Krantic
February 16, 2024, 4:03pm
42
Hi guys
can you tell me why i have not file /sys/class/thermal/thermal_zone0/temp
root@bpi-r64:/# cat /sys/class/thermal/thermal_zone0/temp
cat: /sys/class/thermal/thermal_zone0/temp: No such file or directory
maybe some kind of kernel module is needed ?
frank-w
(Frank W.)
February 16, 2024, 4:11pm
43
Imho r64 uses
CONFIG_MEDIATEK_MT6577_AUXADC
Which is set in my defconfig in branch 6.6-main
And these common options are needed:
CONFIG_HWMON=y
CONFIG_THERMAL_HWMON=y
Could you check if all 3 are selected in your kernel? tried importing defconfig and all are set…maybe anything in bootlog (dmesg)?
maybe MTK_SOC_THERMAL and/or MTK_THERMAL are needed…
first was introduced in 6.3, so if 6.1 was working and 6.6 not this may because of this
https://cateee.net/lkddb/web-lkddb/MTK_SOC_THERMAL.html
seems i found cause…
fad399ebdd67 thermal/drivers/mediatek: Relocate driver to mediatek folder
moves MTK_THERMAL into the new directory/Kconfig and drops the “default y”
so please try to enable both options above
CONFIG_MTK_THERMAL=y
CONFIG_MTK_SOC_THERMAL=y
and then build/try again
ericwoud
(Eric W.)
February 16, 2024, 7:26pm
45
Thanks, I also needed to add this again…
Krantic
February 17, 2024, 8:46am
46
frank-w:
THERMAL
i have done as you advised, and driver not loaded. There is no thermal_zone0
root@bpi-r64:/# dmesg | grep -i thermal
[ 0.014084] thermal_sys: Registered thermal governor 'fair_share'
[ 0.014088] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.014092] thermal_sys: Registered thermal governor 'step_wise'
[ 0.014096] thermal_sys: Registered thermal governor 'user_space'
[ 23.779316] platform 1100b000.thermal: deferred probe pending
root@bpi-r64:/#
root@bpi-r64:/# lsmod | grep -e 'thermal\|aux'
root@bpi-r64:/#
root@bpi-r64:/# ls /sys/class/thermal/
cooling_device0
root@bpi-r64:/#
frank-w
(Frank W.)
February 17, 2024, 8:49am
47
NVMEM_MTK_EFUSE seems to be missing too…looks like it is renamed
CONFIG_MTK_EFUSE=y
to
CONFIG_NVMEM_MTK_EFUSE=y
since 6.1 Linux Kernel Driver DataBase: CONFIG_NVMEM_MTK_EFUSE: Mediatek SoCs EFUSE support
by commit
28fc7c986f01 2022-09-16 nvmem: prefix all symbols with NVMEM_
Krantic
February 17, 2024, 8:53am
48
frank-w:
CONFIG_MTK_EFUSE
there is no the config line, at all
# CONFIG_NVMEM_MTK_EFUSE is not set
does this need to be enabled?
frank-w
(Frank W.)
February 17, 2024, 9:03am
49
yes, this also needs to be added / replacing the old option as i’ve wrote above
root@bpi-r64:~# cat /sys/class/thermal/thermal_zone0/temp
41800
upload fixes to 6.6-main branch and updated 6.1-6.8
@dangowrt do you need this fix too (CONFIG_NVMEM_MTK_EFUSE) for r64/mt7622 and r2/mt7623 after switching to 6.1? the other was 6.3+ so it should not affect opwnwrt
@Krantic a bit more information how i found this out:
you’ve shown this error: platform 1100b000.thermal: deferred probe pending, that means that a depency is not filled…
looking in dts https://github.com/frank-w/BPI-Router-Linux/blob/6.6-main/arch/arm64/boot/dts/mediatek/mt7622.dtsi#L509 you see depency on pericfg, apmixedsys and thermal_calibration
as pericfg does manage all peripheral clocks and other systems work, it should be ok
thermal_calibration is subnode of the efuse which was likely the first thing i look
have not looked on apmixedsys, but this would be next part if it was not fixed (searching compatible e.g. with grep -Rni 'compatible' drivers, then makefile in same folder of driver-file to get the corresponding CONFIG option)
Krantic
February 19, 2024, 7:10am
50
Hi guys
it all worked
but now i have another problem
works very slowly
root@bpi-r64:/shara/R64# ./loopt.sh
TEMP: 59900 FREQ: 119999
TEMP: 60300 FREQ: 119999
TEMP: 60200 FREQ: 119999
TEMP: 60000 FREQ: 119999
how to increase the processor frequency and keep it around 1,000,000 ?
frank-w
(Frank W.)
February 19, 2024, 7:18am
51
Raise temp lower thermalzone in dts. When this temp is arrived cpu will be trottled.
Had done this way in 6.1-main: arm64: dts: mediatek: update thermal trips · frank-w/BPI-Router-Linux@674a164 · GitHub
Krantic
February 19, 2024, 7:31am
52
it needs recompile kernel ?
frank-w
(Frank W.)
February 19, 2024, 7:35am
53
Yes,maybe you can test it before by setting temp via sysfs,seen this here somewhere,but have not tested
ericwoud
(Eric W.)
February 19, 2024, 11:08am
54
You could use a devicetree overlay for it.
frank-w
(Frank W.)
February 19, 2024, 11:48am
55
Kernel recompile is imho easier for him my current contruct uses fit with builtin overlays,not sure if it is possible to add an external overlay to it
Krantic
February 19, 2024, 12:23pm
56
thank you gentlemen
i have recompile and this worked
cpu_passive: cpu-passive {
/* temperature = <47000>; */
temperature = <77000>;
hysteresis = <2000>;
type = "passive";
it seems(imho) this variable should be placed in uEnv.txt
frank-w
(Frank W.)
February 19, 2024, 2:36pm
57
I cannot place dts parts in uEnv.txt
Krantic
February 23, 2024, 3:24pm
58
Hello guys
# cat /proc/sys/kernel/printk
# 10 7 1 15
i can reassign it by sysctl.conf, but is this ok?
