I’d like to add to the list support for MTU higher than 2030, which is the current limit. There’s a patch for the official OpenWrt release to enable it: A new dual 10G router based on Filogic 880 (Banana Pi BPi-R4) - #346 by pmisch - Hardware Questions and Recommendations - OpenWrt Forum
Getting the other 2 PPEs to work
Post Can’t be empty. Must be 20 char
wait, i thought it wasnt since dangowrts list didnt mark it off
If i may add to the todo, does someone know if/how can we check if the wifi driver supports 4addr for the WDS access point mode ?
@glassdoor This thread it aimed specifically at getting a mainline Linux kernel working on the bpi-r4. It is not about the highly modified openwrt one. We do keep an eye on the openwrt one, in case we wish to port things across. In the long run, if we can get all the needed features into mainline Linux, openwrt would not need a separate one, at least, on the more capable (more ram, cpu) platforms like the bpi-r4. This would result in far less work for the openwrt team in the long run. So, I would like to keep this thread more along the lines of a TODO list for the mainline Linux kernel running on the bpi-r4.
my bad for pooping in your thread
@frank-w Hello, I heard that map-e and dslite are also supported by hardware offloading but not support by mainline flow offload. Is it real?
There is a catch, when controlling output pins…
Something else seems could be added to TODO list:
ebpf xdp support
DS-Lite, 6RD, MAP-E/T and 464xlat hardware offload support
FYI i started new attampt to getting RSS/LRO to work based on upported patch from @balika011 with mtk. Btw. This is listed twice in the list…and thought that ppe was working with 4g too,am i wrong?
4g means 4gbps? If so seems correct.
I meant 4gb ram 36bit adressing afair was fixed for ppe too
eth: [net-next,v3,4/4] net: ethernet: mtk_eth_soc: support 36-bit DMA addressing on MT7988 - Patchwork
Yes there were some patches for this problem,but afaik ppe was independ of wed and ethernet fixes.
Could be this one,but not sure
PPE only supports 32bits address mode and hnat driver will allocate coherent memory for HNAT table , so we set dma mask to 32bits in ethernet driver to support 4GB dram.
@frank-w do you have any details of the current status of the LRO / RSS patches (what works / what doesnt work ect) and where to find the latest version of the patches
I have worked on porting functionality from vendor kernels to newer ones so am very happy to assist on these patches if it would help.
I should have my bpi-r4 device just before the end of the year.
currently i talk to mtk about rss (not yet lro). they give me a patch…but there are still some issues found (e.g. threaded napi)
And btw. I cleaned forum last 2 days from massive spammers. Also time not going into other tasks.
But pinctrl and and a bunch of dts patches are on the way to go into mainline linux.
Ahh ok, is the RSS only patch available somewhere to review ?
Nice ill keep an eye out for those changes
