mux {
function = "spi";
groups = "spic1_0";
/* SPI-NOR is shared pin with serial NAND */
spi_nor_pins: spi-nor-pins {
mux {
function = "flash";
groups = "spi_nor";
/* serial NAND is shared pin with SPI-NOR */
mux {
function = "flash";
groups = "snfi";
uart0_pins: uart0-pins {
mux {
function = "uart";
groups = "uart0_0_tx_rx" ;
uart2_pins: uart2-pins {
mux {
function = "uart";
groups = "uart2_1_tx_rx" ;
watchdog_pins: watchdog-pins {
mux {
function = "watchdog";
groups = "watchdog";
&pwm {
pinctrl-0 = <&pwm7_pins>;
status = "okay";
&pwrap {
pinctrl-0 = <&pmic_bus_pins>;
status = "okay";
&sata {
status = "disable";
&sata_phy {
status = "disable";
&spi0 {
pinctrl-0 = <&spic0_pins>;
status = "okay";
&spi1 {
pinctrl-0 = <&spic1_pins>;
status = "okay";
&ssusb {
vusb33-supply = <®_3p3v>;
vbus-supply = <®_5v>;
status = "okay";
&u3phy {
status = "okay";
&uart0 {
pinctrl-0 = <&uart0_pins>;
status = "okay";
&uart2 {
pinctrl-0 = <&uart2_pins>;
status = "okay";
&watchdog {
pinctrl-0 = <&watchdog_pins>;
status = "okay";
&wmac {
status = "okay";
&wmac {
status = "okay";
Dts looks right…from your dmesg it looks like both ports are down…maybe something power-related? Can you compare your dtsi with mine (5.4-main branch except switch driver)? Have you added the other patches i’ve mentioned (irq handling, class fix)?
Looks like I found the culprit.
I just needed to apply all four patches from Spilt PCIe node to comply with hardware design series. I had to make some modifications as I mentioned above since mt7622-rfb1.dts from OpenWRT is a little bit different from what the patch is expecting (see attachments).
1002_1-dt-bindings-PCI-Mediatek-Update-PCIe-binding.patch (9.0 KB)
1002_2-mediatek-Use-regmap-to-get-shared-pcie-cfg-base.patch (2.7 KB)
1002_3-Split_PCIe_node_for_MT2712-MT7622.patch (7.9 KB)
1002_4-ARM-dts-mediatek-Update-mt7629-PCIe-node.patch (2.0 KB)
BTW is there a more elegant way of obtaining these patches rather than select - copy - paste to text editor - save as .patch - put in patches-5.4 dir?
Starting kernel ...
[ATF][ 26.267559]save kernel info
[ATF][ 26.270760]Kernel_EL2
[ATF][ 26.273516]Kernel is 64Bit
[ATF][ 26.276704]pc=0x41080000, r0=0x6bff6000, r1=0x0
[ATF][ 26.294971]el3_exit
[ 0.000000] Linux version 5.4.42 ([email protected]) (gcc version 8.4.0 (OpenWrt GCC 8.4.0 r13342-e35e40ad82)) #0 SMP Fri May 20
[ 0.000168] Calibrating delay loop (skipped), value calculated using timer frequency.. 25.00 BogoMIPS (lpj=50000)
[ 0.000175] pid_max: default: 32768 minimum: 301
[ 0.000260] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
[ 0.000271] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
[ 0.001203] rcu: Hierarchical SRCU implementation.
[ 0.001461] smp: Bringing up secondary CPUs ...
[ 0.001782] Detected VIPT I-cache on CPU1
[ 0.001819] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.001873] smp: Brought up 1 node, 2 CPUs
[ 0.001880] SMP: Total of 2 processors activated.
[ 0.001884] CPU features: detected: 32-bit EL0 Support
[ 0.001888] CPU features: detected: CRC32 instructions
[ 0.001988] CPU: All CPU(s) started at EL2
[ 0.001998] alternatives: patching kernel code
[ 0.005276] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.005288] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.005379] pinctrl core: initialized pinctrl subsystem
[ 0.005808] NET: Registered protocol family 16
[ 0.006088] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.017063] GPIO line 499 (asm_sel) hogged as output/high
[ 0.029735] SCSI subsystem initialized
[ 0.029890] libata version 3.00 loaded.
[ 0.030022] usbcore: registered new interface driver usbfs
[ 0.030052] usbcore: registered new interface driver hub
[ 0.030078] usbcore: registered new device driver usb
[ 0.030859] Bluetooth: Core ver 2.22
[ 0.030890] NET: Registered protocol family 31
[ 0.030894] Bluetooth: HCI device and connection manager initialized
[ 0.030901] Bluetooth: HCI socket layer initialized
[ 0.030908] Bluetooth: L2CAP socket layer initialized
[ 0.030919] Bluetooth: SCO socket layer initialized
[ 0.031382] clocksource: Switched to clocksource arch_sys_counter
[ 0.031850] thermal_sys: Registered thermal governor 'fair_share'
[ 0.031853] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.031858] thermal_sys: Registered thermal governor 'step_wise'
[ 0.031861] thermal_sys: Registered thermal governor 'user_space'
[ 0.031865] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.032119] NET: Registered protocol family 2
[ 0.032394] tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 8192 bytes, linear)
[ 0.032413] TCP established hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.032464] TCP bind hash table entries: 8192 (order: 5, 131072 bytes, linear)
[ 0.032570] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.032658] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.032680] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.032770] NET: Registered protocol family 1
[ 0.032789] PCI: CLS 0 bytes, default 64
[ 0.033547] workingset: timestamp_bits=46 max_order=18 bucket_order=0
[ 0.050389] mtk-tphy 1a0c4000.usb-phy: failed to get ref_clk(id-1)
[ 0.053638] mt-pmic-pwrap 10001000.pwrap: unexpected interrupt int=0x1
[ 0.067647] Serial: 8250/16550 driver, 3 ports, IRQ sharing disabled
[ 0.068299] printk: console [ttyS0] disabled
[ 0.088649] 11002000.serial: ttyS0 at MMIO 0x11002000 (irq = 118, base_baud = 1562500) is a ST16650V2
[ 0.630082] printk: console [ttyS0] enabled
[ 0.654977] 11004000.serial: ttyS1 at MMIO 0x11004000 (irq = 119, base_baud = 1562500) is a ST16650V2
[ 0.664689] 1100c000.serial: ttyS2 at MMIO 0x1100c000 (irq = 125, base_baud = 17499995) is a MediaTek BTIF
[ 0.674422] serial serial0: tty port ttyS2 registered
[ 0.679677] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 0.687251] libphy: Fixed MDIO Bus: probed
[ 0.714662] libphy: mdio: probed
[ 0.717928] mtk_soc_eth 1b100000.ethernet: generated random MAC address c6:eb:14:54:30:ca
[ 0.726374] mtk_soc_eth 1b100000.ethernet eth0: mediatek frame engine at 0xffffffc011520000, irq 134
[ 0.735526] mtk_soc_eth 1b100000.ethernet: generated random MAC address fa:17:a9:bf:07:90
[ 0.743901] mtk_soc_eth 1b100000.ethernet eth1: mediatek frame engine at 0xffffffc011520000, irq 134
[ 0.753108] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.759632] ehci-pci: EHCI PCI platform driver
[ 0.764101] ehci-platform: EHCI generic platform driver
[ 0.769436] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.775625] ohci-platform: OHCI generic platform driver
[ 0.781397] usbcore: registered new interface driver usb-storage
[ 0.787765] rtc_mt7622 10212800.rtc: registered as rtc0
[ 0.793646] Driver for 1-wire Dallas network protocol.
[ 0.798993] mtk-thermal 1100b000.thermal: Device not calibrated, using default calibration values
[ 0.808183] mtk-wdt 10212000.watchdog: Watchdog enabled (timeout=31 sec, nowayout=0)
[ 0.816018] Bluetooth: HCI UART driver ver 2.3
[ 0.820460] Bluetooth: HCI UART protocol H4 registered
[ 0.825593] Bluetooth: HCI UART protocol BCSP registered
[ 0.830951] Bluetooth: HCI UART protocol Broadcom registered
[ 0.836628] Bluetooth: HCI UART protocol QCA registered
[ 0.867707] mtk-msdc 11240000.mmc: Got CD GPIO
[ 0.897832] NET: Registered protocol family 10
[ 0.902895] Segment Routing with IPv6
[ 0.906609] NET: Registered protocol family 17
[ 0.911072] 8021q: 802.1Q VLAN Support v1.8
[ 0.925772] mtk-pcie 1a143000.pcie: host bridge /pcie@1a143000 ranges:
[ 0.932323] mtk-pcie 1a143000.pcie: Parsing ranges property...
[ 0.938159] mtk-pcie 1a143000.pcie: MEM 0x20000000..0x27ffffff -> 0x20000000
[ 0.969503] mtk-pcie 1a143000.pcie: PCI host bridge to bus 0000:00
[ 0.975692] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.981174] pci_bus 0000:00: root bus resource [mem 0x20000000-0x27ffffff]
[ 0.988045] pci_bus 0000:00: scanning bus
[ 0.992080] pci 0000:00:00.0: [14c3:3258] type 01 class 0x060400
[ 0.998176] pci 0000:00:00.0: reg 0x10: [mem 0x00000000-0x1ffffffff 64bit pref]
[ 1.007056] pci_bus 0000:00: fixups for bus
[ 1.011252] pci 0000:00:00.0: scanning [bus 00-00] behind bridge, pass 0
[ 1.017949] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 1.025968] pci 0000:00:00.0: scanning [bus 00-00] behind bridge, pass 1
[ 1.032798] pci_bus 0000:01: scanning bus
[ 1.036937] pci 0000:01:00.0: [14c3:7615] type 00 class 0x000280
[ 1.043170] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x000fffff 64bit]
[ 1.050887] pci 0000:01:00.0: 2.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s x1 link at 0000:00:00.0 (capable of 4.000 Gb/)
[ 1.065983] pci_bus 0000:01: fixups for bus
[ 1.070164] pci_bus 0000:01: bus scan returning with max=01
[ 1.075738] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 1.082362] pci_bus 0000:00: bus scan returning with max=01
[ 1.087946] pci 0000:00:00.0: BAR 0: no space for [mem size 0x200000000 64bit pref]
[ 1.095599] pci 0000:00:00.0: BAR 0: failed to assign [mem size 0x200000000 64bit pref]
[ 1.103599] pci 0000:00:00.0: BAR 8: assigned [mem 0x20000000-0x200fffff]
[ 1.110385] pci 0000:01:00.0: BAR 0: assigned [mem 0x20000000-0x200fffff 64bit]
[ 1.117774] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 1.122751] pci 0000:00:00.0: bridge window [mem 0x20000000-0x200fffff]
[ 1.129775] mtk-pcie 1a145000.pcie: host bridge /pcie@1a145000 ranges:
[ 1.136303] mtk-pcie 1a145000.pcie: Parsing ranges property...
[ 1.142137] mtk-pcie 1a145000.pcie: MEM 0x28000000..0x2fffffff -> 0x28000000
[ 1.168099] mtk-msdc 11230000.mmc: phase: [map:fffffff] [maxlen:28] [final:9]
[ 1.176016] mmc0: new HS200 MMC card at address 0001
[ 1.182132] mmcblk0: mmc0:0001 008G30 7.28 GiB
[ 1.187577] mmcblk0boot0: mmc0:0001 008G30 partition 1 4.00 MiB
[ 1.194381] mmcblk0boot1: mmc0:0001 008G30 partition 2 4.00 MiB
[ 1.200357] mmcblk0rpmb: mmc0:0001 008G30 partition 3 4.00 MiB, chardev (250:0)
[ 1.208857] mmcblk0: p1 p2
[ 1.249492] mtk-pcie 1a145000.pcie: Port1 link down
[ 1.254486] mtk-pcie 1a145000.pcie: PCI host bridge to bus 0001:00
[ 1.260669] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 1.266153] pci_bus 0001:00: root bus resource [mem 0x28000000-0x2fffffff]
[ 1.273026] pci_bus 0001:00: scanning bus
[ 1.278255] pci_bus 0001:00: fixups for bus
[ 1.282437] pci_bus 0001:00: bus scan returning with max=00
[ 1.288171] mtk_hsdma 1b007000.dma-controller: Using 3 as missing dma-requests property
[ 1.296360] mtk_hsdma 1b007000.dma-controller: MediaTek HSDMA driver registered
[ 1.859399] mt753x gsw@0: LAN/WAN VLAN setting=wllll
[ 1.864836] mt753x gsw@0: Switch is MediaTek MT7531BE rev 0
[ 6.511476] xhci-mtk 1a0c0000.usb: xHCI Host Controller
[ 6.516714] xhci-mtk 1a0c0000.usb: new USB bus registered, assigned bus number 1
[ 6.525762] xhci-mtk 1a0c0000.usb: hcc params 0x01403198 hci version 0x96 quirks 0x0000000000210010
[ 6.534833] xhci-mtk 1a0c0000.usb: irq 130, io mem 0x1a0c0000
[ 6.540976] hub 1-0:1.0: USB hub found
[ 6.544741] hub 1-0:1.0: 2 ports detected
[ 6.548978] xhci-mtk 1a0c0000.usb: xHCI Host Controller
[ 6.554208] xhci-mtk 1a0c0000.usb: new USB bus registered, assigned bus number 2
[ 6.561605] xhci-mtk 1a0c0000.usb: Host supports USB 3.0 SuperSpeed
[ 6.567899] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 6.576205] hub 2-0:1.0: USB hub found
[ 6.579966] hub 2-0:1.0: 1 port detected
[ 6.584219] rtc_mt7622 10212800.rtc: setting system clock to 2000-01-01T00:14:21 UTC (946685661)
[ 6.599325] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 6.607477] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 6.614473] Freeing unused kernel memory: 448K
[ 6.627389] Run /sbin/init as init process
[ 6.680739] init: Console is alive
[ 6.684242] init: - watchdog -
[ 6.726757] random: fast init done
[ 6.809320] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[ 6.823175] ehci-fsl: Freescale EHCI Host controller driver
[ 6.833232] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[ 6.841037] init: - preinit -
[ 6.922076] mtk_soc_eth 1b100000.ethernet: PPE started
[ 6.927266] mtk_soc_eth 1b100000.ethernet eth0: configuring for fixed/2500base-x link mode
[ 6.935611] mtk_soc_eth 1b100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
[ 10.969474] mount_root: mounting /dev/root
[ 10.975366] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 10.980936] mount_root: loading kmods from internal overlay
[ 10.994885] kmodloader: loading kernel modules from //etc/modules-boot.d/*
[ 11.002503] kmodloader: done loading kernel modules from //etc/modules-boot.d/*
[ 11.079661] urandom-seed: Seeding with /etc/urandom.seed
[ 11.093866] procd: - early -
[ 11.096801] procd: - watchdog -
[ 11.612900] procd: - watchdog -
[ 11.616159] procd: - ubus -
[ 11.623019] random: ubusd: uninitialized urandom read (4 bytes read)
[ 11.669206] random: ubusd: uninitialized urandom read (4 bytes read)
[ 11.675667] random: ubusd: uninitialized urandom read (4 bytes read)
[ 11.682285] procd: - init -
[ 11.769213] kmodloader: loading kernel modules from /etc/modules.d/*
[ 11.773068] urngd: v1.0.2 started.
[ 11.787062] tun: Universal TUN/TAP device driver, 1.6
[ 11.802151] random: crng init done
[ 11.805573] random: 7 urandom warning(s) missed due to ratelimiting
[ 11.807487] cryptodev: driver 1.10 loaded.
[ 11.818851] i2c /dev entries driver
[ 11.829040] hidraw: raw HID events driver (C) Jiri Kosina
[ 11.836503] Mirror/redirect action on
[ 11.843855] u32 classifier
[ 11.846558] input device check on
[ 11.850241] Actions configured
[ 11.870641] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 11.875990] Bluetooth: BNEP filters: protocol multicast
[ 11.881222] Bluetooth: BNEP socket layer initialized
[ 11.888063] usbcore: registered new interface driver btusb
[ 11.894526] usbcore: registered new interface driver cdc_wdm
[ 11.900862] Loading modules backported from Linux version v5.7-rc3-0-g6a8b55ed4056
[ 11.908442] Backport generated by backports.git v5.7-rc3-1-0-gc0c7d2bb
[ 11.916168] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 11.922122] Bluetooth: HIDP socket layer initialized
[ 11.937166] Bluetooth: RFCOMM TTY layer initialized
[ 11.942077] Bluetooth: RFCOMM socket layer initialized
[ 11.947231] Bluetooth: RFCOMM ver 1.11
[ 11.952953] usbcore: registered new interface driver ums-alauda
[ 11.959517] usbcore: registered new interface driver ums-cypress
[ 11.966085] usbcore: registered new interface driver ums-datafab
[ 11.972436] usbcore: registered new interface driver ums-freecom
[ 11.978912] usbcore: registered new interface driver ums-isd200
[ 11.985152] usbcore: registered new interface driver ums-jumpshot
[ 11.991573] usbcore: registered new interface driver ums-karma
[ 11.997785] usbcore: registered new interface driver ums-sddr09
[ 12.004032] usbcore: registered new interface driver ums-sddr55
[ 12.010291] usbcore: registered new interface driver ums-usbat
[ 12.020258] wireguard: WireGuard 1.0.20200520 loaded. See www.wireguard.com for information.
[ 12.028709] wireguard: Copyright (C) 2015-2019 Jason A. Donenfeld <[email protected]>. All Rights Reserved.
[ 12.048120] xt_time: kernel timezone is -0000
[ 12.053074] usbcore: registered new interface driver cdc_ether
[ 12.096966] mt7615e 0000:01:00.0: assign IRQ: got 139
[ 12.102078] pci 0000:00:00.0: enabling device (0000 -> 0002)
[ 12.107742] pci 0000:00:00.0: enabling bus mastering
[ 12.112717] mt7615e 0000:01:00.0: enabling device (0000 -> 0002)
[ 12.118798] mt7615e 0000:01:00.0: enabling bus mastering
[ 12.125907] mt7615e 0000:01:00.0: Invalid MAC address, using random address 3e:a3:f4:1d:c7:db
[ 12.135936] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[ 12.157301] mt7622-wmac 18000000.wmac: Invalid MAC address, using random address 6e:b2:d5:8b:f0:34
[ 12.167561] ieee80211 phy1: Selected rate control algorithm 'minstrel_ht'
[ 12.175450] mt7615e 0000:01:00.0: HW/SW Version: 0x8a108a10, Build Time: 20180518100604a
[ 12.175450]
[ 12.195206] PPP generic driver version 2.4.2
[ 12.201006] NET: Registered protocol family 24
[ 12.206635] usbcore: registered new interface driver qmi_wwan
[ 12.213157] mt7615e 0000:01:00.0: N9 Firmware Version: 2.0, Build Time: 20200131181812
[ 12.221756] mt7622-wmac 18000000.wmac: HW/SW Version: 0x8a108a10, Build Time: 20190801210006a
[ 12.221756]
[ 12.232303] kmodloader: done loading kernel modules from /etc/modules.d/*
[ 12.246908] mt7615e 0000:01:00.0: CR4 Firmware Version: _reserved_, Build Time: 20190121161307
[ 12.263510] mt7622-wmac 18000000.wmac: N9 Firmware Version: 2.0, Build Time: 20200131180931
[ 13.564852] mtk_soc_eth 1b100000.ethernet eth0: Link is Down
[ 13.573336] mtk_soc_eth 1b100000.ethernet: 0x100 = 0xffff9070, 0x10c = 0x100808ff
[ 13.580846] mtk_soc_eth 1b100000.ethernet: reset pse
[ 13.671845] mtk_soc_eth 1b100000.ethernet: PPE started
[ 13.677060] debugfs: Directory 'mtk_ppe' with parent '/' already present!
[ 13.683890] mtk_soc_eth 1b100000.ethernet eth0: configuring for fixed/2500base-x link mode
[ 13.692253] mtk_soc_eth 1b100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
[ 13.698920] br-lan: port 1(eth0) entered blocking state
[ 13.706190] br-lan: port 1(eth0) entered disabled state
[ 13.711646] device eth0 entered promiscuous mode
[ 13.717901] br-lan: port 1(eth0) entered blocking state
[ 13.723176] br-lan: port 1(eth0) entered forwarding state
[ 13.736030] mtk_soc_eth 1b100000.ethernet eth1: configuring for fixed/rgmii link mode
[ 13.744068] mtk_soc_eth 1b100000.ethernet eth1: Link is Up - 1Gbps/Full - flow control rx/tx
Now I have both WiFi cards operational.
phy#1
Interface wlan1
ifindex 5
wdev 0x100000001
addr 52:43:4e:e7:4d:c6
type managed
txpower 6.00 dBm
multicast TXQ:
0 0 0 0 0 0 0 0 0
phy#0
Interface wlan0
ifindex 7
wdev 0x2
addr aa:60:e3:c5:e6:f2
type managed
txpower 6.00 dBm
multicast TXQ:
0 0 0 0 0 0 0 0 0
Two things bother me though.
- For some reason OpenWRT generated config files in such a way that
radio0iswlan1and vice versa. - Txpower on both cards seems to be limited to 6 dBm. Is there a way to increase it?
Nice to see there is an official patch now…i got them here or by email and collected over time
I don’t know if openwrts build-system can handle mbox files…then you can click “series” button in the upper right corner if patchwork site to download a “git am” compatible file with all patches from the series
Maybe you can change that by modifying udev-files.
There is a discussion about the 6dbm issue,but afaik no working solution…here is a hint why this happens,but afair patch was bot accepted and maybe not compatible with mainline code
@svintuss As for 6dbm limit. Compile mt76 driver with eeprom.c from git on top of this thread. This is working for me on mt7622. I do not have 7615 so cannot check.
After replacing eeprom.c mt7615 is non-functional: It became a clone of mt7622 device (same MAC, system thinks it’s 2.4 GHz).
Compare this output to my previous post: ifindex, wdev and addr are different.
phy#1
Interface wlan1
ifindex 15
wdev 0x100000005
addr 00:0c:43:26:60:00
type AP
txpower 20.00 dBm
multicast TXQ:
0 0 0 0 0 0 0 0 0
phy#0
Interface wlan0
ifindex 16
wdev 0x7
type managed
txpower 20.00 dBm
multicast TXQ:
0 0 0 0 0 0 0 0 0
I’m sure this is because the fixed eeprom-data in mt76_get_of_eeprom called for every device handled by the driver
Do you see your mac-address?
This function should be called only for mt7622 wifi and not mt7615…
If i see this you see that with the eeprom-data all cards will be handled as 7622 because of first 2 bytes
You need something like this in mt76_get_eeprom function:
switch (mt76_chip(dev)) {
case 0x7622: /*here existing content*/ break;
case 0x7615: /*eeprom data for 7615*/ break;
But make sure function returns 1 else it will break mt76_eeprom_init…
Thank you, @frank-w. Do you have any ideas where can I get eeprom data for 7615?
@niebieski20 where did you get mt7622 eeprom?
You can skip the eeprom part for mt7615 in a first step (only write eeprom data for mt7622) but let function return always 1. I guess he used the eeprom-data normaly written to mtd partition in openwrt
have modified eeprom.c like i’ve mentioned…
eeprom.c (7,3 KB)
Thank you.
Am I getting this right?
static int
mt76_get_of_eeprom(struct mt76_dev *dev, int len)
case 0x7622:
static const u8 eeprom[] = {
0x22, 0x76, 0x05, 0x00, 0x00, 0x0C, 0x43, 0x26, 0x60, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x44, 0x00, 0x00, 0x20, 0x00, 0x00, 0x00, 0x00, 0x10, 0x00, 0x20, 0x00, 0x00, 0x00, 0x44, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x20, 0x00, 0x00, 0xB3, 0x40, 0xB6, 0xC3, 0xC3, 0x26, 0x00, 0x00, 0x00, 0x41, 0xC4, 0x26, 0x00, 0x00, 0x00, 0x41, 0xC4, 0x26, 0x00, 0x00, 0x00, 0xC0, 0xC5, 0x26, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xC6, 0xC6, 0xC3, 0xC3, 0xC2, 0xC1, 0x00, 0xC3, 0x00, 0xC3,
0x00, 0x81, 0x81, 0x81, 0x83, 0xC1, 0xC1, 0x82, 0x83, 0x83, 0x83, 0x82, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x84, 0x00, 0x2E, 0x00, 0x90, 0x00, 0x00, 0x87, 0x8A, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0B, 0x00, 0x00, 0x09, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x77, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
memcpy(dev->eeprom.data, eeprom, 0x400);
break;
break;
int ret;
ret = 1; // this part makes the function to always return 1, right?
return ret;
Can images from this post be of any help in extracting mt7615 eeprom? Full support for mt7615 WiFi is claimed.
lspci in this LEDE image looks like this.
root@LEDE:/# lspci
0000:00:00.0 Unclassified device [0002]: MEDIATEK Corp. Device 7622
0001:00:00.0 PCI bridge: MEDIATEK Corp. Device 5396
0001:01:00.0 Unclassified device [0002]: MEDIATEK Corp. Device 7615
basicly yes, but i have renamed the data-const and moved outside the switch for better readability. also the ret-lines can be merged to int ret=1; or easier “return 1;” as replacement for the 3 lines
i think you do not need any additional eeprom-data, because card should have it’s own burned onto it. i had also used mt7622 without any additional eeprom-data, but i have no mt7615 which may breaḱ and have not yet looked at the 6dbm-issue (i guess eeprom-data is fix for this)
