I’d recommend not configuring the ssh interface unless you really want to connect to it right now.
The OpenWRT on there is horrendously insecure and ancient, so better not expose it in any way.
10G is wrong though, the module by default runs in 1G mode, and can be configured to 2.5G mode, but host support for that mode is uncertain, and setting that mode is immediate and irreversible.
If you are trying to access it like it’s a 10G SFP module, there’s your issue right there.
I remember reading somewhere that the OpenWRT build only supports 10G sfp module, but I don’t recall the reason or how to remedy it.
On normal Linux the module just worked out of the box, with the kernel auto-negotiating the speed and mode with it.
I have a spare SD card so i will try to build the Debian images and have a look if it works there.
Do you mind sharing what image you used or the build options?
The speed is read from eeprom, negotiation is turned off.
I also do not use openwrt, and I really don’t know, of all different version out there, which one suipports what. Hopefully eventually all is supported.
I’m running Gentoo on mine, so there is no image or anything I could provide.
But anything running Franks latest 6.9/6.10/6.11 kernels should just work.
sorry for not answering for a few days.
I had some hard deployments at my job.
In the meantime i tried different things…
But I just hit my lowest point and tried to bridge the other mosfet of sfp1. And the same thing: nothing.
Then i tried to configure eth2 again insted of eth1 and now i got some output of ethtool -m eth2
root@OpenWrt:~# ethtool -m eth2
Identifier : 0x03 (SFP)
Connector : 0x01 (SC)
Transceiver codes : 0x00 0x00 0x00 0x02 0x00 0x00 0x00 0x00 0x00
Transceiver type : Ethernet: 1000BASE-LX
Encoding : 0x03 (NRZ)
BR, Nominal : 1200MBd
Length (SMF,km) : 20km
Length (SMF) : 20000m
Length (50um) : 0m
Length (62.5um) : 0m
Length (Copper) : 0m
Length (OM3) : 0m
Laser wavelength : 1310nm
Vendor name : ZYXEL___________
Vendor OUI : 00:00:00
Vendor PN : PMG3000-D20B____
Vendor rev : V1.0
Option values : 0x00 0x1a
Option : RX_LOS implemented
Option : TX_FAULT implemented
BR margin, max : 0%
BR margin, min : 0%
Vendor SN : S234107503784___
Date code : 150525
Optical diagnostics support : Yes
Laser bias current : 15.194 mA
Laser output power : 2.0000 mW / 3.01 dBm
Receiver signal average optical power : 0.0000 mW / -inf dBm
Module temperature : 41.85 degrees C / 107.33 degrees F
Module voltage : 3.3000 V
Alarm/warning flags implemented : Yes
Laser bias current high alarm : Off
Laser bias current low alarm : Off
Laser bias current high warning : Off
Laser bias current low warning : Off
Laser output power high alarm : Off
Laser output power low alarm : On
Laser output power high warning : Off
Laser output power low warning : On
Module temperature high alarm : Off
Module temperature low alarm : Off
Module temperature high warning : Off
Module temperature low warning : Off
Module voltage high alarm : Off
Module voltage low alarm : Off
Module voltage high warning : Off
Module voltage low warning : Off
Laser rx power high alarm : Off
Laser rx power low alarm : On
Laser rx power high warning : Off
Laser rx power low warning : On
Laser bias current high alarm threshold : 90.000 mA
Laser bias current low alarm threshold : 0.000 mA
Laser bias current high warning threshold : 70.000 mA
Laser bias current low warning threshold : 3.000 mA
Laser output power high alarm threshold : 3.1622 mW / 5.00 dBm
Laser output power low alarm threshold : 1.0000 mW / 0.00 dBm
Laser output power high warning threshold : 2.8183 mW / 4.50 dBm
Laser output power low warning threshold : 1.1220 mW / 0.50 dBm
Module temperature high alarm threshold : 100.00 degrees C / 212.00 degrees F
Module temperature low alarm threshold : -50.00 degrees C / -58.00 degrees F
Module temperature high warning threshold : 85.00 degrees C / 185.00 degrees F
Module temperature low warning threshold : -40.00 degrees C / -40.00 degrees F
Module voltage high alarm threshold : 3.6000 V
Module voltage low alarm threshold : 3.0000 V
Module voltage high warning threshold : 3.5000 V
Module voltage low warning threshold : 3.1000 V
Laser rx power high alarm threshold : 0.1995 mW / -7.00 dBm
Laser rx power low alarm threshold : 0.0015 mW / -28.24 dBm
Laser rx power high warning threshold : 0.1584 mW / -8.00 dBm
Laser rx power low warning threshold : 0.0020 mW / -26.99 dBm
You mean this specific Zyxel modem? Or some other unrelated SFP module? Cause of course it generally works, but I don’t know if this module correctly expressed the changed link speed.
If it for some reason does not work, the module is useless until you find a device that does speak 2.5G with it, to change it back to 1G.
Yes, I mean 2.5G SFP modules in general, as whether they are supported by the hardware is not well communicated in the official documentation. Sorry I didn’t get that you were asking about the specific one.
Bring this threat back to life. I suspect lots of pon or xgspon sfp modules are going to suffer from the same exact issue. Not keen to physically bridge the mosfet. Any software based hacks/patches/boot parameters?
Quote" Ok, I have managed to make this module at least work. The issue from my observation: It has a really long boot-up sequence, and only AFTER that sequence, it pulls the MOD_DEF0 pin low.
The problem: While that pin is not pulled low, the circuit of the BPI-R4 board itself does not turn on the power supply for the SFP module. There’s a mosfet that prevents it."
It cannot be circumvented by software. The logic is implemented via circuit, the software sees the module for a split second, and then it vanishes to never come back.
The BPI-R3 had no such circuicy, and any other bit of SFP hardware I tested doesn’t either. The module only does not work in the stock BPI-R4. And given the circuit diagram for the R4 has a place for a brige in place of the mosfet drawn into the diagram, I highly assume this was at least to some degree accounted for.
There are no ill effects to replacing the mosfet with a bridge. Other than the status LED being permanently lit.
I highly doubt it. The BPI-R4 is the first device I have ever seen that employs such an odd setup.
The R3 for example simply does not have any such setup, and just permanently powers the modules.
As does every Switch or Media-Converter I could get my hands on (meaning, the GPON module booted up fine in them).
