there are two tables above, tx0-4 is in the first picture.
It is true that other people gave me incomplete information, and there is no 5G configuration. I don’t know where the four antennas are.
aahh.image is stripped off (goes till 0x1e)…i have to click on it to see all.
this is the information I obtained in the discussion group. I will ask if there is any other information to provide to you. In addition, do you have debian wlan0 test code? AP and client. I use hostapd -B /etc/hostapd/hostapd.conf to report errors. I don’t have these configurations yet.
interface=wlan0
driver=nl80211
ssid=mt7622
root@MT7622:~# hostapd -B /etc/hostapd/hostapd.conf
Configuration file: /etc/hostapd/hostapd.conf
nl80211: Could not configure driver mode
nl80211: deinit ifname=wlan0 disabled_11b_rates=0
nl80211 driver initialization failed.
wlan0: interface state UNINITIALIZED->DISABLED
wlan0: AP-DISABLED
wlan0: CTRL-EVENT-TERMINATING
hostapd_free_hapd_data: Interface wlan0 wasn't started
I have only ap-code ready (2g4 and 5g,for r2,but you only need to replace iface names)
https://www.fw-web.de/dokuwiki/doku.php?id=en:bpi-r2:wlan#hostapd
Have not tried yet with mt7615/mt7622. Mt7615 is currently in my r2 (added antenna on wf3 today so i can test 2g4 and 5g). with and without the firmware-file i got a driver own failed…
without i see this:
[ 49.882535] mt7622-wmac 18000000.wmac: Load firmware : /lib/firmware/mediatek/mt7622-wmac_rf.bin
[ 49.891445] mt7622-wmac 18000000.wmac: Open file failed : /lib/firmware/mediatek/mt7622-wmac_rf.bin
[ 49.901529] mt7622-wmac 18000000.wmac: Invalid MAC address, using random address 02:9d:39:63:ac:55
[ 51.114069] mt7622-wmac 18000000.wmac: driver own failed
with the file i see this:
[ 31.582413] mt7622-wmac 18000000.wmac: Load firmware : /lib/firmware/mediatek/mt7622-wmac_rf.bin
[ 31.594925] mt7622-wmac 18000000.wmac: Load firmware ERR, count 1024byte
[ 31.601739] mt7622-wmac 18000000.wmac: Load firmware OK, count -2byte
[ 31.610768] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
root@bpi-r64:~# [ 32.826357] mt7622-wmac 18000000.wmac: driver own failed
looks like the error message is added by this patchset: https://www.spinics.net/lists/linux-wireless/msg200710.html
i cannot start AP on wlan0
Could not set interface wlan0 flags (UP): Input/output error
nl80211: Could not set interface 'wlan0' UP
i still have the rfkill-option active (softdep rfkill pre: mt7622)
tried 5.9-main (without the eeprom-patch), same result
seems like it is the rfkill-issue again… i loaded rfkill-module before mt7615e and then i got the firmware-load and can start hostapd
i tried to change the rule because driver-module is named mt7615e instead of mt7622m same result (after reboot). directly after boot i get the driver own failure, if i unload the module and load again, i get the firmware-info…maybe mt7622 is blocked some time
mt7622-wmac 18000000.wmac: N9 Firmware Version: _reserved_, Build Time: 20190801210351
rfkill is loaded on boot, maybe the wlan0-interface in /etc/network/interfaces blocks…removed it so network is started completely, but same
root@bpi-r64:~# service networking status
�● networking.service - Raise network interfaces
Loaded: loaded (/lib/systemd/system/networking.service; enabled; vendor prese
Active: active (exited) since Thu 2019-02-14 10:12:03 UTC; 1 years 7 months a
Docs: man:interfaces(5)
Process: 164 ExecStart=/sbin/ifup -a --read-environment (code=exited, status=0
Main PID: 164 (code=exited, status=0/SUCCESS)
Feb 14 10:12:02 bpi-r64 systemd[1]: Starting Raise network interfaces...
Feb 14 10:12:03 bpi-r64 systemd[1]: Started Raise network interfaces.
root@bpi-r64:~# lsmod
Module Size Used by
aes_generic 36864 1
cmac 16384 1
btmtkuart 24576 0
bluetooth 512000 20 btmtkuart
ecdh_generic 16384 2 bluetooth
ecc 24576 1 ecdh_generic
rfkill 32768 3 bluetooth
libaes 16384 2 bluetooth,aes_generic
ip_tables 28672 0
x_tables 36864 1 ip_tables
root@bpi-r64:~# modprobe mt7615e
[ 52.224481] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 52.380732] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 52.388300] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 52.399402] cfg80211: failed to load regulatory.db
[ 52.564273] mt7622-wmac 18000000.wmac: Load firmware : /lib/firmware/mediatek/mt7622-wmac_rf.bin
[ 52.584584] mt7622-wmac 18000000.wmac: Load firmware ERR, count 1024byte
[ 52.592669] mt7622-wmac 18000000.wmac: Load firmware OK, count -2byte
[ 52.615394] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
root@bpi-r64:~# [ 53.823422] mt7622-wmac 18000000.wmac: driver own failed
root@bpi-r64:~# modprobe -r mt7615e
[ 83.800559] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 83.820595] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 83.827979] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 83.850229] cfg80211: failed to load regulatory.db
[ 83.948589] mt7622-wmac 18000000.wmac: Load firmware : /lib/firmware/mediatek/mt7622-wmac_rf.bin
[ 83.958684] mt7622-wmac 18000000.wmac: Load firmware ERR, count 1024byte
[ 83.974036] mt7622-wmac 18000000.wmac: Load firmware OK, count -2byte
[ 84.001470] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[ 84.054993] mt7622-wmac 18000000.wmac: N9 Firmware Version: _reserved_, Build Time: 20190801210351
root@bpi-r64:~#
btw. it looks like the eeprom does not get loaded…(ok-message is wrong because on err there is only ret-var set, but not returned). i added the len in brackets to see difference
[ 157.004155] mt7622-wmac 18000000.wmac: Load firmware : /lib/firmware/mediatek/mt7622-wmac_rf.bin
[ 157.019551] mt7622-wmac 18000000.wmac: Load firmware ERR, count 1024 byte (19880)
imho the len is wrong, it is passed to function so i guess it’s the size of full eeprom and sobuffer needs to initialized with zeros till len and then overridden with file-data (or filled after last file-byte)
root@bpi-r64:~# ls -lh /lib/firmware/mediatek/mt7622-wmac_rf.bin
-rw-r--r-- 1 root root 1.0K Sep 16 12:23 /lib/firmware/mediatek/mt7622-wmac_rf.bin
root@bpi-r64:~# ls -l /lib/firmware/mediatek/mt7622-wmac_rf.bin
-rw-r--r-- 1 root root 1024 Sep 16 12:23 /lib/firmware/mediatek/mt7622-wmac_rf.bin
but i get the same values second time i insert the module…but then initialization succeeds
@nagi have you an idea why driver own failes the first time (also without eeprom-patch - 5.9-main)? without the patch (revert 894b7767ec2fc21574775c354ab5350e51c2171c) i get this:
mt7622-wmac 18000000.wmac: Timeout for driver own
Could you try to uncheck “Bluetooth subsystem support” in make kernel_menuconfig?
Networking support --> < > Bluetooth subsystem support
Indeed ret does not return, I have modified the above code. You try again:
static int
mt76_get_of_file(struct mt76_dev *dev, int len)
char path[64]="";
struct file *fp;
loff_t pos=0;
int ret;
ret = snprintf(path,sizeof(path),"/lib/firmware/mediatek/%s_rf.bin",dev->dev->driver->name);
if(ret < 0)
return -EINVAL;
dev_info(dev->dev,"Load firmware : %s\n",path);
fp = filp_open(path, O_RDONLY, 0);
if (IS_ERR(fp)) {
dev_info(dev->dev,"Load firmware Faile : %s\n",path);
return -ENOENT;
ret = kernel_read(fp, dev->eeprom.data, len, &pos);
if(ret < len){
dev_info(dev->dev,"Load firmware ERR, count %dbyte\n",ret);
ret = -ENOENT;
}else{
dev_info(dev->dev,"Load firmware OK, count %dbyte\n",ret);
ret = 0;
filp_close(fp, 0);
return ret;
As i have compiled bluetooth-support as module i can try to unload it before loading mt7615e module. Should be same,right? bluetooth-module can’t be unloaded…still in use (have unloaded all depencies (mtkbtuart)), but still in use…i guess bluetooth-daemon blocks it. need to drop the revert so i compile and install again without bluetooth.
same result:
Module Size Used by
ip_tables 28672 0
[ 22.867561] cfg80211: Loading compiled-in X.509 certificates for regulatory d
atabase
[ 22.897073] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 22.914501] platform regulatory.0: Direct firmware load for regulatory.db fai
led with error -2
[ 22.923360] cfg80211: failed to load regulatory.db
[ 23.042029] mt7622-wmac 18000000.wmac: Load firmware : /lib/firmware/mediatek
/mt7622-wmac_rf.bin
[ 23.054968] mt7622-wmac 18000000.wmac: Load firmware ERR, count 1024byte
[ 23.065892] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
root@bpi-r64:~# [ 24.269933] mt7622-wmac 18000000.wmac: driver own failed
and now unloading/reloading does not work…have tried many times
@skype, which problem do you mean? i have only the problem with eeprom, where len is larger than the eeprom-file
Indeed ret does not return, I have modified the above, and I provide my test environment:
I don’t understand your above operations very well, because I always ask you for advice and Google search for wifi configuration. You see if you can get close to my test method so that I can help you solve some problems。
I have not used rfkill, nor have I installed it yet. This means that after my configuration starts, I can directly search for wireless AP signals. I provided screenshots.
root@MT7622:~# dmesg | grep mt7622
[ 1.237983] rtc_mt7622 10212800.rtc: registered as rtc0
[ 2.174171] rtc_mt7622 10212800.rtc: setting system clock to 2000-01-01T03:50:41 UTC (946698641)
[ 5.545529] mt7622_wmac 18000000.wmac: ASIC revision: 76220010
[ 5.589460] mt7622_wmac 18000000.wmac: Load firmware : /lib/firmware/mediatek/mt7622_wmac_rf.bin
[ 5.664182] mt7622_wmac 18000000.wmac: Load firmware OK, count 1024byte
[ 5.702666] mt7622_wmac 18000000.wmac: MAC addr = 00:0c:43:26:60:00
[ 5.767225] mt7622_wmac 18000000.wmac: N9 Firmware Version: _reserved_, Build Time: 20190801210351
[ 5.893336] mt7622_wmac 18000000.wmac: Firmware init done
[ 5.922671] mt7622_wmac 18000000.wmac: Driver own success
root@MT7622:~# dmesg | grep mt7615e
[ 5.554275] mt7615e 0000:01:00.0: assign IRQ: got 140
[ 5.676722] mt7615e 0000:01:00.0: enabling device (0000 -> 0002)
[ 5.739069] mt7615e 0000:01:00.0: enabling bus mastering
[ 5.782814] mt7615e 0000:01:00.0: Load firmware : /lib/firmware/mediatek/mt7615e_rf.bin
[ 5.834248] mt7615e 0000:01:00.0: Load firmware OK, count 1024byte
[ 5.880527] mt7615e 0000:01:00.0: HW/SW Version: 0x8a108a10, Build Time: 20180518100604a
[ 5.953826] mt7615e 0000:01:00.0: N9 Firmware Version: _reserved_, Build Time: 20190103180756
[ 6.011722] mt7615e 0000:01:00.0: CR4 Firmware Version: _reserved_, Build Time: 20181207140436
[ 13.727317] mt7615e 0000:01:00.0 wlp1s0: renamed from wlan1
root@MT7622:~#
and
root@MT7622:~# ip a
12: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 00:0c:43:26:60:00 brd ff:ff:ff:ff:ff:ff
inet 192.168.1.3/24 brd 192.168.1.255 scope global wlan0
inet6 fe80::20c:43ff:fe26:6000/64 scope link
13: wlp1s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 00:0c:43:28:05:ab brd ff:ff:ff:ff:ff:ff
inet 192.168.1.5/24 brd 192.168.1.255 scope global wlp1s0
inet6 fe80::20c:43ff:fe28:5ab/64 scope link
and
root@MT7622:~# iw dev
phy#1
Interface wlp1s0
ifindex 13
wdev 0x100000001
addr 00:0c:43:28:05:ab
ssid mt7615e
type AP
channel 48 (5240 MHz), width: 20 MHz, center1: 5240 MHz
txpower 6.00 dBm
multicast TXQ:
qsz-byt qsz-pkt flows drops marks overlmt hashcol tx-bytes tx-packets
0 0 0 0 0 0 0 0 0
phy#0
Interface wlan0
ifindex 12
wdev 0x1
addr 00:0c:43:26:60:00
ssid mt7622
type AP
channel 6 (2437 MHz), width: 20 MHz, center1: 2437 MHz
txpower 20.00 dBm
multicast TXQ:
0 0 0 0 0 0 0 0 0
root@MT7622:~#
I will provide my two bin files again, it seems there is no problem at present.
eeprom.c (2.7 KB) mt7615e_rf.bin (1.2 KB) mt7622_wmac_rf.bin (1 KB)
I have found no fatal problems in my current test!
I tested only mt7622 and used eeprom-file from first post of this thread. But also without modifying eeprom.c i have the driver own issue. With bluetooth i can unload mt7615e module and reload it to get it working. Without bluetooth i got always the driver own issue
Could you try my 5.9-mt76eeprom branch to have same config? My buster rootfs is prepared to test bluetooth too,so i have installed those tools.
No problem, I will test it next week. Can you provide your configuration, and I will refer to your config for testing.
you mean my hostapd-config? (works only if not driver own issue appears)
#ctrl_interface=/var/run/hostapd
#ctrl_interface_group=0 # These 2 are just parameters so that the hostap daemon runs.
interface=wlan0
driver=nl80211
ssid=r64_APi
hw_mode=g
channel=2
#macaddr_acl=0
auth_algs=1
#ignore_broadcast_ssid=0
#wpa=2
#wmm_enabled=1
#wpa_passphrase=12345678
#wpa_key_mgmt=WPA-PSK
#wpa_pairwise=TKIP
#rsn_pairwise=CCMP
my kernelconfig:
https://github.com/frank-w/BPI-R2-4.14/blob/5.9-mt76eeprom/arch/arm64/configs/mt7622_bpi-r64_defconfig (currently with disabled CONFIG_BT, which is set to m in defconfig)
maybe any patch in my tree may break wifi? these are for bluetooth on r64
the rfkill was previously used to fix the semaphore-issue: [BPI-R64] mt7622 mac80211 WiFi driver
i guess pcie and switch-changes does not affect wifi. strange that you don’t get the ret<len error…
i tried 5.8-main and there firmware is loaded the first time (no driver own issue)…so something is changed till 5.8 and 5.9 causing this issue
@skype which kernel did you use (5.9+)?
I am using linux 5.4.72, your branch.
Ah,ok, i got the driver own issue only on 5.9+,maybe the len-issue is also only there
in my 5.4 i see the semaphore-problem again (imho this was because bluetooth/rfkill)
root@bpi-r64:~# modprobe -r mt7622
root@bpi-r64:~# modprobe mt7622
[ 100.778469] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 100.787154] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 100.794318] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 100.803989] cfg80211: failed to load regulatory.db
[ 100.817743] mt7622_wmac 18000000.wmac: ASIC revision: 76220010
[ 100.823808] mt7622_wmac 18000000.wmac: Invalid MAC address, using random address 42:de:fd:15:bb:52
[ 100.832854] mt7622_wmac 18000000.wmac: MAC addr = 42:de:fd:15:bb:52
[ 111.069495] mt7622_wmac 18000000.wmac: Message -16 (seq 1) timeout
[ 111.075697] mt7622_wmac 18000000.wmac: Failed to get patch semaphore
[ 111.083874] mt7622_wmac: probe of 18000000.wmac failed with error -11
with eeprom-patch it looks like this:
root@bpi-r64:~# modprobe rfkill
[ 55.822252] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 55.830948] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 55.838025] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 55.847673] cfg80211: failed to load regulatory.db
[ 55.860947] mt7622_wmac 18000000.wmac: ASIC revision: 76220010
[ 55.866845] mt7622_wmac 18000000.wmac: Load firmware : /lib/firmware/mediatek/mt7622_wmac_rf.bin
[ 55.875668] mt7622_wmac 18000000.wmac: Load firmware Failed : /lib/firmware/mediatek/mt7622_wmac_rf.bin
[ 55.885127] mt7622_wmac 18000000.wmac: Invalid MAC address, using random address 46:c0:74:51:9a:d9
[ 55.894111] mt7622_wmac 18000000.wmac: MAC addr = 46:c0:74:51:9a:d9
[ 66.013328] mt7622_wmac 18000000.wmac: Message -16 (seq 1) timeout
[ 66.019530] mt7622_wmac 18000000.wmac: Failed to get patch semaphore
[ 66.027684] mt7622_wmac: probe of 18000000.wmac failed with error -11
root@bpi-r64:~#
mhm, failed is because file is named “mt7622-wmac_rf.bin” instead of “mt7622_wmac_rf.bin” (seems filename differs between 5.4 and 5.9)…modulename is in 5.4 (mt76_new) also mt7622 and not part of mt7615e
after removing the CONFIG_BT and copy the eeprom-file to other name:
[ 84.258144] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 84.266821] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 84.273471] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 84.282212] cfg80211: failed to load regulatory.db
[ 84.353538] mt7622_wmac 18000000.wmac: ASIC revision: 76220010
[ 84.359422] mt7622_wmac 18000000.wmac: Load firmware : /lib/firmware/mediatek/mt7622_wmac_rf.bin
[ 84.369517] mt7622_wmac 18000000.wmac: Load firmware OK, count 1024 byte
[ 84.376288] mt7622_wmac 18000000.wmac: MAC addr = 00:0c:43:26:60:00
[ 84.383543] mt7622_wmac 18000000.wmac: HW/SW Version: 0x8a108a10, Build Time: 20190801210006a
[ 84.383543]
[ 84.406056] mt7622_wmac 18000000.wmac: N9 Firmware Version: _reserved_, Build Time: 20190801210351
[ 84.461907] mt7622_wmac 18000000.wmac: Firmware init done
[ 84.487375] mt7622_wmac 18000000.wmac: Driver own success
[ 88.245589] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
root@bpi-r64:~#
so eeprom-load on 5.4 works if CONFIG_BT is disabled…else i got the semaphore-error. on 5.9+ i got the driver-own issue and eeprom load failed because len is too big (eeprom-size differently in eeprom_init)
@nagi have you an idea about the driver own issue? It seems not related to bluetooth (like semaphore issue on 5.4).
Mhm,found this https://github.com/openwrt/mt76/issues/438#issuecomment-688114445, but it’s not compatible with my 5.9 source…seems there are Patches missing. but it looks like 5.9.3 has the patch already… => driver own issue fixed in 5.9.3…still have the different len problem…
drivers/net/wireless/mediatek/mt76/mt7615/eeprom.c:75: ret = mt76_eeprom_init(&dev->mt76, MT7615_EEPROM_FULL_SIZE);
drivers/net/wireless/mediatek/mt76/mt7615/eeprom.h:20:#define MT7615_EEPROM_FULL_SIZE (MT7615_EEPROM_TXDPD_OFFSET + \
drivers/net/wireless/mediatek/mt76/mt7615/eeprom.h-21- MT7615_EEPROM_TXDPD_COUNT * \
drivers/net/wireless/mediatek/mt76/mt7615/eeprom.h-22- MT7615_EEPROM_TXDPD_SIZE)
it looks like this calculation has changed a bit with dc7bd30b97aa (mt76: mt7615: fix EEPROM buffer size), but was also larger than 1k
drivers/net/wireless/mediatek/mt76/mt7615/mt7615.h:54:#define MT7615_EEPROM_SIZE 1024
drivers/net/wireless/mediatek/mt76/mt7615/eeprom.h:14:#define MT7615_EEPROM_TXDPD_OFFSET (MT7615_EEPROM_SIZE + \
drivers/net/wireless/mediatek/mt76/mt7615/eeprom.h-15- MT7615_EEPROM_DCOC_COUNT * \
drivers/net/wireless/mediatek/mt76/mt7615/eeprom.h-16- MT7615_EEPROM_DCOC_SIZE)
drivers/net/wireless/mediatek/mt76/mt7615/eeprom.h:11:#define MT7615_EEPROM_DCOC_SIZE 256
drivers/net/wireless/mediatek/mt76/mt7615/eeprom.h-12-#define MT7615_EEPROM_DCOC_COUNT 34
on entering the mt76_eeprom_init-function i have a len of 19880, so we cannot check again the len…maybe it’s better to check for filesize after read and then fill eeprom-buffer with 0x00
DEBUG: Passed mt76_eeprom_init 127 len:19880
the ret=len imho only works for mtd, if the mtd-partition has same size as eeprom
added a filesize-function and compared the loaded bytes with its return-value…now i got read ok
[ 957.477558] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 957.630999] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 957.638469] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 957.649409] cfg80211: failed to load regulatory.db
[ 957.821120] DEBUG: Passed mt76_eeprom_init 150 len:19880
[ 957.827020] mt7622-wmac 18000000.wmac: Load firmware : /lib/firmware/mediatek/mt7622-wmac_rf.bin
[ 957.841716] DEBUG: Passed mt76_get_of_file 51 fsize:1024
[ 957.853486] mt7622-wmac 18000000.wmac: Load firmware OK, count 1024 byte
[ 957.875826] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
root@bpi-r64:~# [ 957.955821] mt7622-wmac 18000000.wmac: N9 Firmware Version: _reserved_, Build Time: 20190801210351
and it looks like mac is correctly read from eeprom-file
10: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
root@bpi-r64:~# hd /lib/firmware/mediatek/mt7622-wmac_rf.bin |less
00000000 22 76 05 00 00 0c 43 26 60 00...
as i see all have 4 bytes (first 54Mbit,channel1-6,7-10,11-14 as delta). i guess i need to set only the position you’ve mentioned…with delta-bytes=0 all should have same tx-power,right?
is the value directly the dBM (like comment mentiones)?
the defined value 00100110 is then 38dB (in eeprom-file too for all 4 antennas) which seems wrong to me…(26 in front of the line is hexadecimal representation). what is suggested (imho ~21dB) or max value?
also it looks like the eeprom also contain MACs for BT and both ethernet-ports (full mt7622 eeprom)
0x26 decimal is 38, I guess it should be: 38 * 0.5 = 19dBm, the other three parameters should be fine-tuned, so just leave it alone.
I think there should be a Bluetooth address set. I haven’t debugged Bluetooth there. I am not familiar with it. I think I still need to ask you for advice in the future.
why this calculation? or did you get -19dB with the value of 38?
is there an easier way to get the filesize? see my repo i linked before for my current implementation
for bluetooth i did not much except adding some patches, installed bluez and made some basic tests with bluetoothctl
@nagi is there a way to fix the semaphore-issue on (my) 5.4 without disabling CONFIG_BT? i have still the modprobe-config which loads rfkill before mt7622
The power values are in unit of 0.5dBm in registers.
This happens because both wifi and bt share some parts in the wbsys, I haven’t dived into this issue yet.
could you try kernel from my tree? change in build.conf board to bpi-r64 (remove # ), run
in mainline-kernel bluetooth is not working, at least because the scpsys and tty-patch is missing
or use kernels compiled from travis (github-releases)
Btw. I read that set_fs will be limited in 5.10 for some architectures because it can be a security hole. Is there any way to get the filesize without it?
