Try reverting the latest change in ethernet driver which switches from rss to lro for mt7986 and some other changes. Imho it should work for r4,bit not tested after this change
I do not update the non-lts kernels normally to see changes i did there
Ah,i see you use the deb package…you should boot the itb file…not sure it is in the actual deb. And you miss the modules when only copy kernel itself
Well, even if the ethernet drivers were not ok, wireless should work, no? Yet, it didn’t.
Anyway, I was just trying to check if the ethernet speed had increased. I installed 6-14-main, all fine now.
So, you’re paying more attention to 6.12? Ok, i’ll try that one to check latest mediatek drivers. The mt7922 card here, sometimes goes kind of slow.
And now, the .deb package does not have the itb file, have to copy it manually as displayed on the procedure above. The package does have all the modules listed in the .config file.
Has anyone managed to get near 10 Gbps between, say, a PC and the router (Pro 4E)? I am using a 10 Gbps SFP+ DAC connected to the sfp-lan port. I got arpund 10 Gbps with --reverse switch passed to iperf3.
