[BPI-R64] mt7622 mac80211 WiFi driver
Thank you very much!
I make some tests if i found some time. How to load mt7615 eeprom (it is not set in dts so we need a default filename based on chip-name)
which eeprom-file have you used? is device initialized if file does not exist (with internal eeprom)?
I only added a function, this function loads the configuration file from the file system.
mt7615, and I test it. The code should be compatible original program.Should not load successfully?
root@MT7622:~# dmesg | grep mt7615e
[  107.700196] mt7615e 0000:01:00.0: assign IRQ: got 140
[  107.842935] mt7615e 0000:01:00.0: enabling device (0000 -> 0002)
[  107.883193] mt7615e 0000:01:00.0: enabling bus mastering
[  109.119164] mt7615e 0000:01:00.0: HW/SW Version: 0x8a108a10, Build Time: 20180518100604a
[  109.194028] mt7615e 0000:01:00.0: N9 Firmware Version: _reserved_, Build Time: 20190103180756
[  109.313564] mt7615e 0000:01:00.0: CR4 Firmware Version: _reserved_, Build Time: 20181207140436
[  117.236814] mt7615e 0000:01:00.0 wlp1s0: renamed from wlan1
root@MT7622:~#
If the configuration file does not exist, it will run the same as the original program. If the device tree exists, load /lib/firmware/xxx [xxx: eeprom device tree configuration file name]. If the eeprom configuration file is saved in mtd, the mtd configuration file is preferred.
Mt7615 have still only own eeprom as it has no reference in dts…here (and for other mt76 like mt7612) can be a default filename like mt76xx_eeprom.bin (you have mt76_dev…maybe there is the chipid somewhere). the eeprom (for mt7615) is needed for tx issue.
Where did i find your eeprom-files for both devices (mt7622+mt7615)?
for chip-id maybe ā€œmt76_chip(struct mt76_dev *dev)ā€ from mt76.h is useful :wink:
I don’t have a special eeprom. I use the eeprom mentioned in this post, save it directly in bin format, and then save all the firmware in github to /lib/firmware/mediatek/.
node run:
var data=[
  0x22, 0x76, 0x05, 0x00, 0x00, 0x0C, 0x43, 0x26, 0x60, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x44, 0x00, 0x00, 0x20, 0x00, 0x00, 0x00, 0x00, 0x10, 0x00, 0x20, 0x00, 0x00, 0x00, 0x44, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x20, 0x00, 0x00, 0xB3, 0x40, 0xB6, 0xC3, 0xC3, 0x26, 0x00, 0x00, 0x00, 0x41, 0xC4, 0x26, 0x00, 0x00, 0x00, 0x41, 0xC4, 0x26, 0x00, 0x00, 0x00, 0xC0, 0xC5, 0x26, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xC6, 0xC6, 0xC3, 0xC3, 0xC2, 0xC1, 0x00, 0xC3, 0x00, 0xC3,
  0x00, 0x81, 0x81, 0x81, 0x83, 0xC1, 0xC1, 0x82, 0x83, 0x83, 0x83, 0x82, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x84, 0x00, 0x2E, 0x00, 0x90, 0x00, 0x00, 0x87, 0x8A, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0B, 0x00, 0x00, 0x09, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x77, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
var fs = require('fs');
fs.writeFile("mt7622_rf_conf.bin", Buffer.from(data),"binary",function(err) {
    if(err) {
        console.log(err);
    } else {
        console.log("The file was saved!");
Thanks…any idea about mt7615?
Maybe something like this
char filename[18];
sprintf(filename, "mt%d_eeprom.bin", mt76xx_chip(dev)); //mt76_chip is static and i do not know if it is available in eeprom.c
tried to set a default filename, but get this:
mt30242_eeprom.bin
ah i see the chip-id needs to be interpreted as hex :slight_smile:
Btw.
drivers/net/wireless/mediatek/mt76/eeprom.c:47:20: warning: format '%ld' expects argument of type 'long int', but argument 3 has type 'ssize_t' {aka 'int'} [-Wformat=]
      47 |  dev_info(dev->dev,"Read File OK, count %ld\n",ret);
So it should be %d instead of %ld…mhm, my compiler needs %ld too…got the error from kernel-ci-bot which uses ā€œCOMPILER=gcc-9.3.0 make.cross ARCH=mipsā€
So you use basicly the same file as in first post (which is already a bin-file)
fp = filp_open(path, O_RDWR, 0); //shouldn't this O_RDONLY, as we don't want to write to the eeprom-file?
and i got a Pagefault with my modifications :wink: i got the pagefault at the strcat…don’t know why…in my current way, i copy fname to filename and then append filename to path
 15     char filename[18];
 28     sprintf(filename, "mt%x_eeprom.bin", mt76_chip(dev));
 29     dev_info(dev->dev,"default filename: '%s'\n",filename);
 30     ret = of_property_read_string(np, "mediatek,rf-conf", &fname);
 31     if (!ret)
 32         strcpy(filename, fname);
 39     strcat(path,filename);
in your code you check again for np and return if it is not set, but np should not be modified by of_property_read_string…only the out-string if return-value is 0. your code works till this point, but not completely, but i don’t know why mine gets pagefault at strcat
root@bpi-r64:~# modprobe mt7615e
[   26.208449] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   26.360043] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   26.367636] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[   26.392478] cfg80211: failed to load regulatory.db
[   26.540283] mt7622-wmac 18000000.wmac: Find 'mediatek,rf-conf' : /lib/firmware/mt7622_rf_conf.bin
[   26.550399] mt7622-wmac 18000000.wmac: Open File Faile : /lib/firmware/mt7622_rf_conf.bin
[   26.569763] mt7622-wmac 18000000.wmac: Invalid MAC address, using random address 0e:5a:a7:5b:07:36
[   26.590779] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
root@bpi-r64:~# [   27.825605] mt7622-wmac 18000000.wmac: driver own failed
i think it should be simple. no need to use the device tree. otherwise, a 7615e node is needed.
load two drivers without device tree.
eeprim.c:
// SPDX-License-Identifier: ISC
 * Copyright (C) 2016 Felix Fietkau <[email protected]>
#include <linux/of.h>
#include <linux/of_net.h>
#include <linux/mtd/mtd.h>
#include <linux/mtd/partitions.h>
#include <linux/etherdevice.h>
#include "mt76.h"
static int
mt76_get_of_file(struct mt76_dev *dev, int len)
char path[64]="";
struct file *fp;
loff_t pos=0;
int ret;
ret = snprintf(path,sizeof(path),"/lib/firmware/mediatek/%s_rf.bin",dev->dev->driver->name);
if(ret < 0)
	return -EINVAL;
dev_info(dev->dev,"Load firmware : %s\n",path);
fp = filp_open(path, O_RDONLY, 0);
if (IS_ERR(fp)) {
	dev_info(dev->dev,"Load firmware Faile : %s\n",path);
	return -ENOENT;
ret = kernel_read(fp, dev->eeprom.data, len, &pos);
if(ret < len){
	dev_info(dev->dev,"Load firmware ERR, count %dbyte\n",ret);
	ret = -ENOENT;
}else{
	dev_info(dev->dev,"Load firmware OK, count %dbyte\n",ret);
	ret = 0;
filp_close(fp, 0);
return ret;
static int
mt76_get_of_eeprom(struct mt76_dev *dev, int len)
#if defined(CONFIG_OF) && defined(CONFIG_MTD)
	struct device_node *np = dev->dev->of_node;
	struct mtd_info *mtd;
	const __be32 *list;
	const char *part;
	phandle phandle;
	int offset = 0;
	int size;
	size_t retlen;
	int ret;
	if (!np)
		return -ENOENT;
	list = of_get_property(np, "mediatek,mtd-eeprom", &size);
	if (!list)
		return -ENOENT;
	phandle = be32_to_cpup(list++);
	if (!phandle)
		return -ENOENT;
	np = of_find_node_by_phandle(phandle);
	if (!np)
		return -EINVAL;
	part = of_get_property(np, "label", NULL);
	if (!part)
		part = np->name;
	mtd = get_mtd_device_nm(part);
	if (IS_ERR(mtd)) {
		ret =  PTR_ERR(mtd);
		goto out_put_node;
	if (size <= sizeof(*list)) {
		ret = -EINVAL;
		goto out_put_node;
	offset = be32_to_cpup(list);
	ret = mtd_read(mtd, offset, len, &retlen, dev->eeprom.data);
	put_mtd_device(mtd);
	if (ret)
		goto out_put_node;
	if (retlen < len) {
		ret = -EINVAL;
		goto out_put_node;
out_put_node:
	of_node_put(np);
	return ret;
#else
	return -ENOENT;
#endif
void
mt76_eeprom_override(struct mt76_dev *dev)
#ifdef CONFIG_OF
	const u8 *mac;
	if (!np)
		return;
	mac = of_get_mac_address(np);
	if (!IS_ERR_OR_NULL(mac))
		memcpy(dev->macaddr, mac, ETH_ALEN);
#endif
	if (!is_valid_ether_addr(dev->macaddr)) {
		eth_random_addr(dev->macaddr);
		dev_info(dev->dev,
			 "Invalid MAC address, using random address %pM\n",
			 dev->macaddr);
EXPORT_SYMBOL_GPL(mt76_eeprom_override);
int
mt76_eeprom_init(struct mt76_dev *dev, int len)
	dev->eeprom.size = len;
	dev->eeprom.data = devm_kzalloc(dev->dev, len, GFP_KERNEL);
	if (!dev->eeprom.data)
		return -ENOMEM;
	return (!mt76_get_of_file(dev, len)) || (!mt76_get_of_eeprom(dev, len));//mtd priority mt76
EXPORT_SYMBOL_GPL(mt76_eeprom_init);
Make sure that the folder contains the following two files:
/lib/firmware/mediatek/mt7615e_rf.bin
/lib/firmware/mediatek/mt7622_wmac_rf.bin
[    5.520634] mt7615e 0000:01:00.0: assign IRQ: got 140
[    5.627256] mt7615e 0000:01:00.0: enabling device (0000 -> 0002)
[    5.665298] mt7615e 0000:01:00.0: enabling bus mastering
[    5.709000] mt7615e 0000:01:00.0: Load firmware : /lib/firmware/mediatek/mt7615e_rf.bin
[    5.767877] mt7615e 0000:01:00.0: Load firmware OK, count 1024byte
[    5.810291] mt7615e 0000:01:00.0: HW/SW Version: 0x8a108a10, Build Time: 20180518100604a
[    5.865967] mt7615e 0000:01:00.0: N9 Firmware Version: _reserved_, Build Time: 20190103180756
[    5.919523] mt7615e 0000:01:00.0: CR4 Firmware Version: _reserved_, Build Time: 20181207140436
[   13.659189] mt7615e 0000:01:00.0 wlp1s0: renamed from wlan1
root@MT7622:~# dmesg | grep mt7622
[    1.237992] rtc_mt7622 10212800.rtc: registered as rtc0
[    2.173705] rtc_mt7622 10212800.rtc: setting system clock to 2000-01-01T03:24:56 UTC (946697096)
[    5.503534] mt7622_wmac 18000000.wmac: ASIC revision: 76220010
[    5.539692] mt7622_wmac 18000000.wmac: Load firmware : /lib/firmware/mediatek/mt7622_wmac_rf.bin
[    5.606086] mt7622_wmac 18000000.wmac: Load firmware OK, count 1024byte
[    5.650923] mt7622_wmac 18000000.wmac: MAC addr = 00:0c:43:26:60:00
[    5.722530] mt7622_wmac 18000000.wmac: N9 Firmware Version: _reserved_, Build Time: 20190801210351
[    5.858934] mt7622_wmac 18000000.wmac: Firmware init done
[    5.902642] mt7622_wmac 18000000.wmac: Driver own success
root@MT7622:~#
additionally where is the write function? i can also write 1024byte directly to the file, and I can help implement it if necessary.
I think this is a better version without devicetree. Thank you very much. Can you send me your name+email so that i can set author in my repo?
Do you mean my comment about O_RDWR (imho this should be O_RDONLY Or do you mean writing eeprom on card with data from file?
Do you know which byte needs to be modified for tx power (21db+)?
Maybe it is possible to read old mac out before overwriting eeprom in memory.
you are right, although the code O_RDWR does not affect, but O_RDONLY is more rigorous. (I have modified the code on the page just now).
email:[email protected]
my english is not very good, and sometimes I misunderstand.
tx0 is 0x58
tx1 is 0x5e
tx2 is 0x64
tx3 is 0x6a
this is the information I can get:
thanks, these offsets are not in your table…and it looks like we need to set the tx power for each mode ([V]HTxx/MCSx) separately…and 5Ghz is missing
there are two tables above, tx0-4 is in the first picture.
It is true that other people gave me incomplete information, and there is no 5G configuration. I don’t know where the four antennas are.
aahh.image is stripped off (goes till 0x1e)…i have to click on it to see all.
this is the information I obtained in the discussion group. I will ask if there is any other information to provide to you. In addition, do you have debian wlan0 test code? AP and client. I use hostapd -B /etc/hostapd/hostapd.conf to report errors. I don’t have these configurations yet.
interface=wlan0
driver=nl80211
ssid=mt7622
root@MT7622:~# hostapd -B /etc/hostapd/hostapd.conf
Configuration file: /etc/hostapd/hostapd.conf
nl80211: Could not configure driver mode
nl80211: deinit ifname=wlan0 disabled_11b_rates=0
nl80211 driver initialization failed.
wlan0: interface state UNINITIALIZED->DISABLED
wlan0: AP-DISABLED
wlan0: CTRL-EVENT-TERMINATING
hostapd_free_hapd_data: Interface wlan0 wasn't started
I have only ap-code ready (2g4 and 5g,for r2,but you only need to replace iface names)
https://www.fw-web.de/dokuwiki/doku.php?id=en:bpi-r2:wlan#hostapd
Have not tried yet with mt7615/mt7622. Mt7615 is currently in my r2 (added antenna on wf3 today so i can test 2g4 and 5g). with and without the firmware-file i got a driver own failed…
without i see this:
[   49.882535] mt7622-wmac 18000000.wmac: Load firmware : /lib/firmware/mediatek/mt7622-wmac_rf.bin
[   49.891445] mt7622-wmac 18000000.wmac: Open file failed : /lib/firmware/mediatek/mt7622-wmac_rf.bin
[   49.901529] mt7622-wmac 18000000.wmac: Invalid MAC address, using random address 02:9d:39:63:ac:55
[   51.114069] mt7622-wmac 18000000.wmac: driver own failed
with the file i see this:
[   31.582413] mt7622-wmac 18000000.wmac: Load firmware : /lib/firmware/mediatek/mt7622-wmac_rf.bin
[   31.594925] mt7622-wmac 18000000.wmac: Load firmware ERR, count 1024byte
[   31.601739] mt7622-wmac 18000000.wmac: Load firmware OK, count -2byte
[   31.610768] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
root@bpi-r64:~# [   32.826357] mt7622-wmac 18000000.wmac: driver own failed
looks like the error message is added by this patchset: https://www.spinics.net/lists/linux-wireless/msg200710.html
i cannot start AP on wlan0
Could not set interface wlan0 flags (UP): Input/output error
nl80211: Could not set interface 'wlan0' UP
i still have the rfkill-option active (softdep rfkill pre: mt7622)
tried 5.9-main (without the eeprom-patch), same result
seems like it is the rfkill-issue again… i loaded rfkill-module before mt7615e and then i got the firmware-load and can start hostapd
i tried to change the rule because driver-module is named mt7615e instead of mt7622m same result (after reboot). directly after boot i get the driver own failure, if i unload the module and load again, i get the firmware-info…maybe mt7622 is blocked some time
mt7622-wmac 18000000.wmac: N9 Firmware Version: _reserved_, Build Time: 20190801210351
rfkill is loaded on boot, maybe the wlan0-interface in /etc/network/interfaces blocks…removed it so network is started completely, but same
root@bpi-r64:~# service networking status
ļæ½ā— networking.service - Raise network interfaces
   Loaded: loaded (/lib/systemd/system/networking.service; enabled; vendor prese
   Active: active (exited) since Thu 2019-02-14 10:12:03 UTC; 1 years 7 months a
     Docs: man:interfaces(5)
  Process: 164 ExecStart=/sbin/ifup -a --read-environment (code=exited, status=0
 Main PID: 164 (code=exited, status=0/SUCCESS)
Feb 14 10:12:02 bpi-r64 systemd[1]: Starting Raise network interfaces...
Feb 14 10:12:03 bpi-r64 systemd[1]: Started Raise network interfaces.
root@bpi-r64:~# lsmod
aes_generic            36864  1
cmac                   16384  1
btmtkuart              24576  0
bluetooth             512000  20 btmtkuart
ecdh_generic           16384  2 bluetooth
ecc                    24576  1 ecdh_generic
rfkill                 32768  3 bluetooth
libaes                 16384  2 bluetooth,aes_generic
ip_tables              28672  0
x_tables               36864  1 ip_tables
[   52.224481] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   52.380732] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   52.388300] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[   52.399402] cfg80211: failed to load regulatory.db
[   52.564273] mt7622-wmac 18000000.wmac: Load firmware : /lib/firmware/mediatek/mt7622-wmac_rf.bin
[   52.584584] mt7622-wmac 18000000.wmac: Load firmware ERR, count 1024byte
[   52.592669] mt7622-wmac 18000000.wmac: Load firmware OK, count -2byte
[   52.615394] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
root@bpi-r64:~# [   53.823422] mt7622-wmac 18000000.wmac: driver own failed
root@bpi-r64:~# modprobe -r mt7615e
[   83.800559] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   83.820595] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   83.827979] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[   83.850229] cfg80211: failed to load regulatory.db
[   83.948589] mt7622-wmac 18000000.wmac: Load firmware : /lib/firmware/mediatek/mt7622-wmac_rf.bin
[   83.958684] mt7622-wmac 18000000.wmac: Load firmware ERR, count 1024byte
[   83.974036] mt7622-wmac 18000000.wmac: Load firmware OK, count -2byte
[   84.001470] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[   84.054993] mt7622-wmac 18000000.wmac: N9 Firmware Version: _reserved_, Build Time: 20190801210351
root@bpi-r64:~#
btw. it looks like the eeprom does not get loaded…(ok-message is wrong because on err there is only ret-var set, but not returned). i added the len in brackets to see difference
[  157.004155] mt7622-wmac 18000000.wmac: Load firmware : /lib/firmware/mediatek/mt7622-wmac_rf.bin
[  157.019551] mt7622-wmac 18000000.wmac: Load firmware ERR, count 1024 byte (19880)
imho the len is wrong, it is passed to function so i guess it’s the size of full eeprom and sobuffer needs to initialized with zeros till len and then overridden with file-data (or filled after last file-byte)
root@bpi-r64:~# ls -lh /lib/firmware/mediatek/mt7622-wmac_rf.bin
-rw-r--r-- 1 root root 1.0K Sep 16 12:23 /lib/firmware/mediatek/mt7622-wmac_rf.bin
root@bpi-r64:~# ls -l /lib/firmware/mediatek/mt7622-wmac_rf.bin
-rw-r--r-- 1 root root 1024 Sep 16 12:23 /lib/firmware/mediatek/mt7622-wmac_rf.bin
but i get the same values second time i insert the module…but then initialization succeeds
@nagi have you an idea why driver own failes the first time (also without eeprom-patch - 5.9-main)? without the patch (revert 894b7767ec2fc21574775c354ab5350e51c2171c) i get this:
 mt7622-wmac 18000000.wmac: Timeout for driver own
Could you try to uncheck ā€œBluetooth subsystem supportā€ in make kernel_menuconfig?
Networking support --> < > Bluetooth subsystem support
Indeed ret does not return, I have modified the above code. You try again:
static int
	char path[64]="";
	struct file *fp;
	loff_t pos=0;
	int ret;
	if(ret < 0)
		return -EINVAL;
	if (IS_ERR(fp)) {
		return -ENOENT;
	if(ret < len){
		ret = -ENOENT;
	}else{
		ret = 0;
	filp_close(fp, 0);
	return ret;
As i have compiled bluetooth-support as module i can try to unload it before loading mt7615e module. Should be same,right? bluetooth-module can’t be unloaded…still in use (have unloaded all depencies (mtkbtuart)), but still in use…i guess bluetooth-daemon blocks it. need to drop the revert so i compile and install again without bluetooth.
same result:
ip_tables              28672  0
[   22.867561] cfg80211: Loading compiled-in X.509 certificates for regulatory d
atabase
[   22.897073] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   22.914501] platform regulatory.0: Direct firmware load for regulatory.db fai
led with error -2
[   22.923360] cfg80211: failed to load regulatory.db
[   23.042029] mt7622-wmac 18000000.wmac: Load firmware : /lib/firmware/mediatek
/mt7622-wmac_rf.bin
[   23.054968] mt7622-wmac 18000000.wmac: Load firmware ERR, count 1024byte
[   23.065892] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
root@bpi-r64:~# [   24.269933] mt7622-wmac 18000000.wmac: driver own failed
and now unloading/reloading does not work…have tried many times
@skype, which problem do you mean? i have only the problem with eeprom, where len is larger than the eeprom-file
Indeed ret does not return, I have modified the above, and I provide my test environment:
I don’t understand your above operations very well, because I always ask you for advice and Google search for wifi configuration. You see if you can get close to my test method so that I can help you solve some problems怂
I have not used rfkill, nor have I installed it yet. This means that after my configuration starts, I can directly search for wireless AP signals. I provided screenshots.
[    1.237983] rtc_mt7622 10212800.rtc: registered as rtc0
[    2.174171] rtc_mt7622 10212800.rtc: setting system clock to 2000-01-01T03:50:41 UTC (946698641)
[    5.545529] mt7622_wmac 18000000.wmac: ASIC revision: 76220010
[    5.589460] mt7622_wmac 18000000.wmac: Load firmware : /lib/firmware/mediatek/mt7622_wmac_rf.bin
[    5.664182] mt7622_wmac 18000000.wmac: Load firmware OK, count 1024byte
[    5.702666] mt7622_wmac 18000000.wmac: MAC addr = 00:0c:43:26:60:00
[    5.767225] mt7622_wmac 18000000.wmac: N9 Firmware Version: _reserved_, Build Time: 20190801210351
[    5.893336] mt7622_wmac 18000000.wmac: Firmware init done
[    5.922671] mt7622_wmac 18000000.wmac: Driver own success
[    5.554275] mt7615e 0000:01:00.0: assign IRQ: got 140
[    5.676722] mt7615e 0000:01:00.0: enabling device (0000 -> 0002)
[    5.739069] mt7615e 0000:01:00.0: enabling bus mastering
[    5.782814] mt7615e 0000:01:00.0: Load firmware : /lib/firmware/mediatek/mt7615e_rf.bin
[    5.834248] mt7615e 0000:01:00.0: Load firmware OK, count 1024byte
[    5.880527] mt7615e 0000:01:00.0: HW/SW Version: 0x8a108a10, Build Time: 20180518100604a
[    5.953826] mt7615e 0000:01:00.0: N9 Firmware Version: _reserved_, Build Time: 20190103180756
[    6.011722] mt7615e 0000:01:00.0: CR4 Firmware Version: _reserved_, Build Time: 20181207140436
[   13.727317] mt7615e 0000:01:00.0 wlp1s0: renamed from wlan1
root@MT7622:~#
and
root@MT7622:~# ip a
12: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
    link/ether 00:0c:43:26:60:00 brd ff:ff:ff:ff:ff:ff
    inet 192.168.1.3/24 brd 192.168.1.255 scope global wlan0
    inet6 fe80::20c:43ff:fe26:6000/64 scope link
13: wlp1s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
    link/ether 00:0c:43:28:05:ab brd ff:ff:ff:ff:ff:ff
    inet 192.168.1.5/24 brd 192.168.1.255 scope global wlp1s0
    inet6 fe80::20c:43ff:fe28:5ab/64 scope link
and
root@MT7622:~# iw dev
phy#1
        Interface wlp1s0
                ifindex 13
                wdev 0x100000001
                addr 00:0c:43:28:05:ab
                ssid mt7615e
                type AP
                channel 48 (5240 MHz), width: 20 MHz, center1: 5240 MHz
                txpower 6.00 dBm
                multicast TXQ:
                        qsz-byt qsz-pkt flows   drops   marks   overlmt hashcol tx-bytes   tx-packets
                        0       0       0       0       0       0       0       0          0
phy#0
        Interface wlan0
                ifindex 12
                wdev 0x1
                addr 00:0c:43:26:60:00
                ssid mt7622
                type AP
                channel 6 (2437 MHz), width: 20 MHz, center1: 2437 MHz
                txpower 20.00 dBm
                multicast TXQ:
                        0       0       0       0       0       0       0       0          0
root@MT7622:~#
I will provide my two bin files again, it seems there is no problem at present.
eeprom.c (2.7 KB) mt7615e_rf.bin (1.2 KB) mt7622_wmac_rf.bin (1 KB)
I have found no fatal problems in my current test!
I tested only mt7622 and used eeprom-file from first post of this thread. But also without modifying eeprom.c i have the driver own issue. With bluetooth i can unload mt7615e module and reload it to get it working. Without bluetooth i got always the driver own issue
Could you try my 5.9-mt76eeprom branch to have same config? My buster rootfs is prepared to test bluetooth too,so i have installed those tools.
No problem, I will test it next week. Can you provide your configuration, and I will refer to your config for testing.
you mean my hostapd-config? (works only if not driver own issue appears)
#ctrl_interface=/var/run/hostapd
#ctrl_interface_group=0 # These 2 are just parameters so that the hostap daemon runs.
interface=wlan0
driver=nl80211
ssid=r64_APi
hw_mode=g
channel=2
#macaddr_acl=0
auth_algs=1
#ignore_broadcast_ssid=0
#wpa=2
#wmm_enabled=1
#wpa_passphrase=12345678
#wpa_key_mgmt=WPA-PSK
#wpa_pairwise=TKIP
#rsn_pairwise=CCMP
my kernelconfig:
https://github.com/frank-w/BPI-R2-4.14/blob/5.9-mt76eeprom/arch/arm64/configs/mt7622_bpi-r64_defconfig (currently with disabled CONFIG_BT, which is set to m in defconfig)
maybe any patch in my tree may break wifi? these are for bluetooth on r64
  • 6fc2b86858a8 bluetooth: mt7622: increase sleeptime in scpsys
  • 8b3ed61bb312 bluetooth: firmware: add mt7622 bluetooth firmware
  • d43115dd13d6 arm64: dts: enable bluetooth-node
  • f92108b7acfa tty: serial: don’t do termios for BTIF
the rfkill was previously used to fix the semaphore-issue: [BPI-R64] mt7622 mac80211 WiFi driver
i guess pcie and switch-changes does not affect wifi. strange that you don’t get the ret<len error…
