I just edited it online. That works ok.
possible that this cannot be done with a new github account due to spam-protection.
have added the SFP(+) i have here
thinking if a shopping-link or similar is a good idea
Understand about the shopping links⦠I deleted them and BPIāRouterāLinux-Wiki.md with my modifications is attached. BPIāRouterāLinux-Wiki.md (1.7 KB) edit: my modifications does not contain the actual version published. Please copy-paste only added rows. Thanks
added your infoā¦needed to reformat it a bit (cols for board and vendor-code were swapped), please check if it is rightā¦
sata are m.2-boards used in the nvme-slot, right?
for the speed test on r4 we need the rss/lro to get full 10G
Created a second user for me,but still able to edit the page (not saved).
Please clear browser cache or use private mode for testing.
Great,
thanks a lot @frank-w , it looks
Sure that I will test SFP whenever rss/lro will be implemented and ready to test. ![]()
Thinking, does it is possible to add ā\nā in the comments cell?
THE JMB585 yes, but the ASM1064 is miniPCIe to 4x SATA3 card.
Deleting cache does not solve my problem, therefore i test commit and push in terminal using git client.
Did you changed your opinion about the links where the product was purchased?
No,i originally not added them but thought it will be better to see it in shop to have some sellers information
I added / amended some info. Feel free to amend again.
Work fine using browser to use write and preview tab.
hi, did it required some specific? i bought the 1M version and i get failed to read EEPROM: -ENXIO when pluging the cable on openwrt 24.10.0/24.10.0
Hello, sorry for the delay, I was not here on the forum for a long time. I tested it on debian 12 with re-compiled kernel from @frank-w
Added the Xraydisk 512GB (not the PRO) NVME, works ok in U-Boot and Linux. The i2c pins are not used, so no need to tape or remove 0-ohm resistors.
