I’m constantly getting the same issue: a mt7615e 0000:01:00.0: Failed to get patch semaphore error. Here’s how boot log looks like.
reading bananapi/bpi-r64/linux/uImage
3265176 bytes read in 68 ms (45.8 MiB/s)
reading bananapi/bpi-r64/linux/dtb/image-mt7622-bananapi-bpi-r64.dtb
24877 bytes read in 7 ms (3.4 MiB/s)
bootm flag=0, states=70f
## Loading kernel from FIT Image at 44000000 ...
Using 'config@1' configuration
Trying 'kernel@1' kernel subimage
Description: ARM64 OpenWrt Linux-5.4.39
Type: Kernel Image
Compression: lzma compressed
Data Start: 0x440000e8
Data Size: 3238412 Bytes = 3.1 MiB
Architecture: AArch64
OS: Linux
Load Address: 0x41080000
Entry Point: 0x41080000
Hash algo: crc32
Hash value: b8baf594
Hash algo: sha1
Hash value: 01c05230b7ca622b4276fe320ca6d62ba0aba352
Verifying Hash Integrity ... crc32+ sha1+ OK
## Flattened Device Tree blob at 47000000
Booting using the fdt blob at 0x47000000
Uncompressing Kernel Image ... OK
Loading Device Tree to 6bff6000, end 6bfff12c ... OK
Starting kernel ...
[ATF][ 26.274057]save kernel info
[ATF][ 26.277258]Kernel_EL2
[ATF][ 26.280014]Kernel is 64Bit
[ATF][ 26.283202]pc=0x41080000, r0=0x6bff6000, r1=0x0
INFO: BL3-1: Preparing for EL3 exit to normal world, Kernel
INFO: BL3-1: Next image address = 0x41080000
INFO: BL3-1: Next image spsr = 0x3c9
[ATF][ 26.301468]el3_exit
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 5.4.39 ([email protected]) (gcc version 8.4.0 (OpenWrt GCC 8.4.0 r13203-02656caa7b)) #0 SMP Fri May 8 18:15:0
[ 0.000000] Machine model: Bananapi BPI-R64
[ 0.000000] On node 0 totalpages: 262096
[ 0.000000] DMA32 zone: 4096 pages used for memmap
[ 0.000000] DMA32 zone: 0 pages reserved
[ 0.000000] DMA32 zone: 262096 pages, LIFO batch:63
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv0.2 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] percpu: Embedded 20 pages/cpu s43608 r8192 d30120 u81920
[ 0.000000] pcpu-alloc: s43608 r8192 d30120 u81920 alloc=20*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: kernel page table isolation disabled by kernel configuration
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 258000
[ 0.000000] Kernel command line: board=bpi-r64 console=ttyS0,115200n1 earlyprintk root=/dev/mmcblk0p2 rootfstype=ext4 rootwait service=linu2
[ 0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 1018396K/1048384K available (6590K kernel code, 432K rwdata, 1896K rodata, 448K init, 285K bss, 29988K reserved, 0K cma)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: CONFIG_RCU_FANOUT set to non-default value of 32.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GIC: GICv2 detected, but range too small and irqchip.gicv2_force_probe not set
[ 0.000000] random: get_random_bytes called from start_kernel+0x2d4/0x42c with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 12.50MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049cda, max_idle_ns: 440795202628 ns
[ 0.000003] sched_clock: 56 bits at 12MHz, resolution 80ns, wraps every 4398046511080ns
[ 0.000166] Calibrating delay loop (skipped), value calculated using timer frequency.. 25.00 BogoMIPS (lpj=50000)
[ 0.000173] pid_max: default: 32768 minimum: 301
[ 0.000261] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
[ 0.000272] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
[ 0.001153] ASID allocator initialised with 65536 entries
[ 0.001202] rcu: Hierarchical SRCU implementation.
[ 0.001465] smp: Bringing up secondary CPUs ...
[ 0.001788] Detected VIPT I-cache on CPU1
[ 0.001824] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.001878] smp: Brought up 1 node, 2 CPUs
[ 0.001884] SMP: Total of 2 processors activated.
[ 0.001888] CPU features: detected: 32-bit EL0 Support
[ 0.001892] CPU features: detected: CRC32 instructions
[ 0.001994] CPU: All CPU(s) started at EL2
[ 0.002003] alternatives: patching kernel code
[ 0.005230] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.005243] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.005333] pinctrl core: initialized pinctrl subsystem
[ 0.005757] NET: Registered protocol family 16
[ 0.006042] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.017011] GPIO line 499 (asm_sel) hogged as output/high
[ 0.029557] SCSI subsystem initialized
[ 0.029683] libata version 3.00 loaded.
[ 0.029803] usbcore: registered new interface driver usbfs
[ 0.029828] usbcore: registered new interface driver hub
[ 0.029854] usbcore: registered new device driver usb
[ 0.030483] Bluetooth: Core ver 2.22
[ 0.030503] NET: Registered protocol family 31
[ 0.030506] Bluetooth: HCI device and connection manager initialized
[ 0.030513] Bluetooth: HCI socket layer initialized
[ 0.030518] Bluetooth: L2CAP socket layer initialized
[ 0.030528] Bluetooth: SCO socket layer initialized
[ 0.030779] clocksource: Switched to clocksource arch_sys_counter
[ 0.031244] thermal_sys: Registered thermal governor 'fair_share'
[ 0.031246] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.031250] thermal_sys: Registered thermal governor 'step_wise'
[ 0.031254] thermal_sys: Registered thermal governor 'user_space'
[ 0.031257] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.031519] NET: Registered protocol family 2
[ 0.031828] tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 8192 bytes, linear)
[ 0.031846] TCP established hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.031897] TCP bind hash table entries: 8192 (order: 5, 131072 bytes, linear)
[ 0.032017] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.032133] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.032154] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.032256] NET: Registered protocol family 1
[ 0.032277] PCI: CLS 0 bytes, default 64
[ 0.033379] workingset: timestamp_bits=46 max_order=18 bucket_order=0
[ 0.036447] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.036455] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.049368] mtk-tphy 1a0c4000.usb-phy: failed to get ref_clk(id-1)
[ 0.052445] mt-pmic-pwrap 10001000.pwrap: unexpected interrupt int=0x1
[ 0.066456] Serial: 8250/16550 driver, 3 ports, IRQ sharing disabled
[ 0.067127] printk: console [ttyS0] disabled
[ 0.087546] 11002000.serial: ttyS0 at MMIO 0x11002000 (irq = 118, base_baud = 1562500) is a ST16650V2
[ 0.628802] printk: console [ttyS0] enabled
[ 0.653636] 11004000.serial: ttyS1 at MMIO 0x11004000 (irq = 119, base_baud = 1562500) is a ST16650V2
[ 0.663319] 1100c000.serial: ttyS2 at MMIO 0x1100c000 (irq = 125, base_baud = 17499995) is a MediaTek BTIF
[ 0.673046] serial serial0: tty port ttyS2 registered
[ 0.678298] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 0.685864] libphy: Fixed MDIO Bus: probed
[ 0.713261] libphy: mdio: probed
[ 0.716527] mtk_soc_eth 1b100000.ethernet: generated random MAC address e6:92:e4:25:e8:06
[ 0.724971] mtk_soc_eth 1b100000.ethernet eth0: mediatek frame engine at 0xffffffc011600000, irq 134
[ 0.734123] mtk_soc_eth 1b100000.ethernet: generated random MAC address c6:8b:e7:c0:9f:93
[ 0.742493] mtk_soc_eth 1b100000.ethernet eth1: mediatek frame engine at 0xffffffc011600000, irq 134
[ 0.751704] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.758228] ehci-pci: EHCI PCI platform driver
[ 0.762702] ehci-platform: EHCI generic platform driver
[ 0.768033] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.774223] ohci-platform: OHCI generic platform driver
[ 0.779994] usbcore: registered new interface driver usb-storage
[ 0.786375] rtc_mt7622 10212800.rtc: registered as rtc0
[ 0.792252] Driver for 1-wire Dallas network protocol.
[ 0.797603] mtk-thermal 1100b000.thermal: Device not calibrated, using default calibration values
[ 0.806794] mtk-wdt 10212000.watchdog: Watchdog enabled (timeout=31 sec, nowayout=0)
[ 0.814628] Bluetooth: HCI UART driver ver 2.3
[ 0.819068] Bluetooth: HCI UART protocol H4 registered
[ 0.824200] Bluetooth: HCI UART protocol BCSP registered
[ 0.829560] Bluetooth: HCI UART protocol Broadcom registered
[ 0.835235] Bluetooth: HCI UART protocol QCA registered
[ 0.867137] mtk-msdc 11240000.mmc: Got CD GPIO
[ 0.897251] NET: Registered protocol family 10
[ 0.902301] Segment Routing with IPv6
[ 0.906011] NET: Registered protocol family 17
[ 0.910472] 8021q: 802.1Q VLAN Support v1.8
[ 0.925308] mtk-pcie 1a140000.pcie: host bridge /pcie@1a140000 ranges:
[ 0.931860] mtk-pcie 1a140000.pcie: Parsing ranges property...
[ 0.937694] mtk-pcie 1a140000.pcie: MEM 0x20000000..0x2fffffff -> 0x20000000
[ 0.987814] mtk-msdc 11230000.mmc: phase: [map:fffffff] [maxlen:28] [final:9]
[ 0.995724] mmc0: new HS200 MMC card at address 0001
[ 1.001820] mmcblk0: mmc0:0001 008G30 7.28 GiB
[ 1.007265] mmcblk0boot0: mmc0:0001 008G30 partition 1 4.00 MiB
[ 1.014073] mmcblk0boot1: mmc0:0001 008G30 partition 2 4.00 MiB
[ 1.020054] mmcblk0rpmb: mmc0:0001 008G30 partition 3 4.00 MiB, chardev (250:0)
[ 1.028576] mmcblk0: p1 p2
[ 1.068777] mtk-pcie 1a140000.pcie: Port1 link down
[ 1.073764] mtk-pcie 1a140000.pcie: PCI host bridge to bus 0000:00
[ 1.079947] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.085431] pci_bus 0000:00: root bus resource [mem 0x20000000-0x2fffffff]
[ 1.092304] pci_bus 0000:00: scanning bus
[ 1.096360] pci 0000:00:00.0: [14c3:3258] type 01 class 0x060400
[ 1.102477] pci 0000:00:00.0: reg 0x10: [mem 0x00000000-0x1ffffffff 64bit pref]
[ 1.111397] pci_bus 0000:00: fixups for bus
[ 1.115581] pci 0000:00:00.0: scanning [bus 00-00] behind bridge, pass 0
[ 1.122279] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 1.130309] pci 0000:00:00.0: scanning [bus 00-00] behind bridge, pass 1
[ 1.137162] pci_bus 0000:01: scanning bus
[ 1.141296] pci 0000:01:00.0: [14c3:7615] type 00 class 0x000280
[ 1.147531] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x000fffff 64bit]
[ 1.155272] pci 0000:01:00.0: 2.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s x1 link at 0000:00:00.0 (capable of 4.000 Gb/s with )
[ 1.170358] pci_bus 0000:01: fixups for bus
[ 1.174539] pci_bus 0000:01: bus scan returning with max=01
[ 1.180109] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 1.186723] pci_bus 0000:00: bus scan returning with max=01
[ 1.192306] pci 0000:00:00.0: BAR 0: no space for [mem size 0x200000000 64bit pref]
[ 1.199958] pci 0000:00:00.0: BAR 0: failed to assign [mem size 0x200000000 64bit pref]
[ 1.207958] pci 0000:00:00.0: BAR 8: assigned [mem 0x20000000-0x200fffff]
[ 1.214744] pci 0000:01:00.0: BAR 0: assigned [mem 0x20000000-0x200fffff 64bit]
[ 1.222133] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 1.227099] pci 0000:00:00.0: bridge window [mem 0x20000000-0x200fffff]
[ 1.234085] mtk_hsdma 1b007000.dma-controller: Using 3 as missing dma-requests property
[ 1.242274] mtk_hsdma 1b007000.dma-controller: MediaTek HSDMA driver registered
[ 1.794810] mt753x gsw@0: LAN/WAN VLAN setting=wllll
[ 1.800254] mt753x gsw@0: Switch is MediaTek MT7531BE rev 0
[ 6.455672] xhci-mtk 1a0c0000.usb: xHCI Host Controller
[ 6.460909] xhci-mtk 1a0c0000.usb: new USB bus registered, assigned bus number 1
[ 6.469954] xhci-mtk 1a0c0000.usb: hcc params 0x01403198 hci version 0x96 quirks 0x0000000000210010
[ 6.479025] xhci-mtk 1a0c0000.usb: irq 130, io mem 0x1a0c0000
[ 6.485154] hub 1-0:1.0: USB hub found
[ 6.488920] hub 1-0:1.0: 2 ports detected
[ 6.493140] xhci-mtk 1a0c0000.usb: xHCI Host Controller
[ 6.498370] xhci-mtk 1a0c0000.usb: new USB bus registered, assigned bus number 2
[ 6.505770] xhci-mtk 1a0c0000.usb: Host supports USB 3.0 SuperSpeed
[ 6.512063] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 6.520376] hub 2-0:1.0: USB hub found
[ 6.524138] hub 2-0:1.0: 1 port detected
[ 6.528401] rtc_mt7622 10212800.rtc: setting system clock to 2020-05-17T18:42:36 UTC (1589740956)
[ 6.543603] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 6.551755] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 6.558729] Freeing unused kernel memory: 448K
[ 6.578811] Run /sbin/init as init process
[ 6.628176] init: Console is alive
[ 6.631745] init: - watchdog -
[ 6.673791] random: fast init done
[ 6.769358] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[ 6.783368] ehci-fsl: Freescale EHCI Host controller driver
[ 6.793243] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[ 6.809234] init: - preinit -
[ 6.894413] mtk_soc_eth 1b100000.ethernet: PPE started
[ 6.899592] mtk_soc_eth 1b100000.ethernet eth0: configuring for fixed/2500base-x link mode
[ 6.907911] mtk_soc_eth 1b100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
[ 6.918897] usb 1-2: new high-speed USB device number 2 using xhci-mtk
Press the [1], [2], [3] or [4] key and hit [enter] to select the debug level
[ 7.146538] usb-storage 1-2:1.0: USB Mass Storage device detected
[ 7.152805] random: procd: uninitialized urandom read (4 bytes read)
[ 7.152854] scsi host0: usb-storage 1-2:1.0
[ 8.196488] scsi 0:0:0:0: Direct-Access JetFlash Transcend 4GB 8.07 PQ: 0 ANSI: 2
[ 8.205669] sd 0:0:0:0: [sda] 7847936 512-byte logical blocks: (4.02 GB/3.74 GiB)
[ 8.213314] sd 0:0:0:0: [sda] Write Protect is off
[ 8.218106] sd 0:0:0:0: [sda] Mode Sense: 03 00 00 00
[ 8.223295] sd 0:0:0:0: [sda] No Caching mode page found
[ 8.228609] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 8.422794] sda: sda1
[ 8.426073] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 10.948245] mount_root: mounting /dev/root
[ 10.954012] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 10.959568] mount_root: loading kmods from internal overlay
[ 10.973450] kmodloader: loading kernel modules from //etc/modules-boot.d/*
[ 10.981062] kmodloader: done loading kernel modules from //etc/modules-boot.d/*
[ 11.109496] urandom-seed: Seeding with /etc/urandom.seed
[ 11.127439] procd: - early -
[ 11.130347] procd: - watchdog -
[ 11.645926] procd: - watchdog -
[ 11.649233] procd: - ubus -
[ 11.656335] random: ubusd: uninitialized urandom read (4 bytes read)
[ 11.702314] random: ubusd: uninitialized urandom read (4 bytes read)
[ 11.708824] random: ubusd: uninitialized urandom read (4 bytes read)
[ 11.715494] procd: - init -
Please press Enter to activate this console.
[ 11.819810] urngd: v1.0.2 started.
[ 11.848392] random: crng init done
[ 11.851859] random: 6 urandom warning(s) missed due to ratelimiting
[ 11.853249] kmodloader: loading kernel modules from /etc/modules.d/*
[ 11.876059] tun: Universal TUN/TAP device driver, 1.6
[ 11.891253] cryptodev: driver 1.10 loaded.
[ 11.898077] i2c /dev entries driver
[ 11.908146] hidraw: raw HID events driver (C) Jiri Kosina
[ 11.915490] Mirror/redirect action on
[ 11.922348] u32 classifier
[ 11.925078] input device check on
[ 11.928735] Actions configured
[ 11.948778] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 11.954116] Bluetooth: BNEP filters: protocol multicast
[ 11.959346] Bluetooth: BNEP socket layer initialized
[ 11.966091] usbcore: registered new interface driver btusb
[ 11.972407] usbcore: registered new interface driver cdc_wdm
[ 11.978561] Loading modules backported from Linux version v5.4.27-0-g585e0cc08069
[ 11.986045] Backport generated by backports.git v5.4.27-1-0-gf6e8852f
[ 11.993584] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 11.999541] Bluetooth: HIDP socket layer initialized
[ 12.018818] Bluetooth: RFCOMM TTY layer initialized
[ 12.023726] Bluetooth: RFCOMM socket layer initialized
[ 12.028876] Bluetooth: RFCOMM ver 1.11
[ 12.034302] usbcore: registered new interface driver ums-alauda
[ 12.040639] usbcore: registered new interface driver ums-cypress
[ 12.047027] usbcore: registered new interface driver ums-datafab
[ 12.053350] usbcore: registered new interface driver ums-freecom
[ 12.059663] usbcore: registered new interface driver ums-isd200
[ 12.065895] usbcore: registered new interface driver ums-jumpshot
[ 12.072271] usbcore: registered new interface driver ums-karma
[ 12.078501] usbcore: registered new interface driver ums-sddr09
[ 12.084744] usbcore: registered new interface driver ums-sddr55
[ 12.091013] usbcore: registered new interface driver ums-usbat
[ 12.100993] wireguard: WireGuard 1.0.20200506 loaded. See www.wireguard.com for information.
[ 12.109450] wireguard: Copyright (C) 2015-2019 Jason A. Donenfeld <[email protected]>. All Rights Reserved.
[ 12.128998] xt_time: kernel timezone is -0000
[ 12.133986] usbcore: registered new interface driver cdc_ether
[ 12.231145] mt7615e 0000:01:00.0: assign IRQ: got 139
[ 12.236249] pci 0000:00:00.0: enabling device (0000 -> 0002)
[ 12.241913] pci 0000:00:00.0: enabling bus mastering
[ 12.246887] mt7615e 0000:01:00.0: enabling device (0000 -> 0002)
[ 12.252970] mt7615e 0000:01:00.0: enabling bus mastering
[ 12.261767] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[ 12.284318] ieee80211 phy1: Selected rate control algorithm 'minstrel_ht'
[ 12.306602] PPP generic driver version 2.4.2
[ 12.312430] NET: Registered protocol family 24
[ 12.318433] usbcore: registered new interface driver qmi_wwan
[ 12.324463] mt7622-wmac 18000000.wmac: HW/SW Version: 0x8a108a10, Build Time: 20190801210006a
[ 12.324463]
[ 12.336368] kmodloader: done loading kernel modules from /etc/modules.d/*
[ 12.354691] mt7622-wmac 18000000.wmac: N9 Firmware Version: 2.0, Build Time: 20200131180931
[ 13.702412] mtk_soc_eth 1b100000.ethernet eth0: Link is Down
[ 13.710927] mtk_soc_eth 1b100000.ethernet: 0x100 = 0xffff9070, 0x10c = 0x100808ff
[ 13.718436] mtk_soc_eth 1b100000.ethernet: reset pse
[ 13.810699] mtk_soc_eth 1b100000.ethernet: PPE started
[ 13.815903] debugfs: Directory 'mtk_ppe' with parent '/' already present!
[ 13.822736] mtk_soc_eth 1b100000.ethernet eth0: configuring for fixed/2500base-x link mode
[ 13.831084] mtk_soc_eth 1b100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
[ 13.833137] br-lan: port 1(eth0) entered blocking state
[ 13.845016] br-lan: port 1(eth0) entered disabled state
[ 13.850464] device eth0 entered promiscuous mode
[ 13.859647] br-lan: port 1(eth0) entered blocking state
[ 13.864905] br-lan: port 1(eth0) entered forwarding state
[ 13.877653] mtk_soc_eth 1b100000.ethernet eth1: configuring for fixed/rgmii link mode
[ 13.887134] mtk_soc_eth 1b100000.ethernet eth1: Link is Up - 1Gbps/Full - flow control rx/tx
[ 13.895841] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
[ 15.922328] br-lan: port 2(wlan1) entered blocking state
[ 15.927660] br-lan: port 2(wlan1) entered disabled state
[ 15.933126] device wlan1 entered promiscuous mode
[ 15.937893] br-lan: port 2(wlan1) entered blocking state
[ 15.943206] br-lan: port 2(wlan1) entered forwarding state
[ 15.948971] br-lan: port 2(wlan1) entered disabled state
[ 15.968334] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
[ 15.974894] br-lan: port 2(wlan1) entered blocking state
[ 15.980233] br-lan: port 2(wlan1) entered forwarding state
[ 33.762788] mt7615e 0000:01:00.0: Message -4294967280 (seq 1) timeout
[ 33.769238] mt7615e 0000:01:00.0: Failed to get patch semaphore
